cruzxia
- Joined
- May 18, 2012
- Messages
- 180
Justin
My setup is as follows:
Battery's - 18s lipo 75-61 volt Low voltage cutout is at 61v on the controller and 61.5v on the CA
Controller - 6 fet Lyen/Infineion direct plug in CA , shunt 2.000mohm
Throttle - Legacy (I plan to change this once the hang is resolved)
Motor - BPM Code 12
Problem 1 I have not had occur
Problem 2
The throttle dose this on every startup. I cant pinpoint what corrects the issue, I just wind the throttle on and off several times and suddenly it goes. I was wandering if it was time related, but I don't think so.
note:You do not have to go full throttle, to clear this, I just tested 0-1/4 throttle and it cleared.
Problem 3
This occurred yesterday again, as I was nearly home so I did not stop. after about 20 seconds it started working again.
What I noticed though was that after the event, the human power input was jumping up and down on the left of the main screen, I dont use the torque input. I then flicked through the screens, and the RPM was rolling numbers.
I think that there is the possibility that with no inputs on the torque throttle in and aux connectors, that spikes may be induced to these inputs. If the function is not being used (disabled in settings) you should disable the inputs and tie the ports high or low, so that there is no chance of induced voltages causing issues.
Once this issue is resolved, you should enable the brownout and watchdog functions in the PIC if you haven't already done so.
There is also the possibility of glitches through the main input, I have not studded the CA PCB, If you need help with this issue, you can PM me and I can try to help you out. I have been programing PIC Micros and designing PCB's for the auto and other industries for over 20 years.
cruzxia
Motor - BPM Code 12
Problem 2
Problem 3
cruzxia
