I need help, as i dont have anywhere to ask, and no one to help me
E-HP   1 MW
Re: I need help, as i dont have anywhere to ask, and no one to help me
Post by E-HP » Jul 30 2020 10:45pm
Davidcroatia wrote:
Jul 30 2020 10:32pm
Davidcroatia wrote:
Jul 13 2020 1:58pm
Hello, this is my first ebike build and i dont have a clue what could be rhe problem, im adding throttle but almost nothing helps . https://imgur.com/a/4zvbfoy
https://youtu.be/lXGZ-mxtYY8
https://youtu.be/feRsy8ailhM
Nothing here doesnt give away i dont posses a lcd screen except the whole video that i shot, 40% of the video happens on an lcd i own
Nice videos of an LCD screen and controller. With that detailed information, someone should be able to help. :thumb:
Sorry, I didn't click on your youtube link, since it looked a little fishy with the address being "youtu.be". We get tested a lot on that for work (anti-phishing).
You might want to try reading the top two stickies at the top of this forum. They are short, but will help you get your answers a lot faster. Following this process seems to work for me, it's inside one of the stickies: viewtopic.php?f=3&t=66302&start=25#p1485445
Balmorhea   100 kW
Post by Balmorhea » Jul 31 2020 2:48am
Youtu.be is the domain you get when you copy a link from YouTube.
___________
Finish Reconstruction.
Davidcroatia   100 W
Post by Davidcroatia » Jul 31 2020 4:04am
Thanks. Well i dont even know the model. I just know it gets real hot
Davidcroatia   100 W
Post by Davidcroatia » Jul 31 2020 4:39am
My lcd is kt lcd 3, my exact controller is in the subject and i drive 1000w qs motor. I connect the charger to it and it just goes charging, not charging, and after few minutes usb cable gets reallly hot :)
E-HP   1 MW
Post by E-HP » Jul 31 2020 10:55am
Balmorhea wrote:
Jul 31 2020 2:48am
Good to know. I guess most people embed the link so you never see that part.
Davidcroatia wrote:
Jul 31 2020 4:39am
Maybe it's your phone. What model is it? Per Kunteng's website, the port is only good for 1A, so it would be unusual for the cable to get heated up like that unless there's a direct short or your phone is pulling too much current. Check the voltage on the USB port to see what's going on.
http://www.szktdz.com/en/news_show.php?article_id=434
HK12K   10 kW
Post by HK12K » Aug 01 2020 2:01pm
markz wrote:
Jul 26 2020 1:34pm
Balmorhea wrote:
Jul 26 2020 1:27pm
markz wrote:
Jul 26 2020 1:22pm
Do you use your H-brake with its one wire?
I don't use any kind of electrical brake. My torque arm only works for forward drive. And my rim brakes are really good.
Yeah I prefer rim brakes myself, can't beat $4 pads! Cheapest disc pads are $21 cdn here, such a ripoff.
I forget what I actually paid, but Nukeproof pads from chain reaction were very budget friendly and do the job well.
HK12K   10 kW
Post by HK12K » Aug 01 2020 2:03pm
Balmorhea wrote:
Jul 26 2020 1:55pm
Good V-brakes cost $20 brand new, and don't need to be bled like used hydraulics. Where I live, a single brake bleed costs more than $30 by itself.
I got a bleed kit from Aliexpress for less than $10. Can recommend, though I bled mine before it arrived without even needing it. Just popped the cap and kept dripping and squeezing.
HK12K   10 kW
Post by HK12K » Aug 01 2020 2:07pm
OP: the phone is probably attempting to draw more amperage than the lcd can provide. Get a portable usb power bank for phone charging.
markz   100 GW
Post by markz » Aug 01 2020 8:25pm
HK12K wrote:
Aug 01 2020 2:07pm
There are 2 or 3 USB protocols for charging and stuff that require different amperes, not sure what each one is, maybe 1A (original version) and 3A (newer version) or something, completely guessing on my part specific Amps. A simple web search should reveal.
Balmorhea   100 kW
Post by Balmorhea » Aug 01 2020 9:12pm
HK12K wrote:
Aug 01 2020 2:03pm
Balmorhea wrote:
Jul 26 2020 1:55pm
Yep. It's a great way to oil and ruin your brake pads. On the other hand, brake pads have never been destroyed by coming into brief contact with a cable.
