Interbike 2014, Las Vegas Sept 9-13
efMX Trials Electric Freeride said:
Nicolai Bikes RN1 at Interbike Las Vegas booth 32160
NICOLAI Distributor of USA, Darin Brin, interviewed Kalle Nicolai about the RN-1 Prototype:
Kalle Nicolai is well known worldwide as a passionate bike design engineer and two-wheel bike constructor. His company Nicolai GMBH is the last company that manufactures aluminum bicycle frames in Germany, in an industrial format. Besides his own Nicolai branded products, he has created many award-winning bikes for the brands GRACE, SMART and others in the field of electric mobility. When asked about what kind of vehicle is the RN-1 and why it was developed, Kalle has given us the following answer's:
The RN-1 bridges the gap between Ebike and motorcycle. We wanted to create a bike that is similarly smooth like a DH-Bike behaves, in the handling, & also additionally installing an engine power that can catapult to every situation like a motorcycle can. In my opinion this kind of bike should also not weight more than 50 kilograms and must have more than 5000 watts. We have been able to develop in co-operation with Swiss motor and electronics specialists ELTRONIC.CH, a new engine that weighs less than 10 kilos and can deliver over 10,000 watts of power. This combined with a Samsung 13S17P battery, (which is of high regard with the most modern batteries) puts out an energy content of 2200W in the market and allows for longer trips. The welded Nicolai Aluminum frame is designed so that it assigns many components in more than one function. For example, the motor housing and the battery cover is used as a stressed member of the frame. The suspension elements are adjusted with respect to damping and spring rated higher loads. The chassis is constructed so that it does not alter chain or belt lengthening or protracting during spring deflection in the rear. All electrical and mechanical components are sealed so that it comes into off-road use, no problems. Whether the market requires such a product, the customer will decide. I will not give it up, on my part.
On the question of when customers can buy this baby, Kalle said: We have in the coming months, additional components such as "front fender",''rear fender "and to develop the lamp panel, and of course test the bike extensively. In addition, we still need to execute the legalisation issues facing Europe and the United States. The RN-1 is really very nice and I look forward to the upcoming work and would therefore still leave no date for availability.
Technical data:
Suspension + frame:
Nicolai Double cradle tubular aluminum frame; ball bearing aluminum rear swing-arm; Rear suspension travel 240 mm; Fork SRS travel 203 mm;
Wheelbase 1382 mm; headangle 62,8 degree; Seat height 915 mm
Motor + Controller: Eltronic CM185; Rated at 5 KW; Peak power 10KW; No Gearbox.
Battery: Configuration 13S17P; Energy content of 2,200W; Nominal voltage 48 volts; Range depends on the selected driving mode between 30 -110 km;
General: total weight - 48 kg;
Find the RN1 at Interbike Las Vegas booth 32160
So more then a year later, vaporware or will it reach production?
I was thinking of the Nicolai RN1. According to statements made last fall RN1 was ready to ship last fall and should be out before Christmas - of last year.
After Interbike 2014 I have seen no more mentioning of the RN1. Vaporware of not?
the proto is real..
but demand must be adequate for sales before serial production..
also legal, access, and price issues..
and i would like to see pedals since Nicolai is a bicycle company..
but i think these types of bikes ARE coming.. whether from Nicolai or others..
(example kuberg freerider, etc..)
Time for a new era - #EBOXX Ultra // NOT E-BIKE - BUT E-MOTORBIKE ! 🚀⚡
Kalle Nicolai has been building bikes for off-road use for 25 years. Occasionally, he is criticised by loyal and beloved NICOLAI customers that the company is not as crazy as the early days, suggesting our current bikes are innovative and special, but have somewhat become high-tech mainstream. It was precisely the wild and wacky designs like the Lambda in the nineties, or the Nucleon born in the noughties which built our brand identity. Polarising machines that caused holler and heckle, but left nobody indifferent.
We would like to quote the boss: I simply love to design fast bikes that people enjoy, that warm their hearts and smile their faces. I love sitting at my desk late into the night, imagining, designing, calculating. I love the battle between design, error and re-design. The quest for solutions and down different paths that I descend. Then, I love to share these plans with my incredible engineers, fabricators, finishers and builders that can take the dream and create a reality from it. The results are celebrated, condemned, or we are simply called crazy Germans. The EBOXX Ultra will tick all three of those boxes.
