drewjet
Awesome build. Somehow missed it the first time around.
I have one of Matts reduction on my bike as well. For the Throttle problems I had, I found that going to a finger throttle helped alot over having a twist throttle. Ridding it alot also helps getting used to it as well. Also i am geared a bit lower as my top speed is about 31. Also i have Delta Wye switching on mine, so when I am off roading and need beeter resolution I switch to Wye and now top speed is only 20 MPH. I don't have the slipper clutch, but from my understanding of it, it should not be slipping too often, I think you may be set too loose.
Tell me more about the 3 speed. I am assuming that both peddle and motor power are going through it. How is it holding up? Do you shift much with it?
I bought the SRAM dual drive for mine, but elected not to use it as I was afraid all the power that the Astro puts out would destroy it.
Great build!
Great build!
