Re: Cycle Analyst V3 preview and first beta release
Sent: Tue Jul 31, 2012 2:26 pm
by MattyCiii
Thanks for the response!
It's been bugging me all day. I'm at work so have no time/test equipment, and won't be able to check till tomorrow night. You're right - I need to go back to the setup that worked, then move forward from there. If I get things working I think I'll get the multimeter out and test all the DC voltaves (e.g., with the "+5" source) with the 6s battery, then see if anything changes with the 8s.
It's just disappointing to have had it all going, then with few changes to have nothing at all. I guess I have to set my mind to the fact that I need to slow down, dive into the documents, and prepare to do some methodical troubleshooting - test all connections, etc.
Thanks again,
Matt
Sent: Tue Jul 31, 2012 1:58 pm
by Ratking
Hello
I have re done all of my wires, so I don't remember the color code anymore. From where to where does the yellow wire go?
I don't see how it could work on the bench but then suddenly not work on the bike?
Have you checked all the necessary software on the ca?
You should have one wire from ThO(throttle out) to the signal wire of the hv160.
You also need ground and +5v.
Just control that you have that set up right, and check the mapping on the throttle in and out on the ca. Remember that the hv160 need under a certain pulse train on the input for start up. If the throttle is too high it wont let you start.
Please give me more details, because its hard to figure out if its hardware or software.
You could start with the 6s battery and see if it works then. If it does, I would see if everything was set up right in the software.
Sent: Tue Jul 31, 2012 12:49 pm
by MattyCiii
Thaks for the reply. I went out of time awhile and could not modify the bike. I'm back, bench tested the CA - worked fine, went for the real world test - fail. Details here: viewtopic.php?f=4&t=37964&hilit=throttle+pad&start=510#p617339
I wonder if I set things up the same way you did.
To confirm - you soldered the yellow wire to the +5v on the "dedicated throttle input" secion shown in the first post of this thread, yes?
Please let me know, THANKS,
Matt
Sent: Tue Jun 26, 2012 10:13 am
by MattyCiii
Thank you!!
This is my first build and my grasp of these things is shakey. But what you said all makes sense, and I agree - it's probably the best way to do things since I'll be routing the signal wire from the CA to the controller anyway, why not have the CA provide + and -
I'm using an Astro 3210, it worked rock solid with a cheap $11 servo tester from ebay/Hong Kong, so hopefully no twitchy with the CA. I'm re-reading the entire CA V3 beta now, it is so much easier to understand something you have in hand than trying to picture it in your mind.
Thanks for the info, I really appreciate it!
~Matt
Sent: Tue Jun 26, 2012 8:26 am
by Ratking
Hello
First of, I don't know if there is a better way of doing this, but as I tried you will need; ground, +5v and signal for the controller to work. Some people will say that you only need ground and signal, I tried it, but no cigar.
Since the ca have common ground, you can use the black wire, pin 2 as ground for the controller, Green, pin 6 is used as throttle signal, and I used the yellow wire as +5v. I had to re solder the yellow wire to the ca board. I used the throttle input +5v one. It should deliver enough current for our need. I use two controllers and have not had any problems.
I don't know what kind of motor you will use, but I would suggest to set the throttle ramp up time to 250-300. Default is 500 and it was very nervous and twitchy.
If there are problems, just ask. I don't mind helping if I can.
Henning
Sent: Mon Jun 25, 2012 9:45 pm
by MattyCiii
Subject: Cycle Analyst V3 preview and first beta release
Ratking wrote:
Thanks to Justin, I got my setup working last night.
I'm using the new ca with a hv160 and a Turnigy 80-10 130kv. I have not tried it on the road yet, still waiting for the final parts, but I can tell that the ca will be mandatory in every build I make.
Both the current and speed control worked flawless at the bench, only complain will be a short throttle range. In speed mode, the motor rpm will be max long before full throttle is applied.
I have the pulses set to min 0.99 ms and max 2.00 ms. Tried different variations, but with no luck. I want to try it with a heavy load before I make any assumptions, I will soon find out.
Hello I recently received my V3 CA preview, and HV160. I have the HV-160 operating off a servo tester just fine. Can you tell me which CA wires connect to the 160? I'm guessing pins 3, 4 and 6 of the JST-6-M (from here viewtopic.php?f=4&t=37964&start=420#p601462), but I don't know which goes to what color. What works for you?
Thank you,
Matt
