Spektrum
Hello
I have a crystalyte HS3540 front motor which is mounted on a steel fork.
I wanted to actually install a disc brake and tried two brakes unfortunately also not go.
The brake caliper of the Avid Elixir 5 and the Magura Louise grind on the screws of the side housing .With a 160mm brake disc and with a 180mm disc I've tried it and both times I am failed
I want to like to install Avid BB7 brakes. This caliper between the housing has place?
