Series paralell switching battery pack
moostrodamus   100 W
Post by moostrodamus » Jun 09 2010 4:12pm
Howdy,
I found "instructable" on how to hook 2 motors up with a DPDT switch so you could run them either in series or parallel.
http://www.instructables.com/id/SIMPLE- ... he-switch/
So I used that and came up with this to hook up two 36v batteries to a DPDT switch to run either in series or parallel.
My understanding is top position would be Parallel, middle position off (use for charging?) and bottom position series.
Should this work?
Can i assume i should buy a 30 amp switch as i am using a 30 amp controller?
Lurning is hard. Any comments/ corrections appreciated,
Moo
Commuter: Crystalyte HS3540
Infineon 40 amp controller
Ping V2.5 48v 20ah
jateureka   10 kW
Re: Series paralell switching battery pack
Post by jateureka » Jun 09 2010 5:54pm
Normally DPDT switches have the two centre pins as common and they either connect to the two upper or two lower pins - only some switches have a centre off position, so you would need to check.
A controller rated at 30A may actually put out much higher peak currents for short duration so you should use a switch rated for a minimum of at least double the controller current. You would prabably need to use a battery isolation switch, but they are quite large. You can buy these from boating/4WD/caravan shops. The other option is to use a smaller switch to activate a DPDT relay to switch the hgh currents.
Depending on the battery chemistry you also might want to install some diodes per this thread http://endless-sphere.com/forums/viewto ... =2&t=14744
E-bikes: Bafang 8FUN; Mac; Ezee; FreeGo; Aprilia 7s LiPo; eLation V2; TerraTrike recumbent
E-motorbikes: ZEV 7100 LR scooter, 84V 60Ah LiFePO4.
ZERO 2011 S motorcycle, 51.8V 70Ah LiMno2, 2012 headlight, Kilovac EV-200 contactor
E-mower: EGO 56V mower & line trimmer
moostrodamus   100 W
Post by moostrodamus » Jun 09 2010 7:37pm
thanks for the link to that thread, lots of great info.
Moo
Ping V2.5 48v 20ah
jateureka   10 kW
Post by jateureka » Jun 09 2010 9:40pm
You also might want to look at this thread regards the effects of arcing http://endless-sphere.com/forums/viewto ... 95#p276095
Kiwi   1 kW
Post by Kiwi » Jul 19 2010 11:27pm
I am looking at this also, only I want to be able to run 100amps through the switch.
An important consideration is that, as you have to throw 2 switches to change between S and P, one MUST NOT close before the other one is open, or POOF!
So you need either a mechanical connected switch DPDT (Double Pole Double Throw), or 2 stage switching, eg a three position micro switch driving 2 relays, Position One=Series, Position 2= Break Series, Position 3=Parallel
Here are some DPDT Relays I found
100, 200, and 300Amp DPDT Relays. Note these are huge, heavy and draw a bit of current to keep them switched.
http://www.geindustrial.com/products/sp ... actors.pdf
These would suit you, 30amp continuous, also 50amp available.
http://www.rvpowerhouse.com/category.php?cat=10
Another option, which has failed me before due to them not switching at the same time is to use automotive headlamp relays.
You can get up to 150A ones. Get them from 4x4 accessory stores.
http://www.pickercomponents.com/Data_Sh ... _Sheet.pdf
I am planning to try again with these, but this time switch them one at a time, as below
So, you could have a small toggle switch on your bars, with series, disconnect and parallel positions.
You would also need a 12v dc converter to drive the relays.
I have yet to see a high current(100A) manual DPDT switch. Any one know of one?
