DC to DC Multi-Purpose Voltage Converter $14.98
Lyen
Re: DC to DC Multi-Purpose Voltage Converter $14.98
Post by Lyen » May 12, 2011 3:51 am
ChinaPhil wrote:I use an iPhone 4 for navigation and have been trying to power / charge it with one of these converters set at 5V and powering a USB charging cable - cannot get it to work, any suggestions?
Phil
Hi Phil,
The iPhone 4 needs to sense voltage on the USB data pins. Its wall charger definitely outputs 2V & 2.7V on the two USB data lines, as well as the 5V on the USB Pwr pin.
If you have some electronics experience, follow the instructions below to construct your own charging adapter cable.
If you never soldered before, then don’t try. If you connect things wrong there is the potential risk of damaging the phone.
As usual, if you do make your own cable, you do it entirely at your own risk. If your phone dies, do not blame me. Mine is working fine, so the procedure does work if done properly.
Instructions:
READ ALL STEPS BEFORE STARTING WORK!
The USB has 4 wires:
Red-5V, White-Data, Green-Data, Black-Gnd.
They are numbered Pin1 to Pin4, in the same order, ie Red =Pin1.
1. Cut the USB EXTENSION lead, trim both pieces to a shorter size, but make sure you leave enough length to work with !
2. Cut off the foil-shielding on both pieces, twist the braided wire shielding into a single “wire” on each piece.
3. On the female piece of the lead solder resistors as follows:
Pin1—R1—Pin2—R2—Pin3—R3—Pin4—Shield
R1=2K2; R2=680; R3=2K2
4. Trim resistor legs as short as possible. Make sure you put some insulating tape between all the exposed bits of wire and resistor legs. You want to pack the resistors as tight as you can, and you do not want any metal bits touching!
5. On the male end of the lead, cut off the white and green wires; you DO NOT want to connect them to anything! If they were connected it would feed power back to the car adapter, which could conceivably have those pins grounded as they’re usually not used (hence the iPhone 4 charging problem).
Even worse, you might one day accidentally plug this new DIY adapter cable into a USB port on your PC, and it may take offense at having power coming in on the data lines.
So cut the green and white wires on the male end.
6. Cut a piece of large-diameter heat-shrink and slide it over the male piece of the lead. It should be long enough to later cover the area where the resistors are. Hence the male end of the lead needs to be at least as long as the length of heat-shrink you need!
7. Join the two pieces of lead by soldering the male red wire to the female red, male black to female black, the shields to the blacks.
8. Carefully compact all the resistors together, ensuring there is insulation between adjacent metal parts, and that nothing comes lose. You might need to think about how you want to pack the resistors BEFORE YOU SOLDER!
Then slide the heat-shrink over the resistor assembly until it overlaps the untouched part of the the USB cable on both sides of the resistor assembly.
Heat up heat-shrink to make it grip.
* If the assembly is bigger than the heat-shrink you chose, remove heat-shrink and tightly wrap the entire cable with electrical tape instead. Done!
9. WAIT! DO NOT CONNECT iPhone, yet!!!!
10. Connect your new adapter cable to the DC-DC converter.
With a multimeter (and thin probes, or bit of stiff wire soldered to the probe tip) measure the voltages you get on the female end of your new adapter cable.
Put the Gnd-Probe on the plug shield, and be extremely careful with the other probe not to touch both the shield and a pin at the same time.
You should have ~5V on Pin1, ~2.8V Pin2, ~2V Pin3, 0V Pin4.
If you do, Congratulations, you now have a USB adaptor cable that will turn any plain USB voltage adaptor into an iPhone 4 charger.
If you have no voltage, you might have forgotten to solder the shield to the black. Put Gnd-probe on Gnd-Pin4, then measure all other pins and shield. If the pins measure ok, and the shield is still 0V, you are probably ok too.
All other results, and you need to re-do your cable!
11. IF YOUR CABLE MEASURES OK, at your own risk (!) you can now connect your iPhone to the adapter cable, and then into the DC-DC converter. It should now charge.
Note: Apple states that the iPhone should only be connected to authorised chargers,etc. Using the DIY adapter cable could potentially void your warranty.
Please be careful though :
When cutting an USB extention cable : Do not rely on the wire colours !!!
Mine had red colour connected to pin2, black wire connected to Pin 3, green (5V) connected to pin 1 and white connected to Pin4 (GND)
Measure twice !
Regards,
Lyen
Items For Sale
Please sign up here and donate your marrow to save life.
wojtek
Post by wojtek » May 12, 2011 4:13 am
WOW Lyen, that is impressive!!!
