We've gotten more testing done and the actual Kv is around 102...Nice! The controller isn't in yet, but according to Kelly, should be in this week. After that, we can really start putting thing thing through its paces. I'll be sure to update as soon as the controller is in. The hall sensor mount is also made and the halls are ready to go in...Just waiting on the controller.
Now for something funky. I used the 4-wire method to measure the resistance between each set of phase wires in delta and it came in well under 20mohms...Seems really low to me. Does that seem feasible to yall? The setup was a power supply with the motor and a small lightbulb in series, with one multimeter measuring current and another measuring the voltage drop across 2 sets of phase wires. I let the system get to somewhat steady state, then took the voltage drop divided by the current to get the resistance. I did it with and without the lightbulb and got the same resistance, also. The equipment is top notch (Fluke 289, Fluke 43B), so that's probably not the issue if there is one.
Thanks muchly!
-Cole
