interrupted charging, top up vs continous to full
tomkut   100 µW
100 µW
Post by tomkut » Sep 07 2019 7:53am
I noticed something strange with my battery and was wondering whether this is specific to mine.
When I charge continuously to full, the bike has significantly more power for the first few miles.
When I interrupt the charging (say divide into about an hour periods) but still to full, the motor does not have the same kick, feels like 10miles from the first scenario.
Is it normal? Everywhere I read that interrupting the charging does not make any difference, but it does with my battery/charger.
My batt : 48V 14.5Ah Hairon cells SAMSUNG INR18650-29E, standard charger
wineboyrider   100 MW
Re: interrupted charging, top up vs continous to full
Post by wineboyrider » Sep 07 2019 8:33am
No battery expert for sure, but my old lifepo4 pack was always more stronger through discharge than lipo.
wineboyrider   100 MW
Post by wineboyrider » Sep 07 2019 8:36am
One data sheet I looked up shows the cell to be .2c ? That's a pretty weak discharge for battery. So lower c rate cells sag more than higher c rate cells.
Alan B   100 GW
Post by Alan B » Sep 07 2019 9:03am
Many chargers won't start charging if the battery is close to full. So interrupting charging may prevent the final charging segment.
