Broken Spokes - EZip - Solutions!
DrkAngel
1 GW
Upstate-Western-Southern Tier NY. USA
Broken Spokes seem to plague the EZip bikes.
Closer investigation was done!
Turns out, there are multiple reasons for these failures!
1. Torque is mono-directional, but typically, this is not accounted for.
The "torqued" spokes should have their elbows turned outward!
All EZips, I've had, have one side turned inward, one outward. (4 EZips, 1 IZip)
2. Hub spoke flange is too thin, spokes are not supported, so there is excessive stress on the spoke "elbow" causing early failure!
Solutions?
1. Re-directionalize spokes. (Partial solution)
2. Use better hub. I lucked into a few of these, present source unknown.
3. 12 gauge spokes with "proper directionality".
The EZip uses 14ga 258mm & 260mm spokes, I was able to find 260 & 261mm closest match, extra length was on purpose ...
This still doesn't address the issue of the spoke flange being too thin, so ... washers!
#4 SAE washers work nicely, and look impressive!
Nice and SOLID!
Oh! Why the "longer" spokes.
Well with the spokes "solidified" and capable of great strength, the weak point, is now the wheel, being a cheap alloy extrusion.
Might even pull the nipples, through the wheel.
So ... washers!
#10 SAE "stamped" washers have a nice concave side, that works nicely with 12ga nipples.
Aluminum alloy wheels don't particularly like steel, even zinc coated steel washers, against them, so I ran 2 wraps of duct tape between.
Also see: 14ga to 12ga Spoke Upgrade
Presently, I am testing 3 prototypes.
1. EZip Stepthrough, with oem spokes re-directionalized.
2. New alloy hub with new "WheelSmith" stainless spokes, properly laced to support torque. (Hub has smaller spoke flange diameter, used 262 & 264mm spokes - eZip oem are 258 & 260mm.)
3. "EnArmored"
EZip hub re-laced with 12ga spokes and #4 SAE washers.
Probably overkill, should have gone with a better wheel!
Gotta put it on a heavy hauler
Will try to heavily test #1 & #2, both are on 25.9V bikes, but will test at 37V, and probably 44.4V also.
As a test bed, I am building a 44.4V Lipo pack with 48V controller and quick mount thumb throttle w/12ga wire for connection to T-Plug on my eZip motors.
Everything fits in a 6-pack cooler!
Will Velcro between bars and front fork and run wire back to rear motor, extend thumb throttle, clip on, ready to go!
I would recommend relacing the oem wheel, for proper torque support, but also, adding #4 washers to all spokes.
Even though these spokes were previously abused, they have held up nicely for 700+ miles!
I did re-tension spokes after initial break in, new hub, spokes and nipples in old wheel.
Everything looks and feels great - 1000 mile report.
DrkAngel said:
3. "EnArmored"
Sorry! My "simpler" "solutions" seem to have rendered this heavy duty re-build ... unnecessary?
I did purchase a 3/16 Southpaw freewheel, in case I wish to rig a more powerful motor.
Presently, I am testing 3 prototype rebuilds.
Even though these spokes were previously abused!
1200+ miles and no problems! - Update
1600+ miles and no problems! - Update
3. "EnArmored"
Still, not placed in service ... yet. - Update
2500+ miles and no problems! - Update
3. "EnArmored"
It appears that I have "cured" the eZip broken spoke problem!
Merely re-directionalizing the spokes, seems to be enough!
Tho, I would recommend adding #2 washers, for, even better, elbow support - added strength.
(#2 for 14ga spokes, #4 for 12ga.)
Near the 2000 mile point, one of the abused oem spokes broke ... not surprised.
Decided to use the last of my 14g steel spokes, for a properly directionalized, "washered" install.
Purpose -
1. To test the effectiveness of spokes laced to best support the stress of an externally motored wheel.
2. To test a method of better managing-supporting elbow stress.
Parts:
18 - 258mm UCP (universal chrome plated) spokes
18 - 260mm UCP spokes
36 - #4 stainless steel washers
36 - M4 stainless steel washers (optional)
Tools -
Scotch tape ... ?
"Proper" spoke wrenches.
Cordless drill with "slot" bit.
When previously working with 12g spokes, I found it advantageous to pre-position the spokes.
Scotch tape worked nicely
#4 washers pulled the spoke "elbows" nicely close to the hub flange.
M4 stainless washers (accidentally purchased) gave secure corrosion free seating to the spoke nipples.
Completed relace.
P.S. As a test item, I applied a synthetic chain lube to the threads of the steel spokes.