The EBOXX Ultra closes the gap between eMTB and eMoto. eMotorbikes have massive power from 15 to 35 KW. Tonnes of torque, but weighing in over 100kgs can make handling difficult and can pull the brake levers on fun. In contrast, a licence-free eMTB weighs about 60% more than a comparable non-motorised MTB and provides similar handling and agility. However, due to their nominal power of 250 watts, eMTB’s don't have much oomph. The EBOXX Ultra weighs between 55 and 65kg, its motor has a peak output of 10 KW and generates an incredible 275 Nm torque at the rear wheel. This power combined with a weight much closer to an MTB than a motorbike guarantees maximum riding smiles, fantastic control and agile handling. The Italian-made Extreme Racing Shox suspension developed specifically for this bike can easily take on bombed-out tracks and the toughest trails.
NICOLAI is a mountain bike brand at heart, so at this point we clearly define that you have no business riding the EBOXX Ultra in your local forest on MTB trails: it is classified as a motor vehicle. The unrestricted motocross version, the EBOXX Ultra MX, reaches a top speed of 65 km/h and cannot be road legal in Germany in this form. Like any motocross bike, the MX version should only be operated on private, approved, and closed off-road tracks. Fortunately, approved off-road parks and tracks are becoming more common so you can legally let off steam with e-power.
With L1e-B approval, the EBOXX Ultra can be used in Germany as a road vehicle. With an electronic throttle of 4 KW and a maximum speed of 45 km/h, it falls into the category of small moped or scooter. It can be ridden with a scooter driving licence class AM from the age of 16, or with a regular class B car driving licence, which includes class AM. The EBOXX Ultra is not only a radical off-road fun machine, but an attractive alternative for those looking for a different view on their commute than from inside a car. With a 45 km/h limit, plenty of torque and agile handling, riding to work on the EBOXX Ultra is a great experience that might pass by too quickly.
The EBOXX Ultra will be available in variants with or without pedal assistance. The pedal-assist version is equipped with a 9-speed PINION gearbox in parallel to the throttle grip and the gear range allows you to pedal with electric-assist upto 45 km/h so fitness will not fall by the wayside. Alternatively, if you want to concentrate purely on the next berm or jump and accelerate only with the throttle, choose the version with fixed motorbike style footrests.
NICOLAI made no compromises with the EBOXX Ultra drive system by simply buying off-the-shelf parts. All components such as battery, controller, motor, wiring harness and much more have been specially developed for this bike. The control technology offered is completely new with intelligent functions and smart features, the details shall stay secret for a while.
The EBOXX Ultra is in an advanced prototype stage. By the way, the idea of developing an L1e vehicle is by no means new. Back in 2014, NICOLAI showed the first prototype of the NICOLAI RN1, which helped them gain valuable practical experience and develop suitable technology.
NICOLAI will offer the first test rides and accept orders starting OCTOBER 2021. The price will also be fixed by then. Delivery of the first series is planned for summer 2022..
NICOLAI-BICYCLES.com
Nicolai Eboxx Ultra / Eurobike 2021: Krasses E-Moped von Nicolai ..
[youtube]G9U9yRcY2Fs[/youtube]
Nicolai zeigt auf der auf der Eurobike 2021 seine Neuheiten für die Saison 2022. Die deutsche Traditionsmarke ist bekannt für seine visionären Ansätze und überrascht immer wieder mit Entwicklungen, die ihrer Zeit voraus sind. So auch für die Saison 2022, denn hier zeigt Nicolai das Eboxx Ultra – ein E-Bike, oder eher, E-Motorrad mit viel Technik, großem Akku, hohem Gewicht und massiver Leistung. Wir haben mit Kalle Nicolai im Video über das Nicola Eboxx Ultra gesprochen.
EMTB Tech At The IAA Show ..
[youtube]7kiQCVkluow[/youtube]
We've been invited to the IAA Show in Munich, historically one of the biggest motor shows in Europe. But today we're not here to talk about cars, we're here to look over one of the biggest collections of new E-Mountain Bike Tech. From boundary-breaking integration to purpose-built suspension and electrics that will make your mind boggle, the halls at the IAA are bursting with interesting looks into the future...
Strange thing, is that so far they have no PAS planned for the Pinion Option.
Not sure if it is an oversight, or they think that pedaling a 60kg bike without Pedal assist is fine....
