zombiess
Here is quick and dirty hex edit I've done of the the EB3xx software to allow for higher battery currents. This is not a pretty edit, but it does work. I did this for my own testing and because Steveo has been asking me to do it for him for a few days so I figured I might as well help everyone out. I included some of my working sample files I have been testing with as well.
This allows you to turn block time down to 0.0, do this first, no more than 0.1S block time on a high power controller if you want it to stand a chance at living.
Changes:
battery current all the way up to 250A
Block time as low as 0.0s
Regen voltage of 55,63,75V. I changed this for my own needs as I use this on my IRFB4115 18 FET controllers at 125V to get regen with the proper R12 mod to change LVC/HVC. 1200 ohm R12 = displayed voltage, 900 ohm R12 = 1.33x displayed voltage, 600 ohm R12 = 2.00x displayed voltage. For reference most of Lyen's IRFB4110 controllers use a 900 ohm R12, IRFB4115 controllers usually have a 600 ohm R12.
Disclaimer, if you blow up your controller... you probably pushed it to hard I sell 18FET and 24 FET replacements
For an even better selection of options use XPD. I need to spend some time hacking the source code on that to make sure the shunt values are what I think they are... just need more time. XPD kicks serious butt!
Enjoy.
View attachment EB3xx V2.zip
Changes:
Enjoy.
