sanford
Hi all,
Been a bit a of lurker over the past year or two. Living in South Hertfordhsire in the UK.
I originally planned a MXUS Carrea Banshee (Kona Stinky clone) build, however the wife needed that motor for her bike as she changed jobs and does not drive. So I put this together;
12s2p Lipo in the bag and controller attached to the underside of the rack. Works quite well, around 25mph or so top speed.
I have no frabrication skills, no knowledge of electrics and cannot really solder, just used one of them mini blow torch things to do the harness etc.
So, as the wife "stole" my motor and batteries, I was on the look out for a replacement and lucky for me I was able to buy Spacey's Greyborg frame and forks, Lyen Sensorless Controller plus HS3450 and Magic Pie. Only picked it up the other weekend as I was unable to get down before that. Thanks Spacey for the great deal.
So just now need to get it built up. I dont have a massive budget so will be trying to do this as easy and cheap as possible probably using second hand parts where I can.
Purchased so far just the tyres (2x DMR Moto Diggers) and tubes they are on there way from chain reaction.
Still to buy; Brakes, front and rear. Rear mech and chain. Throttle and Grips. Also Batteries - Hobbyking Lipo - Either 18s or maybe 24s and a bulk charger. Plus need to work out how and where to mount the batteries as well.
Not sure if I will try to build the Magic pie into a wheel myself or get someone else to do it, anyone in the UK estimate how much it might cost to get someone to do it? And should I go for a 24" or 26" wheel?