Anti-rust?
etriker said:
Currie must have seen your thread.
They are now using aluminum hubs with thicker flanges and spoked with the pulling spokes on the outside. :)
Quieter motors, better hubs. They are on it ! :)
Damn!
They never sent my consultant fee.
2013 eZip LS broke a spoke at 1200 miles.
Overvolting might have helped ...
2009 eZip w/14ga UCP spokes and washers has held up an additional 4500 miles with no spoke issues.
Guess it was a good idea!
I will rebuild 4 wheels for eZip.
Been waiting for mass production opportunity.
2 OEM wheels with 13ga SS spokes and washers.
2 aftermarket alloy hubs, better rims and 14ga SS spokes - got 2 WheelMaster wheels, alloy w/SS spokes on clearance, will relace onto new hubs.
Will document ...
Maybe 5 ...
Got cheap steel compatible hub, but threads are tight.
Might cut some grooves in freewheel threads, create a die, and cut a bit deeper.
NOTE - The 2014 eZips, reputably, come with proper alloy hubs and likely have cured their spoke malady! ... ?
Will document ...
Maybe 5 ...
Darn! Mine is a 2013 model and I've had to have numerous spokes replaced, I think part of that is due to going to a smaller tire with higher pressure for less rolling resistance. I have since gone back to the stock size though and it seemed to help a little. I wonder if a 2014 eZip wheel would be worth buying. Honestly though I haven't really ridden the eZip much since I put the Yescom kit on my Trek, mainly because the eZip tends to shut down if I give it full throttle for more than like seven seconds! I have it overvolted to 36V with a new controller, the motor doesn't feel hot so I assume it's some kind of protection in the controller.
If I turn the power switch off and then on again it immediately starts to work again! I kind of want to make it a pedalic only system like I did to the Trek, but I lost pedal assist when I put in the 36v controller.
All breaking at the elbow on one side.
Where the spokes are inside the hub ... right?
Once they start breaking, you have to replace all.
Relace with SS spokes, directionally proper, but most importantly, add the washers!
My 2013 eZip Trailz LS suffered broken spokes @ 1500 miles ... typical.
Oops, running at 33,3V ...
Instead of "properly" re-lacing the original wheel I rebuilt one of the WheelMaster wheels with the compatible alloy hubs I picked up a few years ago.
I might have 3 eZip wheels that are primed for rebuilding with the 13ga SS spokes I bought for them.
13ga spokes w/washers and "proper" directionality.
After cleaning, inspection and lubrication I intend on an assembly line type mass re-lacing.
I have enough 13ga SS spokes for 4 wheels.
With my washer type install I highly doubt any further breaks, so might re-lace a 4th still good wheel.
If, as I suspect, one of the wheels has a bearing seat problem, I will attempt making dies and re-threading some of the cheap steel eZip compatible hubs I picked up.
Might try pulling good seat from hub and repairing a previous similar failed hub ...
Thanks DrkAngel for all the great information. There's a lot of information here and I'm having trouble figuring out the best solution for my 2008 Trailz with broken spokes. I need to order new spokes anyway so I will go ahead and replace them all, and relace them as you have shown. Do you have an ultimate "best" solution in terms of gauge, length, washers etc? I am also planning on replacing the freewheel with the ACS Southpaw 16T since I will have to take it off anyway.
Most important is to add the washers!
"Proper" lacing direction-pattern.
Parts:
18 - 258mm 14ga SS (Stainless Steel) spokes
18 - 260mm 14ga SS spokes
36 - #4 stainless steel washers (If too thin, use 2 per spoke) box of 100 is usually the best buy
..... (#2 washers might fit better? - test on new spoke at hardware store before purchasing) .....
As luck would have it, I broke a spoke today on my Trailz men's bike. I did get home without any others breaking this timer, at least. It's a replacement wheel from Currie that I put on a little over a year ago, and I had hoped it would last longer. I already have another wheel on order, but I was wondering if anyone here would sell me 2-6 each of the 14 gauge 258 & 260mm spokes. A few #4 washers would also be great, although I should be able to find them locally...? I'm not going to re-lace the wheel, just want to make it usable as a spare bike.
HELP PLEASE , I have the replacement spokes for this ezip trailz but can not figure out how to get them thru the holes because I do not know how to get the side with the chain sprockets off the wheel to get at them the holes .Old Vet
Should be a 1 time operation ... ?
Best bet is to take wheel to a local bike shop.
Probably cheaper than buying the necessary tools.
Both motor and pedal freewheels reinstall by hand.
Removal from 2007 - 2009 eZips explained - $20 for 20mph
