EBC-A20 Battery discharge cycle life tester - SOLD
Darren2018   100 W
Post by Darren2018 » Jan 01 2021 5:17pm
EBC-A20 - £55 delivered within the UK - SOLD
20A discharge (85W max)
5A charge (18V 60W max)
Cycle testing via windows software.
Manufactures specifications:
Power supply mode: DC19V-20V, current above 3.5A
Voltage setting: 0.00-30.00V, minimum step 0.01V (maximum voltage is 18V when charging)
Current setting:
Discharge: 0.10-20.00A, minimum step 0.01A (automatic current limit when power exceeds limit)
Charging: 0.10-5.00A, minimum step 0.01A (maximum current depends on supply current)
Mode setting:
DSC-CC (constant current discharge): constant discharge current for testing battery capacity
DSC-CP (constant power): constant discharge power for simulating constant power equipment
CHG-CV (constant pressure charge): constant current and constant voltage charge, support lithium battery and lead acid
Automatic charge and discharge: support automatic "charge-discharge-charge" mode, test battery capacity
Voltage measurement:
0.000-4.500V (low pressure), accurate to 0.003V, error ±0.5%
4.50V-30.00V (high pressure), accurate to 0.01V, error ±0.5%
Current measurement: 0.10-20.00A, accurate to 0.01A, error ±0.5%
Capacity measurement:
Within 10Ah, resolution 0.001Ah
10Ah-100Ah, resolution 0.01Ah
Above 100Ah, resolution 0.1Ah
Wiring method: four-wire detection, voltage measurement and current channel separate wiring to ensure measurement accuracy
LCD display: test data of voltage, current, capacity, time, power, energy, etc.
Computer connection:
Dedicated USB to TTL serial cable (MiniUSB port, not ordinary USB cable)
Computer control, drawing curves, calibrating measurement benchmarks, upgrading device firmware, cycling charge and discharge, etc.
john61ct   100 GW
Re: EBC-A20 Battery discharge cycle life tester
Post by john61ct » Jan 01 2021 6:24pm
Price shipping to USA please?
Slowest boat is fine
Darren2018   100 W
Post by Darren2018 » Jan 01 2021 8:08pm
John wouldn't you be better off buying one from Aliexpress? Any potential duty or shipping would make it cheaper to buy from China.
john61ct   100 GW
Post by john61ct » Jan 01 2021 8:18pm
Not if you could get it here for say $20
Darren2018   100 W
Post by Darren2018 » Jan 01 2021 10:57pm
I have sent you a PM.
