Ebike with Lyen 18fet controller & HS3540 motor. Needs TLC.
Have extra parts that need a good home? Post it up here and see if anyone else is searching for what you are selling.
icekreme1002   1 W
1 W
Post by icekreme1002 » Mar 01 2021 1:10am
$500 ONO including charger, helmet and armour.
Pickup Parkinson, QLD 4115
Hi guys,
I loved this beast and enjoyed using it while at uni however, it has sat unused since around 2013 and I think it beyond time to let it go.
Here is a post I made explaining most of the build. viewtopic.php?t=32041
It was an 18s setup and includes a range of great quality parts. Everything worked as it should when i used it last.
It def needs a lot of TLC to get back to its glory but I hope at this price even the parts will be of use to someone.
If you have any questions or would like to come and inspect it please feel free to shout out :)
Edit: I should add there a plenty of little extras I am happy to throw in too.
There is a cable to program the controller
A 300mm bearing puller should you want to change the hub motor bearings,
A spare tyre and tube (same as front tyre)
an Avid service kit for the front hydraulic brakes
The lock switch for the reba shocks and pretty sure I have a shock pump somewhere too.
Basically anything I have specific to this build in the bike toolbox will be included too. Will add more as i find/think of it.
1st build - Norco Hardtail, 18s Lipo, HS3540, Lyen 18fet 45/120amps
http://endless-sphere.com/forums/viewto ... =6&t=32041
icekreme1002   1 W
1 W
Re: Ebike with Lyen 18fet controller & HS3540 motor. Needs TLC.
Post by icekreme1002 » Mar 29 2021 1:14am
Any interest? I thought it would have gone quickly at $500!
Lots of great parts there to use on another built or even rebuild this.
The charger alone has over $300 worth of PSU's.
Controller, motor and cycle analysis work as they should.
Feel free to come and take a look!
millzy555   100 W
Post by millzy555 » Mar 30 2021 12:48am
PM sent mate
