Start of my E-Cruiser Project
E-GE
Post by E-GE » Jun 15, 2010 1:53 pm
After watching lot's of electronic vehicle video's on YouTube and driving in a Lotus Tesla I really want to have my own electric vehicle. Unfortunately I don't have the money to buy a Tesla from the shop, so I have to make my own e-vehicle which is going to be a Nirve B1 Beach Cruiser. For me it was obvious to choose for a Beach Cruiser cause of the looks and the low center of gravity.
I'm quite new to the electric vehicle e-bike scene, although I have been studying Electronics for 2 years ages ago.
Here you can see the bike I just bought and assembled for this e-bike project. The bike has 26" wheels.
As it comes to the performance of the bike I have several wishes:
- Instant start rear hub motor. (I'm going to remove the peddles and the chain so no freewheel needed)
- Fast accelleration is more important than topspeed.
-Top speed ± 30 MPH (or about 50 Kmh)
- 2 disc brakes and front-fork suspension
- Twist Throttle
- Lithium-ion battery pack
- No e-brake system
I have been looking around for the proper setup, and I find it very difficult to choose the proper setup. Until now I have the following setup:
- BMC V3 Rear Hub Motor (1000W) or BMC V2 High Torque Rear Hub Motor (600W)
- BMC full-twist Throttle
- LiFePO4 48V 10Ah Battery
- BMC 48V 50A Controller
- Cycle Analyst Stand-Alone
Can anyone tell me if this setup will work properly according the required needs? Any help or suggestions would be more than welcome!
Nirve B1 Cruiser - 9C 2806 Rear - 48V - still in the works: https://endless-sphere.com/forums/viewto ... =3&t=19171
itselectric
Re: Start of the my E-Cruiser Project
Post by itselectric » Jun 15, 2010 3:09 pm
- Twist Throttle
- No e-brake system
E-GE:
That is great that you have selected high torque / high speed setup. But how are you planning to put 2 disc brakes at the front? Are you planning to put rear brake? If you have to stop in a hurry, you will flip over with dual front disc brakes.
Ken
E-GE
Post by E-GE » Jun 15, 2010 3:35 pm
Hi Ken, With double disc brakes I mean one in the front and one in the rear. A superman dive over the steer was not exactly my idea :D
wheelbender6
Post by wheelbender6 » Jun 15, 2010 9:16 pm
Just build it!. It's gonna look so cool that you can't go wrong.
"Money can't buy you happiness, but it can buy you a yacht big enough to pull up right alongside it." - David Lee Roth
E-GE
Post by E-GE » Jun 16, 2010 1:19 am
Wheelbender,
Can you show me some pictures of your just finished project?
As for the looks: I want to keep the bike as clean and raw as possible. Do you have any tips for working away the cables? Drilling holes in the frame could be an option, but don't know how it will work out.
After seeing some BMC V3 video's on YouTube I guess I should go for the 1000W version :D
itselectric
Post by itselectric » Jun 16, 2010 4:28 pm
E-GE wrote:Hi Ken, With double disc brakes I mean one in the front and one in the rear. A superman dive over the steer was not exactly my idea :D
Ok. I see. The reason I am focusing around your front brake, if I am correct, your frame do not have rear disc brake mount, nor v-brake mount. We actually did a similar configuration with Nirve Classic-3. It has a coaster brake, no front brake.
- We installed Sturmey Archer XFD front hub drum brake
- We used a regen sensorless controller which also provide some regen brake to rear wheel
- the dropout width is not a standard 135 or 100mm, we use custom 115mm axle, with single speed freewheel
The BMC 1000W is a powerful motor with 48v pack, you need to have some good brake to stop. If you don't have mounting for the disc brake, you will need other type of alternative, or weld the disc mount onto the frame.
Here is the picture of the bike.
DSC00947 [800x600].jpg (94.54 KiB) Viewed 3004 times
gestalt
Post by gestalt » Jun 16, 2010 4:38 pm
That's a rockstar status cruiser frame to build an e-bike with, if you haven't already done so you should check out this thread https://endless-sphere.com/forums/viewto ... 8099&hilit and get a load of all those early motorcycles. I cant wait to see this bike start to take shape.
- be seeing you
E-GE
Post by E-GE » Jun 18, 2010 8:41 am
Hi Ken,
Nice bike you have there. Is there a forum topic of the build of you bike?
