TotalConfusion
Ok i have finally bit the bullet and purchased all my parts for my build.
I do have a few questions that i know have already been aswered on this forum but they are very hard to find at times.
1st of all are my parts purchased
1 Specialized Bighit DS DH bike
Rear Crystalyte H4040
5 speed cluster
Grin Tech 7240 controller
Cycle Analyst V3
Magura Throttle
3 speed switch
Sunrim DH Double track rim 24" x 39mm wide
13G Sapim Spokes from Holmes Hobbies
3 rear 24 x 2.5 Maxxis Hookworm Tyres, 26 x 2.5 Maxxis Hookworm front tyre
203mm rear disk upgrade from 160mm, Uberbike Sintered Compound Brake pads front & rear
Cellman 21s5p Samsung 20R Battery Pack & Charger around 9.75Amps, Not big but enough for my needs atm.
My Concern is the Magura Throttle, From what i underrstand i can wire it straight into the Cycle Analyst and adjust the voltage through the CAV3, Can anyone tell me if this is a correct way to do it and if not any links regarding a Magura throttle being connected to a CAV3 would really help me out please.
My other concern at this point is my battery connection to the controller, i have been told i dont need to run a inline fuse between the battery and the controller but this doesnt seen right to me becasue if there is any kind of fault with the battery or wires running to the controller it could blow the controller up or cause internal damage.
Can i have peoples thoughts on this also please and any links showing the type of fuses or breakers used would be appreciated.
I am currently desgining some dropout torque plates copied from Rodgah's Build with a few modifications and the battery is currently being shipped by FedEx from Cellman.
5 speed cluster
Cycle Analyst V3
Magura Throttle
3 speed switch