WIRES AND CONNECTORS
https://endless-sphere.com/forums/vi ... 31&t=30176
https://endless-sphere.com/forums/viewto ... 31&t=32244
KMX Cobra with Xlyte 5403
Go-One Evo with Cromotor
BATMOBILE - Astro 3220 / Nuvinci in progress
Giant CRS Alliance - yes, just pushbike! frock you..
3Element Espire - SOLD
Custom built Specialized BigHit with BBS02 - SOLD
Velokraft e-VK3 SOLD
Steintrike Mungo Sport HS3540-SOLD
Scorpion FS HS3540-SOLD
Kona Dawg BMC v2-SOLD
ChinaPhil
Post by ChinaPhil » May 12, 2011 6:48 am
Phil
Hi Phil,
Instructions:
10. Connect your new adapter cable to a car USB adapter.
11. IF YOUR CABLE MEASURES OK, at your own risk (!) you can now connect your iPhone to the adapter cable, and then into the car adapter. It should now charge.
Measure twice !
Regards,
Lyen
Lyen, thank you. I will give this a go after I have been resistor shopping. Hope that your instructions help others.
Phil
Cyclone 500W, SRAM DualDrive, hardtail; 8s Lithium Iron Phosphate, 38A
Cellman 350W geared hubs, 2WD, hardtail; 12s Lithium Cobalt Oxide, 2 x 17A
Cellman 500W Mac rear geared hub (upgraded gears), full suspension; 12s Lithium Cobalt Oxide, 59A
NeilP
Post by NeilP » May 19, 2011 9:23 pm
ambroseliao wrote:I'm wondering how clean (ripple) the DC voltages are from those small units? Do you have a oscilloscope by any chance? :?:
Ambrose
I did think about going down to a mates to try a scope on the output of the small SMPU's that I got from th dump and ran at 84 v or less from my bikes pack,and have not got round to it yet, but it has occurred to me that , even if he did, the results would be meaningless to you unless you had the exact same model power supply.
As far as I understand, since these are switched mode units, the input is going to have absolutely no bearing on the smoothness of the output, this is solely going to be a factor of the design of that particular supply, so any results I may find from the SMPSU's I have would be different for any supplies you find.
I may still go ahead and try and see the chap, and give it a try, just out of curiosity now, but I do not thing it will produce any useful information.
As for going below 84 volts...not sure what voltage I initially tried this out at, when I first tried running one of them off DC, but it would not have been a fully charged pack in any case...it would have at least been down to about 75 v by the time I had got to the farm workshop, where I do all my bike building
Neil
:) Only Irish coffee provides in a glass all four essential food groups: alcohol, caffeine, sugar, and fat :)
ChinaPhil
Post by ChinaPhil » May 19, 2011 10:10 pm
Confirming that Lyen's iPhone charging instructions work, thank you once again.
Phil
jonathanm
Post by jonathanm » Jul 10, 2011 11:30 pm
Want one of these to hook up my android phone for using speedict ebike.....payment sent!
ohzee
Post by ohzee » Sep 04, 2011 12:42 am
bought one - 2nd item I have bought from Lyen and his shipping is IMPRESSIVE to say the least.
Placing a 2nd order now.
geoff57
Post by geoff57 » Feb 16, 2012 5:42 am
Hi
Iphone charger.
For those that worry about getting the resistors correct there is an alternative, iphone car chargers with built in cables to a iphone for not a lot of cash, if opened up you will find that most if not all only have 2 wires coming down the cable, the resistor network is hardwired into the connector.this means that there is an alternative charger that requires no skill in getting resistors in the right order.
1: prepare the power in to the DC to DC converter in the same way as in the previous instructions. Connect Positive (60V to 8V) and ground to ground, if using a battery then fit it between the battery and V IN + if fitted on the V O + side then the DC to DC converter will be draining the battery all the time and if lithium with no LVC protection the battery could well end up discharged beyond repair.
2: you now have the Converter connected to a power supply (battery or mains PSU), take a multimeter put it over V O + and V O - turn the screw pot untill the meter reads 5.1V. Now disconnect the power supply and get ready to do the rest of the soldering.
3: check which is the positive and negative wire in the charging cable you have, (if there are more than 2 wires the cable is not a charging cable but a data cable) most probably the wires will be Red and Black but don't rely on the colors.
4: once identified solder the lead to the V O+ and V O - positive and negative respectively.
5: the output wires are probably very thin and only PVC insulated, for the wires strength and insulation cover the 2 wires with heat shrink to where the wires are striped, on the connection either use heat shrink if it is possable or if on a circuit board use silicone or epoxy glue don't use heat melt glue as when in use the converter gets hot.