I'm going to replace the front-fork with a MTB suspension fork including disc brake. In the rear there is no disc brake mount yet. I'm going to use an adapter for the rear to make it disc brake compatible. I think that should do.
E-GE
Post by E-GE » Jun 18, 2010 9:00 am
gestalt wrote:That's a rockstar status cruiser frame to build an e-bike with, if you haven't already done so you should check out this thread https://endless-sphere.com/forums/viewto ... 8099&hilit and get a load of all those early motorcycles. I cant wait to see this bike start to take shape.
Hi Gestalt, Thanks for the link! I've build up a folder on my computer full of these old-skool bobbers and motorized bicycles just for inspiration.
I really dig your project. The bike is going to look completely different from the first picture. Unfortunately I'm not that skilled and can not weld, so I have to do it with more "plug and play" parts. I'm going to try to keep the bike as clean as possible.
itselectric
Post by itselectric » Jun 18, 2010 6:22 pm
E-GE wrote: Hi Ken,
Thank you for your comment! I don't have a topic of my build, it scatter all over the place, but here some of posting of my build:
the most interesting to you, may be the Electra cruiser and Crazy Chopper bike
Stealth Bike
https://endless-sphere.com/forums/viewto ... =6&t=16930
Solar Bike
https://endless-sphere.com/forums/viewto ... =6&t=13091
Crazy Chopper Bike
https://endless-sphere.com/forums/viewto ... f=6&t=7710
Electra cruiser conversion
https://endless-sphere.com/forums/viewto ... =6&t=17095
Cruiser Trike
https://endless-sphere.com/forums/viewto ... f=6&t=7674
I am a retailer/online dealer, so I have seem more bike and have converted many interesting bikes. By now, I know what works and what to avoid for pitfall.
Ken
geetarboy
Post by geetarboy » Jun 19, 2010 10:12 pm
Hi E-GE,I like those big white balloon tires on that black frame- nice contrast, what kind are they?
E-GE
Post by E-GE » Jun 20, 2010 6:05 am
Geetarboy, They are Schwalbe Fat Franks 26". I know Electra has the same kind of balloon bike wheels.
E-GE
Post by E-GE » Jun 20, 2010 6:46 am
I'm still not sure if I should go for a BMC v3 or a Crystalyte hub. I've been reading about the pro's and con's of both, but still find it hard to choose.
My feeling says I'm better off with the BMC v3 because of the circumstances where i'm going to ride the bike.
- Mostly flat and good city roads (no off roads)
- Not for everyday use
- Temperatures from 0°C to 25°C Max (32F to 77F)
- Toque / acceleration is what I want
- top speed of 25MPH is more than enough
Any help or advice would be appreciated. Can anybody show me a video of the acceleration of the BMC v3? I'm curious about the sounds that this motor produces. I can't find any good ones on YouTube.
E-GE
Post by E-GE » Aug 05, 2010 3:18 am
Finally, I have the stuff needed for my first e-bike project. :D
I will use a Nine Continent 2806 hub with a 25A Infineon controller on a Nirve cruiser with metal frame. The current space between my dropouts is 109 mm, while the dropout space needed for the 2806 hub is 134 mm.
That means I'll need to bend the frame for 25 mm which is quite a lot in my opinion. Here you can see 2 images of the frame.
Would it be safe to bend the frame, or do I need to make another construction? Any advice is welcome!
AussieRider
Post by AussieRider » Aug 06, 2010 3:55 am
G'day.
You can bend the frame a bit but make sure you keep the pedal & wheel sprockets lined up. Gently does it. Make sure the dropouts stay parallel as well.
Evolving E-bike
Retro style mid drive beach cruiser
Mid drive chopper
E-GE
Post by E-GE » Aug 07, 2010 10:54 am
Just finished working on my bike for this day. I've managed to get the rear 135mm hub into the 110mm frame by using a little tool to stretch the frame for tire replacements (it's laying on the ground on the left side in the image). As you can also see on the image below is that the 9C wheel in not really centered, although the frame is stretched on both sides. The space between the frame and rim on the left side is 28mm while on the right side it's 18mm. I'm not sure how to deal with this problem yet. I guess it's possible to drive, but a centered wheel would always be better. I've placed the washers on the outside to minimize the frame stretch. Are there any good reasons to place them inside?
