atom1025
So I recently invested into bulk charging. I purchased the necessary cell protection from Methods and purchased two 400w chargers from BMS. One charger at work one at home.
I chose 4.10v per cell so 61.5v output at ~3amps. I only use 5amps to and fro so charging takes about two hours.
Been running this for a week now and love the plug and play charging.
So my concern. The resting voltage after charge reads 61.05v (4.07per cell)on the 101wattmeter. The resting voltage after commute is around 54-55v roughly 3.6 per cell.
So it appears I am only using the lower spectrum of my pack. Obviously power is down a hair on the way home. So my question to ya all is.... Do you think using the lower end causes more abuse to the pack then say using the upper?
So I am kinda thinking bout getting a new charger with 62v output. 4.13 per cell. Put me more into the upper mid range.... might try and modify these chargers, myself since they are paperweights if replaced...
