DrkAngel
1 GW
Most people would like a true eCar but, due to range limitations, feel it necessary to settle for a Hybrid.
These calculations are based on the BMW "Mini E", mainly because it is the most efficient, (that doesn't look like a pedal-car).
Unlimited range - bumper mount a 16hp, 10kwh generator. This will provide power, nearly equal to continuous highway travel, (mpg unavailable.)
Total weight - 200 lb, plus gas and bumper mount, (equal to 1 large passenger).
http://cgi.ebay.com/NEW-16HP-10000-...itu=UCC&otn=5&ps=63&clkid=5477529288326174360
200lb+ ... but more efficient than most!
Electric starter & battery might be worth the extra weight!?
Extended range - 12hp, 6kwh generator. This will provide 50%+ of the power required for highway travel, effectively doubling range from 150 miles, to 300+ miles! Total weight - 125lb, (plus gas & bumper mount). Less than a typical male passenger.
Alternative to bumper mount would be a small trailer. An aerodynamic design, no taller than vehicle, should increase power requirements, only slightly. Trailer will also increase luggage capacity, for trips!
I'm not sure, but it is possible that a separate generator, might bypass emission control requirements.
At the very least, I would always carry around the 2.5hp, 1500 watt, 4-cycle generator that I picked up.
Only 52lb & small!
Getting stranded is no fun!
Highly recommended, would be a 4 cycle, compared to 2 cycle (2 stroke). 2 cycle might be lighter, but is less efficient and requires mixing oil w/gas.
If weight is not a primary concern, a Diesel generator will provide the best "mpg", (trailer highly recommended.)
Only 52lb & small!
