andreym
Knuckles said:Well I finally got it all together. I re-flashed the MCU and set the amps to 50A.
When the LEFT e-Brake alone is slightly pulled (BK to GND is shorted) the throttle will allow variable regen.
When the RIGHT e-Brake alone is slightly pulled (EBS to GND is shorted) the controller shuts off.
When BOTH e-Brakes are applied the controller applies max regen to a stop.
-Knuckles
Can you share how to make this mod? I`d like to add this mod to Lyen`s 18fet controller - is it possible?
Thanks in Advance,
Andrey.