6: put the whole thing into a small case plastic or metal, the heat from the converter will not be enough to melt a plastic one( it has never melted mine anyway ) you just have an input wire an output wire and an optional switch on the box.
I made my charging unit soon after this thread started so that I could charge my iPad from a LiPo battery pack the converter gets very hot but I have had no problems when charging my iphone it charges like its on steroids.
This build is in effect the same as was described above it just avoids working out where to put the resistors, infant the resistors are not needed.
Geoff
hillzofvalp
Post by hillzofvalp » Feb 19, 2012 11:48 am
For those of u who have a 12-24V auxiliary supply, many of the car USB ports regulate this range. I got mine for free at a job fair booth, but I'm sure you could get one for less than $5. It's only 700mA though... I can't remember what the highest the iPhone can take
nonlineartom
Post by nonlineartom » Feb 19, 2012 4:16 pm
Personally I just have the DCDC converter running at 12V and then use a cigarette lighter USB charger to charge the phone up. I know it's effectively 2 DCDC converters but it gives the iPhone power it's happy about and doesn't risk damaging the phone. I'm guessing it uses some kind of regulator built it. Doesn't add much bulk
Commuter bike: 10T MAC Schwinn Panther Beach Cruiser on 12S LiPo, super stealth hill eater
Forest trail eater: Crystalyte 5306 KMX Viper with 24" wheel. 100A controller 18S LiPo
Pocket rocket: 8T MAC e-BMX 18s LiPo. Missile for testing to destruction
Summer ride: 8T MAC Kona Joe MTB / chopper / beach cruiser hybrid bike. 24" wheels and a lot lot of style.
Respect and fear the ancient god LiPo and pray he is merciful.
gurshark
Post by gurshark » Dec 05, 2012 4:00 am
Sent payment for two at 12:55am on 12/5/12. The one I bought from cell man just died after a week of use, but this is so useful, I want to try again and hope the dead one was just defective. Stepping 48v down to 14 to power a 1 amp light.
gurshark
Post by gurshark » Dec 14, 2012 11:17 am
FYI. Don't reverse the input polarity. That cap blew spectacularly last night.
Lyen, is the amount of heat the converter generates dependent on how much you are stepping down the voltage?
geoff57
Post by geoff57 » Dec 15, 2012 3:38 am
Hi
I'm not lyen but I can answer that. First your comment on reverse polarity on the input, I did it once never again with me the chip exploded with one hell of a crack.
As for the heat generated it is linked to the wattage output not the ammount steped down, I use one to charge my iPad or iphone, set to 5.1V output weather I put a 3 cell lipo,5 cell or 10 cell the heat produced by the converter is a lot almost too hot to touch, by comparison I have a converter on my bike with the input side being my 12 cell battery pack just over 50V fresh off the charger, the output is to bank of Cree front led lights switchable from 1 to 4 . The output from the converter is set to 3V to give the LEDs long life, each pull 1W even with all 4 on the converter stays cool the same temp as when off where as the converter for the iphone which I am using as a sat nav is warm but not as hot as when charging the iphone/iPad from close to flat.
Hope that was not too long an answer to how much heat the converter produces and when.
Geoff
Merlin
Post by Merlin » Feb 20, 2013 12:04 pm
hello,
can someone maybe help me?
i recieved also one from lyen, but when i connect a 6S Lipo (25,4v) incoming there comes nothing out... 0,0v
i tried to screw in any way 360° and nothing comes out.
any idea? :?
yopappamon
Post by yopappamon » Feb 20, 2013 9:37 pm
Merlin wrote:hello,
any idea? :?
I believe it is a multi turn potentiometer. Verify that you are putting the power in the input, and that positive and negative are correct. Then turn the screw several turns one way, if nothing, then go the other.
Doctorbass
Post by Doctorbass » Feb 20, 2013 10:33 pm
Bought 2
Thanks Lyen!
Doc
CURRENT PROJECT: 2WD duo MXUS/Max-E ebike 32kW
https://endless-sphere.com/forums/viewto ... =3&t=65764
-Fastest speed record 117 km/h on flat
-Fastest 1/4 mile@ 114km/h on flat and 16.316 sec
113kmh Gianthttp://www.evalbum.com/3406
Mongoosehttp://www.evalbum.com/1947
YOUTUBE---https://m.youtube.com/user/Doctorbasss
I speak FRENCH and english
Merlin
Post by Merlin » Feb 21, 2013 3:52 am
thx, will try it :|
Merlin
Post by Merlin » Feb 28, 2013 5:30 pm
have tried....unbelivable....i have to turn 20-30 times to increase voltages....
but below 7,5 it goes straight "off" and there comes 0 volt.
