s900 display - compatable replacement
vbebike   1 µW
Post by vbebike » Jun 26 2019 9:18am
I have a s900 display that is not functioning.. Can anyone recommend a compatible display. Also, do all displays have the same outputs.. the controller is a suzhou tongshen bicycle co 48v LCO4822C1H-TS26.. thanks for any help out there
slcpunk   10 µW
10 µW
Re: s900 display - compatable replacement
Post by slcpunk » Jul 26 2019 10:11am
There are people here that know way more than me, but since no one has replied, I'll pass along what I can think of.
It should be easy to just get another SW900. You might be inclined to get something else, but I think the chances of compatibility issues with your controller will go up a bunch.
Check Amazon and Ebay for SW900 LCD displays. Look at the connections and see if they match up with the ones on your controller.
that's what I would do. That is a fairly standard display, so it should be easy to replace.
A few quick links ( I have no idea if these have the same connections as yours, but check it out )
https://www.amazon.com/EBIKELING-Displa ... r=8-2&th=1
https://www.amazon.com/Intelligent-Cont ... 180&sr=8-3
DAND214   1 GW
1 GW
Location: About 1200 miles south of Chicago, in sunny/rainny Port Richey, Florida!
Post by DAND214 » Jul 26 2019 11:15am
Isn't a shame that a display costs as much or more, than the controller.
Dan
