liveforphysics
100 TW
This has some potential. It's a new FET just relased last month, and it's pretty damn exciting.
This FET applied in an RC controller type design could actually cool itself. lol
Big advantages:
It doesn't try to cool through a PCB! Cooling through a PCB = fail-boat.
It's not pacakge limited (like many SMT junk parts), yet it's cooling side is opposite it's connection side, so you can cool it!
The cooling tab is isolated for 2,500v. This means, no dicking around with kapton and silicon pads etc etc.
Combined Rth of 0.33C/W in an all ready isolated package!!!!!!! WOW!
Even at 175degC junction temp, it's only 1.9mOhm RdsOn!! WOW! 0.9mOhm RdsOn cold (as if the cold RdsOn ever matters)
1600amp pulse, 500amp intrensic diode with 150ns Trr (meaning it should tollerate freewheeling currents pretty well).
350amp current rating with a 100C case temp, (500amp 25c curent rating, a useless spec to look good on a datasheet)
Roughly 1"x1" foot print means it's possible to make a 300-phase amp rated controller (~100 battery amps) not much bigger than a pack of smokes (caps would be the biggest part aside from heatsink). Or, do a 12-18fet version for a serious controller.
Pd rated at 820watts (cute that they put numbers like this on the datasheet, but entirely impractical, still though, it has a decent cooling area.)
Datasheet:
http://ixdev.ixys.com/DataSheet/DS100269(MMIX1F520N075T2).pdf
Big advantages:
Datasheet:
