9 FET 72V Infineon Brushless Controller (LYEN's Edition) $89
electricridefl   1 kW
Re: 9 FET 72V Infineon Brushless Controller (LYEN's Edition)
Post by electricridefl » Apr 17 2011 8:16am
Yeah, I didn't want any lvc. I put in message...but, the controller work fine, but now I can't run 55v, because then I get twice the range. I mounted my controller in my basket, with some bubble wrap and wire tie. Controller does get a bit warm running 35mph for 10 miles. My motor was scorching after said ride. There is such a huge difference between 55v(22mph) and 96v(38mph). The difference is, the first I ride on more sidewalks. The second I enjoy the highway! I haven-t hit the 63v lvc with my 96v battery. I run my 72 cell nimh battery from 103v to 88.9v. At 88.8v, speed and power drop, and I flip switch for 2nd battery. Too bad I didn't have this controller before I built my batteries, or I would have used a123 to take advantage of the regen feature. Because what I really need now is an electric brake...This thing runs great! What a deal...$299 for a 72v controller...what a ripoff. Thank God for Lyen controller!
Rifle   1 kW
Post by Rifle » Jun 20 2011 1:50am
Do you have to have electronics knowledge to program this, or if you get the cable should you be able to figure things out? Where do you get the software for your PC?
2807 9c front hub. 48v 20ah Ping. 12s2p Lipo.
neptronix   100 GW
Post by neptronix » Jun 20 2011 1:57am
If you buy the programming cable from lyen with this controller, he provides everything you need. You don't need electronics experience and it won't require soldering.
ValeryDV   1 µW
Post by ValeryDV » Aug 26 2011 3:45am
I, too, became the happy owner of this controller. I couldn't resist, just looked inside. Really enjoyed the quality of the build. That's the way to do controllers for e-bikes. In the near time will set instead of the old monster (why I bought a kit with a controller ?).
stl_recum   100 µW
100 µW
Post by stl_recum » Sep 05 2011 9:31am
Are there any of these left?
FastDemise   100 W
Post by FastDemise » Sep 16 2011 10:03pm
I am interested as well in a controller if you still have 1 available. :-)
21" Hardtail, Docs Torque Arm, Lipo 20s2p, ebikes.ca 9C 8x8 and Lyen 6fet (both Mineral Oil cooled)
wineboyrider   100 MW
Post by wineboyrider » Sep 18 2011 9:35am
PM Lyen and see if he answers he's the one that knows if he has any left. :D :D :D :D
ES IS SAVED! THANK YOU JUSTIN.
Quajochem   100 W
Post by Quajochem » Nov 23 2011 11:34pm
Hi
I have a question, can I directly plugin this cycle analist to this controller?
"Direct Plug-in Model (CA-DP): This unit is designed to plug directly into a motor controller to get the appropriate signals, resulting in a tidy installation with minimal wiring. Most motor controllers have an internal current sensing shunt resistor that can be used for measuring current, as well as a hall sensor signal that can be used to detect the wheel speed in direct drive hub motors. The CA-DP is terminated with a 6-pin plug that connects directly to the modified Crystalyte, Infineon, and eZee Controllers that we have at www.ebikes.ca.
http://www.ebikes.ca/drainbrain.shtml
http://www.ebikes.ca/store/photos/CA-LDP.jpg
Or should I use this one:
"Direct Plug-in with Speedo (CA-DPS): This is a variation of the CA-DP device for ebike setups that can't use the hall signals in the motor controller for the speed sensing. This would include DC motor systems which don't have hall sensors, geared motor setups like the eZee kits where the motor RPM does not match the wheel RPM, and mid-drive arrangements where the motor powers through the bicycle drive chain. It uses a separate speedometer sensor and spoke magnet like the Stand Alone device to pick the speed from your wheel."
Does the 9 Fet controller have a direct plug? (would be really nice)
(I don't really like the extra wires just for some stupid magnet on a spoke and an equally ugly thingy tie-ripped to my fork)
BUT my motor is a geared motor, WITH HALL sensors. (Looks like MAC motor)
Is the analis capable of deviding the motor RPM by a factor 5? So it can measure my speed via the signals in my controller?
How does this work?
Quajochem
wineboyrider   100 MW
Post by wineboyrider » Nov 24 2011 8:43am
Yes, this controller has a direct plug in for the CA.
You have to use this one with the BMC as it is not a Direct Drive motor. AFAIK the speed only calculates properly with a DD motor. I know I have the CA-DP and wish I would have bought the CA-DPS as I like to use it with my 9c and my BMC setup. The CA-DP works, but the speed shows you as going much faster than you really are.... :mrgreen: :mrgreen:
Quajochem   100 W
Post by Quajochem » Nov 24 2011 10:41am
[/quote]
You have to use this one with the BMC as it is not a Direct Drive motor. AFAIK the speed only calculates properly with a DD motor. I know I have the CA-DP and wish I would have bought the CA-DPS as I like to use it with my 9c and my BMC setup. The CA-DP works, but the speed shows you as going much faster than you really are.... :mrgreen: :mrgreen:[/quote]
The gears in a geard motor have a typical ratio of 5:1. So it should show you your speed x 5
Have you tried to feed in 1/5 of the true wheel diameter when programming the CA?
That should do the trick or not?
I cannot try it because I haven't got it yet.
And I am really curious if this might work!
wineboyrider   100 MW
Post by wineboyrider » Nov 27 2011 9:13pm
:)[/quote]
Clever! I will try it and post back! Right now I am using the mini motor?????????which is also geared!!! If this works it would be great, but isn't the freewheeling aspect a factor as well?
Quajochem   100 W
Post by Quajochem » Nov 29 2011 12:20pm
Good point! But what's the point of measuring your speed when freewheeling anyway? :wink:
Ykick   100 GW
Post by Ykick » Dec 15 2011 9:46am
My #1 bike with the 9FET Lyen edition has been sitting about a month for wheel repair. (long story for another time...) So, 'been riding old #2 bike with what looks like a 12FET Conhismotor long housing controller.
#1 is back on the road and now being able to compare back to back, I gotta give mad props to this little 9FET Lyen edition. The thing is so smooth, it pulls strong when it should but doesn't draw excessive Amps and the throttle response is very linear throughout the entire range. The differences are night/day - stock Conhis controller doesn't even come close when used with basically the same motors/throttle.
I never thought there would be so much difference but it's there and whatever Lyen's doing to provide a better controller it's working!
Talent must not be wasted.... Those who have talent must hug it, embrace it, nurture it and share it lest it be taken away from you as fast as it was loaned to you.
- Frank Sinatra
Quajochem   100 W
Post by Quajochem » Dec 15 2011 3:58pm
Ykick wrote:My #1 bike with the 9FET Lyen edition has been sitting about a month for wheel repair. (long story for another time...) So, 'been riding old #2 bike with what looks like a 12FET Conhismotor long housing controller.
i haven't installed it yet, but
likE :D
chisixer6   1 kW
Post by chisixer6 » Jan 01 2012 9:26am
Lyen;
My setup..... Ebikekit gear hub on a 24" rear wheel. I will be running this at 48v, maybe later go up to 60v. I will be riding on flat ground. Will this controller work with my setup? Do you have any units left? Is there any other info that you need? Also want the CA anyalst setup too.
Jerry
Motobecane ..bafang front driver.. 42v
24" girls bike ..ebikekit 20" fwd..75v
24" Schweinn 9c 20"rwd 75v
26" Schweinn Yescomusa 48v 800watt dd
Easy Racer clone LWB.....24" rear e-bikekit 48v ..ready for testing
Hooligan clone , longer rear chain stay.. twin 20"...
fun bike...twin 16" wheels. small rear motor... ready for testing
convert my CLWB recumbent to a front bafung@48v..ongoing
pwbset   1 MW
Post by pwbset » May 03 2012 12:16pm
Just picked up a used 9fet and despite my efforts I'm not finding anywhere the default values programmed into this controller. My used one came with a programming cable so I'd like to experiment with it this summer maybe pushing up to 35-40A sustained with good, cold Montana airflow 8) , but apparently you can't read in existing controller values just blindly send new values. Previous owner states they're all still default as shipped from Lyen so 30A to the motor I assume. Anyone help out? Thanks!
methods   10 GW
10 GW
Post by methods » May 03 2012 1:15pm
The community could probably help more if Lyen made his documentation public and did not make it available only to those who purchase controllers :|
You would also get a lot more support from the community on the software if it were available for all to see instead of distributed only to those who purchase controllers.
Disclaimer: I sell things similar to what Lyen sells so I could be seen as a "competitor". That aside - I am a member first and a guy who sells stuff second... and if you dont know me well... I am a guy who always speaks his mind (what I believe to be the truth) no matter whether it is appropriate or not. The fact is that I (and many others) worked together for a long time on this board to pioneer our understanding of how these "infineon" controllers operate and we have always shared our knowledge freely so as to help the general public.
I am aware that this is Lyens sale thread.
This is also a thread in a public forum where posters are asking for the help - from Lyen yes - but also from subject matter experts such as myself and many, many others. It only follows that we (those who help) should have as much at our disposal as possible.
I speak only for myself and not on behalf of anyone else or any group of people.
-methods
Increasing battery voltage and controller current limit will result in a non linear experience
methods   10 GW
10 GW
Post by methods » May 03 2012 1:25pm
pwbset wrote:Just picked up a used 9fet and despite my efforts I'm not finding anywhere the default values programmed into this controller. My used one came with a programming cable so I'd like to experiment with it this summer maybe pushing up to 35-40A sustained with good, cold Montana airflow 8) , but apparently you can't read in existing controller values just blindly send new values. Previous owner states they're all still default as shipped from Lyen so 30A to the motor I assume. Anyone help out? Thanks!
To answer your question... no you cant read values out and your best bet is to just re-flash the controller with known good values. Who knows what bits the last guy diddled.
I assume that you got a version of the software from the guy you got the controller from- along with the manual and programming cable.
-methods
pwbset   1 MW
Post by pwbset » May 03 2012 1:32pm
methods wrote:I assume that you got a version of the software from the guy you got the controller from- along with the manual and programming cable.
Yeah, got software/cable etc. Just looking for baseline values to start with. Didn't realize this was "closed" software. That's too bad. We'll see what the CA readings give me once I'm riding.
Ypedal   100 GW
Post by Ypedal » May 03 2012 2:54pm
i have to agree here, i got few of these controllers on my hands and have not dared to hook any of them to my laptop for fear of turning them into a brick.. but i would like to and will soo need to do this as my trike will be using regen, the chopper needs tweaks and i have a general curiosity of how this works......
There must be a few threads floating around ES ??? no ?
Is there a feature to perform a backup of existing parameters if you want to create a restore point? even if you canot read what values are set ?
ES site status page:
methods   10 GW
10 GW
Post by methods » May 03 2012 3:22pm
A few threads?
Try a few hundred.
We have beaten the infineon controller to death and discussed it ad nauseum. The problem is that every few weeks Infineon (who XIE Chang or whoever it is this week) releases a slightly different version of the chip or the software interface or the circuit board... so there is no way to make a wiki or anything that will be of any value over time. It really just boils down to staying on top of it and sharing what we find.
There are about 10 guys on the board who are always rolling up their sleeves and translating their way into the latest releases to get things working - but those threads are buried pretty deep in the technical section.
-methods
nicobie   10 MW
Post by nicobie » May 04 2012 2:04pm
When you install Lyen's software then chose your controller (12 fet,18 fet etc.) a screen pops up that shows the values that can be changed by the user. I always assumed that the numbers shown were Lyen's default values.
But I could be wrong... :mrgreen:
Take it easy... but take it. (Woody Guthrie)
my eTownie build thread: http://endless-sphere.com/forums/viewto ... =6&t=23701
Magazine article https://www.electricbike.com/nicks-etownie/
randel24   1 mW
Post by randel24 » Sep 14 2012 12:43am
Hey guys, I have been building my second bike for about 8 months,(been taking care of my mom, Long road),anyway, I have last years Ampedbikes rear dd motor and Edward Lyen's 72v 9 fet controller, Edward has been very helpful to me with possible controller and phase combo's, but I am leary of trying them, I am not sure if the setup is MXUS or 9C or other motor. Does anyone have any experience with this setup? I am trying to avoid any unnecessary steps if possible! To avoid ruining anything. Also, I need to know how many poles this particular motor has so I can calibrate my DP Cycle Analyst,also from Lyen. Thank's I want to get this wired up this weekend and this will be my main tranportation when I retire my test mule! I tried to start a new post for this , pardon my noobie'ness. Randel
miuan   10 kW
Post by miuan » Sep 14 2012 7:13am
randel24 wrote:Hey guys, I have been building my second bike for about 8 months,(been taking care of my mom, Long road),anyway, I have last years Ampedbikes rear dd motor and Edward Lyen's 72v 9 fet controller, Edward has been very helpful to me with possible controller and phase combo's, but I am leary of trying them, I am not sure if the setup is MXUS or 9C or other motor. Does anyone have any experience with this setup? I am trying to avoid any unnecessary steps if possible! To avoid ruining anything. Also, I need to know how many poles this particular motor has so I can calibrate my DP Cycle Analyst,also from Lyen. Thank's I want to get this wired up this weekend and this will be my main tranportation when I retire my test mule! I tried to start a new post for this , pardon my noobie'ness. Randel
There are only a total of 36 combinations of hall and phase wires, actually 3 times less genuine ones if you take it relatively. Try different combos with a light brief throttle pull to see if the wheel turns without ill effects. If it turns in reverse direction, swap 2 phases and equal colored hall wires to reverse it back to normal direction. Don't be afraid to try, just don't do it with full throttle or extended time, before you find the correct combo.
999zip999   100 GW
Post by 999zip999 » Oct 19 2012 3:35am
Thanks works great on a 2810 plus A123 20 ah 24s. 30amp only ? perfect. 2260 watts and strong
Maybe 40 amps, Lyen is it limited ? Lots of hills maybe to warm at 40amps ? No small S.F. stuff and don't want to walk my bike up ricearoni hill..
