Making a small pack 5S24P
leffex   1 kW
Post by leffex » Jul 03 2019 1:59pm
Just some photos of my small pack I want to share
How to assemble: Soldering
exactly how: tesla style. One side is fused with wire capable of 5-15a max(deciding), the other more robust fastened with thicker copper wire. Both sides uses twined copper wire as busbar. Hot glue gun to make pack sturdier and also additional plastic and soft material inbetwen + manually activated fan cooling.
Numbers of cells 5s24p
Cell type: Used tested Panasonic 18650PF
Usage: max 150A, 6,25 per cell
Total wh: 1221 (18,5Vx66AH)
Salestech in an ebike store
leffex   1 kW
Re: Making a small pack 5S24P
Post by leffex » Aug 24 2019 9:59am
Work table:
1 of 5 pieces
5 pieces fits inside one
Finished pack:
Module pack stats:
18,5cm*7,5cm*30cm = 4162cm^3 Volume = 4,162 L
5s*24p 2,9PF nominal 1221wh
1221wh / 4,162 L = 293wh/L
Next mission, what to do. Test pack for voltage drop at set load and monitor temperature
flippy   1 MW
Post by flippy » Aug 27 2019 5:42am
what cell holders did you use?
Lithium beats liquid dinosaurs.
leffex   1 kW
Post by leffex » Aug 27 2019 12:54pm
Something like cylindrical or 6squared plastic cell holders. The ones I used was 1x4p so I added them together and broke some to make smaller pieces were needed
These are very alike but not the ones I have
https://vruzend.com/product/hexagonal-1 ... rs-3-cell/
I first thought not of using any but then its pretty much better in all ways to use plastic cell holders than not to
leffex   1 kW
Post by leffex » Sep 14 2019 1:34pm
Another pack mocked up for photos:
Module 2 pack stats:
5s*26p 26F nominal 1196wh
1196wh / 4,162 L = 287wh/L
Power rating 26p x 5,2a = 135,2A
I'm thinking about what these modules can give in relation to power. I don't want the cells to get warm and they are only 26p for a normal usage of 1,7kw/h or 65w / km. That means the power from the full battery will be average 1700w used per hour and 1/4th of the energy will come from module 2 consisting of 1196wh module which is 1196/4 = 299wh. That makes out to average load of 1700w/90v = 19a shared load for 26 parallel cells. hmmm it will work. easy :D
flippy   1 MW
Post by flippy » Sep 14 2019 4:08pm
i found the cell holders on ali: https://www.aliexpress.com/item/32919687859.html
i have orderd a set and see if they can take self-destructing cells without catching fire or melt too bad that it can lead to a catastrofic ending for a battery. that is going to be a fun -but smelly- afternoon.
cwah   10 GW
Post by cwah » Sep 15 2019 1:29pm
How do you find the right size box?
leffex   1 kW
Post by leffex » Sep 16 2019 2:32pm
I searched for a box that fits the space I want to use and put my battery into. I can put 4 of them into my space so I started with ordering 2 boxes to try.
Ordered another two from here:
https://www.aliexpress.com/item/3300438 ... 03GYq&mp=1
cwah wrote:
Sep 15 2019 1:29pm
Also to find out how big your box or pack should be try to decide its Voltage and AH or how any cells you need.
each cell is 1,8cm wide and 6,5cm in height and a little wider with a plastic cell holder depending if you use one or not . If a box is 20cm in width and 20cm length and 8,5cm in height then 20/1,8=11,11 cells can fit on one side and the other is the same so another 11 (because we can't split cells) Maximum potential is 11x11 cells in that box so 121 cells. If you pack them as tight they can be maybe a few more cells may find its way into the pack.
First I was thinking of making a box from building material. Plastic squared tubes but easiest way of doing it is to get a box that is in perfect size already and go from there even though it may cost you some.
cwah   10 GW
Post by cwah » Sep 16 2019 4:42pm
Oh I see. These are battery box. But not size I need unfortunately.
leffex   1 kW
Post by leffex » Sep 19 2019 10:48am
Just tested module one 5s24p with panasonic PF cells.
They have a delta voltage between cells in the module below 0,11v at 3,95v and 150a load. Maybe I didn't balance them so it could even be lower. (Delta voltage between cells at no load was 0,005v)
However. Total pack voltage at testing was 19,75v or 3,95v per cell. At a load test of 150a or 100-150A the voltage sag came to a maximum of 1,91v. That is almost 10% voltage sag at a very high load.
