N!cos 1st ebike build
N!co
The Netherlands
A few weeks ago i had the chance to ride a (eu legal) ebike. It confirmed what i always thought, its great but just a tad too slow @ 25kph! Commuting to work is now done by car. I tried a few times on a normal bike, but its just a bit too long, 20 km round trip.
I searched a bit on the interweb and found this forum. So after a lot of reading i got a bit of an idea what i wanted and what it would cost and decided to go for it.
At this moment a 12Fet Lyen & some stuff is on its way, and this is what i already gathered at the moment:
Clyte HS3540 second hand.
Ping 36V/15Ah.
speedict.
Clyte frame bag.
Fuse, main-switch, 6mm2 wire, shrink-tube and connector-blocks.
Already made a holder for the battery that will be bolted onto the frame through the bottom of the frame bag.
This is the secondhand bike i bought:
Will be continued...
Nice bike. Those are Magura HS33 hydraulic rim brakes front and rear, yes? You can splice an e-brake cutoff switch into the brake line.
Starting off the right way 8) Love it!
However i would have went for the H3525 and volted it up accordingly. It would consume less power on average an heat up slower. Since it uses less power you can go much farther at the same speed. I got the same motor you did and now I am regretting getting the higher speed wind over the lower speed wind. :(
My $.02 right there :D
Have fun with your build by the way, look forward for updates!
Yes, exactly those type brakes! I didn't even know hydraulic rim brakes existed! I found those hydraulic switches, that seems to me the neatest solution. Now i have to find out how i can fill and get the air out of the system. I know my way around cars and motorbikes, pedalbikes is new for me...
I was thorn between those 2 motors. I agree the high torque version would also be a sensible option. As the topic says, its my first build, you got to start somewhere.
I am even thinking now of 2 ebikes, a highspeed/offroad bike, and a sensible commuter...
Looks good. I think the HS3540 is a good choice to start with, specially if you got a good deal second hand. I don't think there would be a real big difference between the HT3525 and the HS3540 winding in terms of efficiency, if you run them at different voltages to give close to the same top speed. Going a given speed will always take x amount of watts regardless of winding type.
I installed eBrake switches about a month ago. I bought the kit mentioned here (http://www.unicyclist.com/forums/showthread.php?t=84815) for like $28 delivered. Used a sharp razor to cut the brake line. Leave at least 3" of line from the end (I put the brake sensor near the lever, since I'll be plugging it into the Cycle Analyst). Less than 3" will make it impossible to bleed.
If the brakes are new enough, the Magura bleed video is wrong. I had to google around a lot to find how to bleed at the lever. Something about loosening the lever/brake line interface three full turns to allow the bleed valve to pass fluid. Wish I kept the link...
I agree. I got the HS and wished I'd gotten the HT with 20" rim. I understand things a bit more than my first few months of e-biking. Experience does pay off. Especially when you get it from the school of hard knocks.
Nice battery mount.
Let's see your rear dropouts, torque arms? I know that frame is tricky to mount a hub motor in, very small dropouts.
Good choices! Close ups of your torque plates would help others, if you please?
You're gonna like it...
EDIT - oops, just noticed the controller orientation. Many of us keep the wire end pointing downward. If you never ride Rain, it probably won't matter. It might not even matter if you ride Rain but most agree that allowing for water to drain out of any potential opening is better than water draining in. Since you've got a small size controller package have you considered behind the seat post? That's where I mount mine, wires down, of course.
And the wheel is spinning:
Still a lot to do, tyres, new chain, friction shifter for rear, neaten the wiring, ad PAS, make controller waterproof.
And not to forget, make the torque plates! I don't know yet exactly how, but it will be something that has to be clamped on the axle.
EDIT: I am not planning to go out in the rain, but you never know. I like the place of the controller how it is now, but water is certainly one of my concerns.
I've gotta bike using that controller location and it's fine, wires down. Only caveat is to be sure the front tire can't touch at maximum suspension compression.
Welcome to ES, enjoy your eBike!
N!co said:
Wheel is in, controller has arrived. Battery is in the bag now. Still busy with the wiring:
Which frame bag is that? Crystalyte or Falcon EV?
Great progress! You are going much faster than my build.
Doesnt getting the motor spinning for the first time make you that much more pumped to just get it on the road!? :mrgreen:
Quick thought what about putting the controller in the frame bag with the battery if there's space?
Ya the overheating depends on how how hard you "push it". I have used that controller with a ping 36v 10ah inside a battery bag but that was for my girlfriends bike and she is no racer. Wires down for sure. Why didn't you go with the crystalyte 12 fet controller? Just wondering.
There was much more info about the Lyen/infineon controllers, thats the reason.
After lengthening the wiring of the controller i connected it again for a second test, now with the speedict connected. I was allready thinking the motor made too much noise, but then i saw a no load current of more than 20A!!! and a max. wheel speed of 30km/h. After a bit of reading here i concluded the fase/hall connections could still be wrong.
So after a few tries i have now a super silent motor, no load @ WOT of 2,5A and a wheelspeed of 50km/h! :D
Cant wait to get it running on the road, but still waiting on the tyres.
OK, f#ck the new road tyres, i've put the old worn knobby on the rear wheel! Test drive was great!!! :lol: Very smooth acceleration, even from standstill without pedaling. Very fast to 35km/h, and then creeping up to 40+. This is even more than i hoped for! Controller is limited at 20A batt / 50A fase. Motor stays cold, controller hardly warms up.
BTW, this is the torque arm, hex. bolt goes through existing hole in dropout. No torq arm on the gear side yet, but there will i mount one from Lyen.
Riding this ebike is great!! Used it for commuting a few times allready and some other trips. Cant keep myself from laughing when i overtake mopeds :mrgreen: :mrgreen: :mrgreen:
Its almost finished now i guess:
Well, some things left to do; mount second torq arm, make controller black, replace white tyraps with black ones, connect speed switch, connect pas and throttle to speedict...
Concluding, it was a bit of a guess to invest this kind of money when you don't really know if it all works out, but i'm glad i did it!
Update: 600km commuting, no problems. I ditched the skinny continental slick for a pair maxxis hookworms. The ride is much better now. It is a fully suspension but the hookworm take the bad roadsurface much better and i can corner with much more confidence.
Today i rode with a 6fet keywin controller inside the bag. It gets a bit warm at 20A. I want to upgrade it with some proper Fets to keep the heat down.
No controller in sight, better for stealth:
If i can get my hands on a cheap hubmotor that will do 35km/h @ 36V it will even be more stealth, and fast enough for commuting.
Thats a neat and stealthy commuter :)
Depending on your definition of cheap, a geared 8 or 10 turn mac motor is alot smaller than a HS, freewheels nicely and would meet your speed requirement (26" rim).
On 36v / 20a, a mac might be a bit more lively than a HS too :wink:
Paul :D
