SKATEBOARD video & gps 23 mph
papo2110   100 W
Post by papo2110 » Feb 27 2012 2:55pm
motor TURNIGY C6364-280 KV
SHOULD BE FAST VERY FAST
sk8norcal   100 MW
Re: SKATEBOARD
Post by sk8norcal » Mar 01 2012 5:05am
we seen all the RC motors on mountainboards or carveboard, all air rubber tires...
but haven't seen it on a skateboard or longboard, till now...
papo2110   100 W
Re: SKATEBOARD
Post by papo2110 » Mar 02 2012 6:18pm
E SKATEBOARD
photo 2KK.JPG (95.87 KiB) Viewed 40761 times
photo 4X.JPG (103.45 KiB) Viewed 40761 times
photo 3JJK.JPG (102.87 KiB) Viewed 40761 times
photo 1.JPG (102.96 KiB) Viewed 40761 times
photo 3.JPG (95.03 KiB) Viewed 40761 times
photo 1N.JPG (106.7 KiB) Viewed 40761 times
photo 4.JPG (89.31 KiB) Viewed 40761 times
photo 5.JPG (85.54 KiB) Viewed 40761 times
photo 2.JPG (130.03 KiB) Viewed 40761 times
EBJ   1 kW
Re: SKATEBOARD
Post by EBJ » Mar 02 2012 9:47pm
if what I am seeing is a single motor to drive both rear wheels,
then you will want to re-consider that.
Your skateboard will not turn if that is the case.
Other than that, looks great. That sprocket looks unique, where did you get it ?
and I imagine you have another piece on the front of the wheel that is used to "sandwich" the wheel in order to keep the sprocket secure ?
Beachcruzer   100 W
Re: SKATEBOARD
Post by Beachcruzer » Mar 02 2012 10:51pm
Very cool. How fast?
papo2110   100 W
Re: SKATEBOARD
Post by papo2110 » Mar 03 2012 1:52pm
EBJ wrote:if what I am seeing is a single motor to drive both rear wheels,
1 weel drive was going to make it 2 wheel drive
EBJ   1 kW
Re: SKATEBOARD
Post by EBJ » Mar 03 2012 6:48pm
looks like you may have already done so,
but if not,
try and design it such that the sprocket can be mounted to any of the wheels,
that way you can "rotate" the wheels as the driven-one gets worn out faster.
sk8norcal   100 MW
Re: SKATEBOARD
Post by sk8norcal » Mar 03 2012 7:33pm
I think there was a guy on here that drove both wheels with one motor,
i will find the link, maybe only works on dirt...
ran across this,
using a randal comp truck with floating "free spin'' axle,
http://www.alibaba.com/product-free/106 ... _Axle.html
anyways Papo, I am excited to see that you are working on this,
what wheel is that?
another alternative is using the wheels with the belt cogs that are cheaply available for e-boards.
(or the expensive electrifly, really huge, http://wackyboards.blogspot.com/2009/10 ... board.html )
I was thinking of going the easy route and using existing e-board trucks and mounting a brushless motor on it....
not sure how much they sell that back truck for...
sk8norcal   100 MW
Re: SKATEBOARD
Post by sk8norcal » Mar 04 2012 1:55am
sk8norcal wrote:I think there was a guy on here that drove both wheels with one motor,
stielz
http://endless-sphere.com/forums/viewto ... 3&start=15
i seem to remember some gas boards that also use a solid axle...
edit:
http://www.gopednation.com/forum/showth ... 902&page=3
http://wackyboards.blogspot.com/2010/01/motoboard.html
papo2110   100 W
Re: SKATEBOARD
Post by papo2110 » Mar 06 2012 9:19am
papo2110   100 W
Re: SKATEBOARD
Post by papo2110 » Mar 07 2012 9:42am
e skateboad
photo 1.JPG (100.81 KiB) Viewed 40627 times
photo 2.JPG (144.32 KiB) Viewed 40627 times
papo2110   100 W
Re: SKATEBOARD
Post by papo2110 » Mar 08 2012 10:03am
E-skateboard
photo 1.JPG (144.32 KiB) Viewed 40584 times
photo 2.JPG (134.75 KiB) Viewed 40584 times
sk8norcal   100 MW
Re: SKATEBOARD
Post by sk8norcal » Mar 08 2012 1:00pm
sick!!!
r u gonna weld that plate to the hanger ?
papo2110   100 W
Re: SKATEBOARD
Post by papo2110 » Mar 10 2012 4:05pm
sk8norcal wrote:sick!!!
Going to have it welded
papo2110   100 W
radio mod
Post by papo2110 » Mar 15 2012 9:58am
took radio apart making a new case much much smaller
grindz145   100 MW
Re: SKATEBOARD
Post by grindz145 » Mar 15 2012 10:43am
E-skateboards just don't get old to me. I can see a well-designed version as a true urban mobility alternative for >3 mile or so.
papo2110   100 W
Re: SKATEBOARD
Post by papo2110 » Mar 16 2012 7:24pm
finished remote
papo2110   100 W
Re: SKATEBOARD
Post by papo2110 » Mar 23 2012 4:38pm
the weld job
let me know what you think
EBJ   1 kW
Re: SKATEBOARD
Post by EBJ » Mar 23 2012 8:05pm
Looks great. Should hold up nicely.
Are you gonna paint it white or leave the cool "burn-marks" ?
papo2110   100 W
Re: SKATEBOARD
Post by papo2110 » Mar 23 2012 8:36pm
EBJ wrote:Looks great. Should hold up nicely.
test it then paint
papo2110   100 W
Re: SKATEBOARD video
Post by papo2110 » Mar 26 2012 7:55pm
rc motor
photo 4.JPG (110.28 KiB) Viewed 49783 times
photo 5.JPG (128.27 KiB) Viewed 49783 times
papo2110   100 W
Re: SKATEBOARD
Post by papo2110 » Mar 26 2012 7:57pm
sk8norcal   100 MW
Re: SKATEBOARD
Post by sk8norcal » Mar 26 2012 8:17pm
sick! mount that sucker up!
I wonder how much advantage 2wd have over 1wd for urethane wheels....
Uvedovle   1 µW
Re: SKATEBOARD
Post by Uvedovle » Mar 27 2012 4:17am
I'm looking for 2wd for offroad purposes, maybe you don't need it for you skate...
Good job!
papo2110   100 W
Re: SKATEBOARD
Post by papo2110 » Mar 31 2012 7:47am
skateboard almost ready