Estimated voltage sag levels at lower amperage levels:
10a load = 0,13
25a load= 0,32
40a load= 0,51
50a load=0,63
75a load=0,95
100a load=1,27
Estimated average usage 50a
Pack module temperatures. No difference at first test for 5 minutes and 2km. A slight difference in temperature outside the module box of 3 Celsius degrees higher than surrounding temperature after second run made 10 minutes later.
End voltage of each cell was 3,895 with delta between cells at no load at 0,006
*edit added photo - 20190920
Next test will be on Saturday 21st of September and 8km in distance times two.
flippy   1 MW
Post by flippy » Sep 19 2019 11:14am
you need way more copper on your bus if you wat better performance. same goes for the inbalance during load. you need way more beefy series connections.
leffex   1 kW
Post by leffex » Sep 19 2019 5:37pm
flippy wrote:
Sep 19 2019 11:14am
What happends when I double or tripple the bus bars? Better performance...
Pack module cable are short 10awg 20cm and battery cables are oversize awg 2, 25mmsq^2 to the controller.
From each cell group there are at least 4 copper wires going to the next cell group apart from the copper connecting all cells of course as seen in the pictures. The copper awg I would estimate to be at least 12awg
Thanks for your input and help
999zip999   100 GW
Post by 999zip999 » Sep 19 2019 6:42pm
Hey double and see. Or 8 please. This should give good info.
BlueSeas   10 W
Post by BlueSeas » Sep 19 2019 7:21pm
Let's crunch a few round numbers. This isn't intended to be exact. 24P is 24 * 3 Ah for a 72 Ah cell. 150A discharge is slightly greater than 2C discharge rate. Let's look at the battery specs:
Now I've never seen a chart using "lt", presumably load test. I'm going to assume lt = C, which is capacity since it fits the graph for a max 10A or slightly greater than 3C discharge. So the cell specs call for a .22V voltage drop between .2C and 2C rate. For 5S, that's 1.1V.
Interpolating the test results for .2C load, .2*72 = 14A. The observed pack voltage drop at 14A, about .2V, so the perfect world drop is 1.1+.2=1.3V versus the observed 1.9V, a .6V delta.
Plus it's really greater than 2C due to rounding. The factory data for a single cell is probably impossible to achieve in a 100 cell configuration. I'd say there is little room for improvement. I'd be pretty satisfied.
leffex   1 kW
Post by leffex » Sep 20 2019 3:35am
BlueSeas wrote:
Sep 19 2019 7:21pm
...So the cell specs call for a .22V voltage drop between .2C and 2C rate. For 5S, that's 1.1V.
That was interesting facts to know!
I did a longer test drive today. Two times 8 km. Power used was about an hour of charge of 95vx5.5a so I used about 522wh of energy. 32wh/km.
Pack module 1 was not hot or anything after "feeling it". On this test drive however I did put the voltage meter on ONE of my 500 cycles RC-lipo multistar 12c rated 4s1p10AH connected in 2p as 20AH. Delta measured from it was 2,16v. They can't be compared directly because of 5 series vs 4 series but in this case the PF is the better of the two for reasons of course.
measured max delta voltage at 150a load
PF, 0,38v delta / cells (66ah)
RC, 0,54v delta / cells (20ah)
calculated estimates:
RC, 0,27v delta / cells (40ah)
RC, 0,38v delta / cells (28,5ah)
leffex   1 kW
Post by leffex » Oct 31 2019 10:25am
Making another pack. This one has 25p because the cells should measure up to 66ah and so one more is needed in each group beacuse of lower cell capacity.
Difference with this module is that I'm trying more copper in the series connections. 8 instead of 4-5
leffex   1 kW
Post by leffex » Mar 10 2020 3:13pm
At last a new year and time to use those batteries.
I have in total build three of these batteries and here they are in all their glory.
The first was a 24p which was then changed to 25p for the two last packs. There's a 2s Sanyo Ga 20p ready to start its life soon in the left corner as it get connected. Other than that it will be interesting to se how this will work. First version module has 5x 12awg twined copper wire between each series connection and the newer batteries have 8x.