Thats not cool because i want to use 5v to charge PDA/Handy/Navi
kudos
Post by kudos » May 30, 2013 8:09 am
I bought one of these from Lyen, I'd like to see pictures of how people have connected wires to these.
It's a bit of an awkward shape with the pins sticking out of the back.
I'm going to use it to step down to 12V then use a second adapter to charge my iPhone. Or maybe just down to 5V direct.
Kudos
Build 1A Gary Fisher Wahoo Hardtail : Crystalyte HS3540 40A 49V : 31mph
Build 1B Gary Fisher Wahoo Hardtail : Mac 10T 30A 49V : 27mph
Build 1C Gary Fisher Wahoo Hardtail : Crystalyte HS3540 40A 82V :
Build 2 Mountain Cycle Fury FS : Mac 8T 40A 57V : Scrapped
Build 3 GT LTS FS : Mac 10T 30A 49V
Build 4 EEB : Mac 8T 40A - In Progress
opperpanter
Post by opperpanter » Dec 21, 2014 5:14 am
geoff57 wrote:Hi
Geoff
Anybody ever found out the efficiency of these converters? If they are linear, they won't be very efficient?
Dougt
Post by Dougt » Dec 21, 2014 10:25 am
opperpanter wrote: Anybody ever found out the efficiency of these converters? If they are linear, they won't be very efficient?
I don't know particulars about this model, but looking at the pic and capability, it is certainly some sort of switching design. Efficiency is usually 80-90% for most dc-dc converters.
opperpanter
Post by opperpanter » Dec 21, 2014 10:50 am
Yeah I was in doubt because most switching converters i found on google have a lot more pins and require extra components. Might be already inside this 'box'?
opperpanter
Post by opperpanter » Dec 21, 2014 2:44 pm
Are you saying it's *identical* to that LM2596HVS, or *similar*?
LM2596HVS seems to be good only up to 53V?
Do you have experience up to 60V (14S)?
EDIT: hmmm sometimes it's stated as max 60V input, but only 2A out. 3A only with heatsink. And always around 6$
DanGT86
Post by DanGT86 » Dec 22, 2014 2:26 am
Kiriakos GR wrote:It is unimaginable to me that so many people here got scammed by some one selling 1$ circuit for 15$ ?? :x
http://www.ittsb.eu/forum/index.php?topic=965.0
Electronics are commonly sold for more than the cost of their components. Whether you consider it a finders fee for sourcing a useful device or just paying Lyen $15 to answer an email then pack and ship something, its a fair price. If you look at the experience level of people that bought this converter its obvious that Lyen is not scamming ignorant beginners.
Lyen has been a valued and trusted member of this forum for a long time. He has provided hundreds or possibly thousands of custom controllers to members of this forum for less money than you would pay for an hour of consulting from an engineering company. Providing affordable made to order products to home bike builders has accelerated the evolution of ebikes in general.
I'm not trying to sound like a Lyen advertisement but I feel the need to defend an honest vendor. I think I speak for a majority on this forum when I say I find it "unimaginable" that anyone would suggest Lyen is guilty of scamming.
rowbiker
Post by rowbiker » Dec 22, 2014 10:38 am
Agreed. I have purchased multiple items from Ed (Lyen), including this DC converter being discussed, and have been extremely satisfied with all my transactions with Ed.
After doing considerable online research about the LM2596 family of DC-to-DC converters, I have found what all ES veterans already know. When it comes to products with multiple sources, "your mileage may vary" (YMMV) always applies. I've purchased a variety of these converters, many of them directly from China, and one in kit form from a US supplier. I've been lucky so far by not blowing anything up, even the "cheap" (several dollar) units from China, but I also haven't "pushed" any units very far. Kiriakos has obtained some valuable additional experience with these units, particularly relating to driving incandescent (filament based) bulb loads. I recommend visiting his site, following the link in his post.
I'm still looking, as are other EV members, for good DC converters for use with higher voltage (above 48 nominal voltage battery packs). I know that there is a "HV" version of the LM2596 chip, but it's not clear which of the many modules being advertised using that version of the chip actually use appropriate versions of input and output capacitors. If Lyen, or another ES member for that matter, actually bought a bunch of these, tested them, found they worked as advertised, I would gladly pay (again) the very modest markup for being spared the time, effort, and risk of buying an unknown product from an unknown vendor. As always, YMMV, but I've benefitted greatly from all of these posts!