Kiwi   1 kW
Post by Kiwi » Aug 06 2010 3:03am
Check this out Now thats a switch! $100us though.
http://www.grainger.com/Grainger/NKK-To ... Pid=search
ambroseliao   100 kW
Post by ambroseliao » Aug 06 2010 11:34am
The lovely NKK DPDT switch can be bought for around $53 at other online dealers.
http://www.alliedelec.com/search/produc ... KU=8700593
and
http://parts.digikey.com/1/parts/980869 ... 32-ro.html
and
http://www.mouser.com/ProductDetail/NKK ... taPw%3d%3d
There are also much less expensive DPDT or 4PDT center off switches that allow you to switch between series and parallel on the *Bay.
http://cgi.ebay.com/DPDT-Toggle-20-amp- ... 1312wt_886
http://cgi.ebay.com/4PDT-Toggle-Switch- ... 1254wt_886
I am currently installing a 4PDT center off switch in my Bosch Fat Pack setup which consists of 8 BPFs that can be switched to 8 parallel packs 8P (37V) to charge or 2S4P (74V) to run. The center off allows me to switch without worrying about shorting or overloading anything. I'm trying to implement a Cell-log battery monitor as well.
http://endless-sphere.com/forums/viewto ... =3&t=20000
Doctorbass has used this configuration with his Sony/Konion cells for many years without trouble. Of course, he's working on something more powerful and advanced now!
http://endless-sphere.com/forums/viewto ... =14&t=7240
Ambrose
http://www.ebikes.ca/ is the best!
TidalForce M-750X, Tidalforce S-750 with Crystalyte HS3540, 1x TF iO-X Cruiser. E+ 1000W hybrid bike. ebikes.ca DrainBrain & Cycle Analyst meters. GoPro HD Hero2 camera. Bosch Fat Packs, 37V 10Ah LiPO pack. Turnigy Multistar batteries
My blog: http://ebikerider.blogspot.com
Remember LiFEPo4 HVC is 3.65V and LVC is 2.7V
moostrodamus   100 W
Post by moostrodamus » Aug 06 2010 4:28pm
Awesome resources guys! Thanks!
Moo
Ping V2.5 48v 20ah
mwkeefer   10 MW
Post by mwkeefer » Aug 06 2010 5:22pm
I may have missed somthing but...
I do this now on my geared setups between 10S/20S and 12S/24S and the first thing I didn't note in your explaination was the controller you will use. It will need to be able to either work with the given voltage range (Tip122 transistor mod) or you will need 2 different voltage divider bridges to the LM317T voltage regulator to handle the different voltages - these will need to be switched while the pack is in disconnect state - the actual state model should be:
1.) Interrupt throttle return (relay)
2.) Remove Parallel Connection between packs - breaking the connection so you have 2 packs
3.) power the relay needed to switch from the 36v divider network to the 72v divider network
4.) power the relays needed to engage in series
5.) re-engage the throttle return.
This will ensure smooth and safe switching between the 2 possible voltage inputs :)
Hope this helps a bit !
-Mike
Regards,
Mike
{My Rides]
Brent Hasty   1 µW
Post by Brent Hasty » Oct 13 2011 9:00pm
Hay all,
Check out these heavy duty DPTD toggle switches 30A Amp rated for $22
http://www.mouser.com/Electromechanical ... |0&FS=True
Check out the Ebike my brother and I are building
http://www.youtube.com/watch?v=lByACVoDoyw
Thanks, Brent Hasty
(503)839-5471
http://www.hastyheat.com
See Our Feedback on Facebook
http://www.facebook.com/#!/pages/Hasty- ... 2342720320
____________________________________
"To mess up a Linux box, you need to work at it; to mess up a Windows box, you
need to work on it."
AussieJester   100 GW
Post by AussieJester » Oct 13 2011 9:15pm
Didn't doctorbass use contactors rather than switches
To change battery configuration?
KiM
DimGr   10 W
Post by DimGr » Oct 19 2011 2:59am
if I use 2 battery packs of 48V 12Ah(96V in series and 24Ah in parallel) how many Amps should be the dpdt switch?
amberwolf   100 GW
Post by amberwolf » Oct 19 2011 3:29am
How many amps is your controller going to pull from the pack(s)? That's how many amps the switch has to take.
DimGr   10 W
Post by DimGr » Oct 19 2011 3:34am
amberwolf wrote:How many amps is your controller going to pull from the pack(s)? That's how many amps the switch has to take.
40-50 Amps almost..
swbluto   100 GW
Post by swbluto » May 18 2013 11:10pm
Subscribing. This is extremely useful information. I think I'll copy it to the reference area.