___________
HK12K   10 kW
Post by HK12K » Aug 01 2020 10:54pm
Uh, I bled from the top side, so no chance of that happening. Didn't lose a drop. You might come in contact with a tree should that cable snap though.
Balmorhea   100 kW
Post by Balmorhea » Aug 02 2020 2:25am
HK12K wrote:
Aug 01 2020 10:54pm
Or if the hose gets the slightest damage.
___________
HK12K   10 kW
Post by HK12K » Aug 02 2020 10:17am
Cables are fine, but there was a reason every production motorcycle switched to hydraulic decades ago. They're better.
But this was never about one vs the other. It was about being competent enough to not give someone else $30 to do a simple job for you.
markz   100 GW
Post by markz » Aug 02 2020 1:07pm
Here we go again comparing bicycles to motorcycles.
20lbs vs 300lbs (15X)
15mph vs 60mph (4X)
HK12K   10 kW
Post by HK12K » Aug 02 2020 7:47pm
Speak for yourself. Mike bike weighs 100 and will do 100, lol. Not to mention your 15lb bike weighs how much after you throw your leg over the saddle again? More. Quite a bit more. Now point it downhill.
All of that aside though, hydros offer considerably better feel and modulation and significantly more stopping power overall. But again it was never about one vs the other, it was about being able to do the most basic of maintenance yourself.
Davidcroatia   100 W
Post by Davidcroatia » Aug 05 2020 3:40pm
What do you buy for a battery cover to be waterproof? Upp battery producer doesnt have a waterproof battery cover so large for my battery. Mine is 24.5ah 91 cells hialong case dolphin i think
Davidcroatia   100 W
Post by Davidcroatia » Aug 10 2020 6:51am
My rear kranz has bad bearings, cassette adapter seems much betzer
Balmorhea   100 kW
Post by Balmorhea » Aug 12 2020 12:03pm
Thats the speed that the motor will try to turn, not the speed that the motor has enough power to reach. Using too fast a motor for the amount of power your controller and/or battery can supply is a rookie mistake.
Note that the performance data for those motors show the 1000w model producing 21 Nm of torque from 24 A of current (about 1000W), and the 1500W version producing 86 Nm of torque from 90A of current (about 2700W).
The 1500W motor is heavier, with more copper and wider magnets. It can produce more power without overheating. The “speed” of the motor is a result of the motor winding and how many volts you feed it. It does not result in you going that speed unless there is enough power available to do that.
___________
Davidcroatia   100 W
Post by Davidcroatia » Aug 12 2020 1:44pm
Lets say 6t winding is a good winding for start and stop, i mean it comes as a first option. So its good for a quick start stop all day, thats what i need. Then i use 48v 24.5ah battery with 40amp bms , i need speed up to 50km h , what would be the difference bezween 1000w and 1500 w ?
Balmorhea   100 kW
Post by Balmorhea » Aug 12 2020 2:29pm
Davidcroatia wrote:
Aug 12 2020 1:44pm
1500W is a little heavier and will heat up less under load. 50 km/h will take about 1300W at the wheel, so at least 1600W from the battery. That’s a better match for the 1500W motor in my opinion.
Don’t assume that the same winding will give the same RPM per volt or the same torque per amp, when applied to these two different motors. Those values will probably be different.
Your battery contains a little less than 1.2kWh of energy, if you run it completely down to exhaustion. You won’t get all day endurance from that, if you have lots of starts and stops and you want to go 50 km/h. Have a plan to recharge as you go, or have a second battery in rotation.
___________
Davidcroatia   100 W
Post by Davidcroatia » Aug 12 2020 4:32pm
I work in delivery of food , wolt, similar to glovo, i make appx 50km range
Davidcroatia   100 W
Post by Davidcroatia » Aug 19 2020 7:00am
https://youtu.be/yt78ZCLJ7V4 kranz died and has eaten the kranz adapter how to solve this? Distancer we are thining it
Balmorhea   100 kW
Post by Balmorhea » Aug 20 2020 4:02am
Davidcroatia wrote:
Aug 19 2020 7:00am
You stripped the freewheel thread? If so, you need to get a new motor side cover. There’s not a quick and easy fix for that.
___________
Davidcroatia   100 W
Post by Davidcroatia » Aug 20 2020 7:14pm
Its not so stripped , but its a little bit stripped, why it has stripped ? Thats why i need cassette adspter...
