nonlineartom
My Cycle analyst when plugged into the Lyen 12fet controller reads -11W when just in standby and seems to be showing far too many amps.
So whats the best way to accurately calibrate the CA, open up the controller and use a multimeter to read the resistor value of the internal shunt? Would I just hook onto the 2 solder points on the PCB for this and use the ohm setting?
Or is there an easier way?
On a connected note, just tried the 5304 V2 out for the first time, got it laced into a 20" rim. Gave it full acceration and the performance was quite dissapointing. The Controller should be giving out 45A, battery was fully charged at 50V and 3 speed switch was in the top speed mode, controller programming is totally stock. the acceleration kick was less than my bike at 1KW
Thanks in advance.
Thanks in advance.