Tomorrow I'll try to give the wheel it's first spin while upside-down by connecting all the parts. :D
E-GE
Re: Start of my E-Cruiser Project
Post by E-GE » Aug 16, 2010 7:47 am
Yesyes, got my first ride on the bike yesterday, although the bike is far from finished. First impressions are great. I was unable tot do a lot of testing since my single side calliper brake is not braking at all. I'll hope to find a front suspension fork with disc brake soon!
Whiplash
1 GW
1 GW
Post by Whiplash » Aug 16, 2010 8:10 am
Double post...
Power is a fascinating thing, the more you have, the more you want, but the real power is having the restraint not to use it all at once...............Um...Yeah..
The harder you work.....The luckier you get!!
"People who say it can't be done are often interrupted by those that have already figured out how to do it!"
Email me @ currentcycles@gmail.com
OR check out http://www.CurrentCycles.net
Whiplash
1 GW
1 GW
Post by Whiplash » Aug 16, 2010 8:11 am
For the wheel not being centered, You can try loosening the spokes on the side the wheel is to far over on and then tightening the other side to pull it over. Go really slow and try to count the turns you make and match them on the other side to keep it somewhat straight, then you can finish it up by checking the straightness of the wheel by spinning it and adjusting where needed to get it perfect, its not too hard just time consuming...Nice looking bike!
E-GE
Post by E-GE » Aug 16, 2010 8:36 am
Whiplash wrote:For the wheel not being centered, You can try loosening the spokes on the side the wheel is to far over on and then tightening the other side to pull it over. Go really slow and try to count the turns you make and match them on the other side to keep it somewhat straight, then you can finish it up by checking the straightness of the wheel by spinning it and adjusting where needed to get it perfect, its not too hard just time consuming...Nice looking bike!
The wheel has been trued by the local bike shop. I think the flight from Canada to Europe was quite bumpy, since the bikeshop found out that there is a slight bump in the rim, so it will never be fully trued.
After placing the wheel in the frame for the 2nd time I centered the wheel by adjusting the position of the axle. Have to say that it looks pretty good now.
By the way: The auto-cruise functionality on the new Infineon controllers is horrible. I'll desolder this "feature" as soon as I find a good instruction...
torker
Post by torker » Aug 16, 2010 8:51 am
I would try to run a washer on the inside. 9c motors have a really small flat on the axle. I would worry that it will try to pull through the dropout.
Dave When I die I want to slide in sideways yelling WooHoo what a ride !
Giant Rincon w rear 9C 6*10 10s Lipo 30+ amps
Specialized FSR Comp 9C 6*10 15s x 50A 3300 W :)
http://s18.photobucket.com/user/rolinfu ... t=3&page=1
docnjoj
Post by docnjoj » Aug 16, 2010 10:01 am
Torque arm(s)?
otherDoc
E-bike stable at our house
Steintrike Mad Max full suspension trike rear Cute 100H going on: Whoops, Cute wheel broke but I fixed it.
Sun USX delta trike EbikeKit small geared front wheel sort of front suspension for wife
Agniusm/A123 AMP 20 36 volts on the Steini has been taken off.
2x16000 Multisport from HK now gone as they died after 2 years
New Luna 10S bottle battery 13.6AH now on mine
Relatively New 10S4Px2 for wife's bike giving 20ah @ 40 volts home made Panasonic from Tumich. BMS's rule.
E-GE
Post by E-GE » Aug 16, 2010 10:33 am
docnjoj wrote:Torque arm(s)?
otherDoc
I'm currently drawing my custom torque arms for both sides. I've a steel frame, so for now I'm good.
torker wrote:I would try to run a washer on the inside. 9c motors have a really small flat on the axle. I would worry that it will try to pull through the dropout.
I'll try to place the washers on the inside next time I'll have to remove the wheel. The axle is not suited for every day pit-stops...
E-GE
Post by E-GE » May 23, 2011 5:15 am
I'm about to (re)start the project again. I've a new suspension fork with a brake disk and I've been working on a battery tank that's hopefully going to look quite awesome. I'll try to post some new photo's within the next few weeks!
torker
Post by torker » May 23, 2011 9:05 am
Yea +2 on the washers inside. If that is a steel frame it should be no prob to spread it a little more. You did say you are going to run singlespeed or no pedals so you could do like I did and file/mill the flat on the axle. I gained another 1/4 inch doing this. I pretty much had to as my rear drops are alum. and I was not about to spread those. I have to run a singlespeed sprocket now but no bother for me.
