Mongoose Salvo, GNG 1.1 build (in progress)
Overclocker   10 kW
Post by Overclocker » Nov 30 2014 10:57am
The Mongoose Salvo (size L) was chosen because 1) good price, 2) huge triangle
The GNG in my hotel room in Hong Kong after meeting up with Jon Chan's dad. Very nice guy, he even took me to a hilltop with a good view :D
Unfortunately in stock form it's probably a belt shredder so I decided to tweak the design a bit. I also got Lightningrod's upper sheets:
Anti seize on parts that I'll probably have to disassemble later on
12s8p samsung ICR18650-26F bonded together in groups of 8.
test fitting...
in progress... suggestions/wisdom most welcome
Overclocker   10 kW
Re: Mongoose Salvo, GNG 1.1 build (in progress)
Post by Overclocker » Dec 22 2014 6:56am
sorry for the very slow progress...
pre-fluxed:
Wheazel   10 kW
Post by Wheazel » Jan 11 2015 9:53am
Looks good! Are those copperwires cell-level fuses?
What kind of flux do you use?
Overclocker   10 kW
Post by Overclocker » Jan 17 2015 10:14am
Wheazel wrote:Looks good! Are those copperwires cell-level fuses?
didn't design them to be fuses. 1.0mm diameter btw.
so here it is mounted to a hardtail (for now). after 300kms there IS some noticeable wear on the belt:
jdevo2004   100 W
Post by jdevo2004 » Jan 17 2015 11:48am
I like your belt and chain mods.
Overclocker   10 kW
Post by Overclocker » Jan 25 2015 7:44am
jdevo2004 wrote:I like your belt and chain mods.
thanks but i'm not sure if the mods did any good LOL. here's the belt after 500kms:
Overclocker   10 kW
Post by Overclocker » Apr 08 2015 11:03pm
1000km belt life not good enough. time to do chain conversion...
meelis11   100 W
Post by meelis11 » Apr 09 2015 3:19pm
Did you file off sharp edges of both toothwheels? Probably not, do it.
I did and my belt tooths look like new after 900km. Max they were lasted was about 800-900km but breaking belt is due to stock design (wrapping belt over too small tensioner and probably breaking/weakening fibers inside belt). I now modded that too - replaced belt with shorter version 260mm length instead of stock 275mm
Nobuo   10 kW
Post by Nobuo » Apr 09 2015 3:28pm
Very very good soldering skills.
Are you using BMS?
* Lithium + Air = Fire * <-----> ** Lithium + Chemical-Additives + Air = ZERO Fire **
<Battery and EV works>
https://facebook.com/evmadrid1
<Battery building resources>
http://www.endless-sphere.com/forums/vi ... 14&t=68005
r3volved   100 kW
Post by r3volved » Apr 09 2015 4:16pm
meelis11 wrote:Did you file off sharp edges of both toothwheels? Probably not, do it.
Do you have a picture of your belt side? What else did you have to mod to fit the 260mm?
meelis11   100 W
Post by meelis11 » Apr 10 2015 5:12pm
I started my build thread today and added belt mod post there too :)
http://endless-sphere.com/forums/viewto ... 3#p1032663
(it was 475mm length, not 275mm - fixed in my thread)
Overclocker   10 kW
Post by Overclocker » Apr 10 2015 10:24pm
yep i did. the motor pulley was particularly time-consuming...
i'm also using a much larger backside idler. less back-bending
btw i do a lot of off-roading that's why everything looks dusty LOL. some of my climbs are enough to stall the motor. probably contributed to the belt's early demise.
meelis11   100 W
Post by meelis11 » Apr 14 2015 5:11am
It still looks like some of teeth are still sharp. Maybe you missed some sharp edges?
But id you are almost 1000km mark and belt has not broken - so less backbending must help :) Did you mod it immediately (no riding in stock conf)?
btw, what is your idler diameter?
Overclocker   10 kW
Post by Overclocker » Apr 14 2015 6:41am
Nobuo wrote:Very very good soldering skills.
Are you using BMS?
i would have to do w/ soldering for now. might get a spot welder in the future
no BMS. discharged as 12s but "folded" and charged as 6s w/ iCharger 106b+
Overclocker   10 kW
Post by Overclocker » Apr 14 2015 6:48am
30mm
yep i modded immediately
anyway i'm giving up on the belt. i've just hacked the 80t belt pulley and turned it into a "spider" for the new 80T #25 sprocket. motor sprocket is 11T. should give decent reduction. pictures coming soon
PS i believe the only way to make the belt system work is to have at least an 18T motor pulley. but this means a very high tooth count driven pulley if you want a good amount of reduction.
meelis11   100 W
Post by meelis11 » Apr 14 2015 7:44am
Why you give up - did you brake your belt or does belt skip?
Overclocker   10 kW
Post by Overclocker » Apr 14 2015 8:15am
meelis11 wrote:Why you give up - did you brake your belt or does belt skip?
while out on a ride the belt started giving out a screeching / tearing sound so i immediately headed home since i didn't want to have to pedal back home :evil: some teeth on the belt had already partially broken off
anyway here's what remains of the 80t belt pulley
r3volved   100 kW
Post by r3volved » Apr 19 2015 12:18pm
Did you just lathe down that belt sprocket?
Overclocker   10 kW
Post by Overclocker » Apr 19 2015 1:01pm
r3volved wrote:Did you just lathe down that belt sprocket?
angle grinder. while motor is running
Overclocker   10 kW
Post by Overclocker » Apr 20 2015 1:00am
chain conversion done. 80T and 11T #25 sprockets from electricscooterparts.com
Overclocker   10 kW
Post by Overclocker » May 27 2015 1:01am
now enclosed the primary reduction
shall be finalizing the battery box soon
Hummina Shadeeba   1 MW
Post by Hummina Shadeeba » Mar 08 2016 2:46pm
Maybe just get a better material belt. Is it Kevlar or just fiberglass?
Overclocker   10 kW
Post by Overclocker » Mar 09 2016 10:24am
Hummina Shadeeba wrote:Maybe just get a better material belt. Is it Kevlar or just fiberglass?
oh i'm done w/ belts :) the consensus in the huge GNG thread is that the stock motor pulley is poorly designed and has too few teeth
