novembersierra28 said:you painted it yourself? how'd you do it if you don't mind my askin
i didn´t need a perfect finish so i did it with a spray can. took it all apart till i had the naked frame. tied it to the garage door motor with a thin wire and hanging there i could work from all sides. took silicone remover to clean it, then sandpaper, heated up the garage a bit, then primer and white spray paint. most of the work was putting it all together again. took me 3 days but most f that was waiting for the primer and the paint to get dry.
i´ll soon do the same with my old GT Karakoram - 16 or 17 years old but painted white it´ll look almost the same as the newer one and also have some green GT decals left - will use that in winter and in bad weather. with a smaller and lighter rear 500w Cute 128SX but sadly no disc brakes on this old bike :|
