mikereidis
- Joined
- Jul 24, 2008
- Messages
- 343
nutsandvolts said:This is all very interesting. What value resistor did you put in parallel with the original? I wish I had one box the size of a pack of cigarettes that could charge my six batteries in one hour.
My DMM says about 0.3 ohms, but I thought it was lower; didn't add whatever the connections and wire added. DMM accuracy is lowish at this scale. About 1.5 cm of single strand of picture hanging wire, in parallel with 0.67 ohm wire wound, at end of a few feet of alligator clipped 5 amp RC battery charger cable.
Well, my bridge rectifier and heat sink are about that size... Just wait'll I get some CV mode protection in. Don't want to see more smoked batteries/BMSs.
I pulled my lower 4 batts today. Two were giving me issues and another just started. If batts aren't puffed I'm hoping I can just replace a resistor or two.
I thought I was covered with Torx and Security torx, but my drivers aren't long enough for the width of the hole. Darnit ! Are these security Torx ? Mine are just drivers; are actual torx "screwdrivers" able to fit. Size ? Thanks...
I'm seeing indications on my 4 now charging "good" batts, that 2 of them seem to have 10 milliohms of resistance more than their bank-mate. Once again, could be resistor heat changing resistor value. I think I need something that works better for determing very low resistance values. I've been thinking more about just bypassing the BMSs; but they DO help protect the battery. Anyway, would like to understand more about the BMSs too, and how they might get damaged or be tweaked.
Well, Franktown Radar and my horizontal hand test indicate I might be able to get some riding in now, without rain. I'm REALLY curious to see what kind of range I can get on this bike with at least 4 good batts, using my previous standard test runs. Been disappointed with range lately, but it's been hard to account for the impact of my bad batts and all the switching I did to compensate. Should be fun to run 15 pounds lighter too.
I pulled my son in the trailer this aft. down a dirt/mud road (Baille ?) to go walking on a local ATV trail at end of Terry Fox. With this "kids bike" with bar ends on bar ends looking like some weird sort of chopper bars. Weight probably 330 pounds. Worked fine, even splashing through some mud puddles at tame part of trail.
Shoot; typing this and one of my batts is at 21.7v ! No wonder my BMSs are fried... At least that batt seems fully charged now; 21.00v but dropping slowly. Hmmm, this is the batt with 10 milliohms higher resistance already. I've noted that when a BMS is compromised it tends to be the one in a string that will go high like that.
