Best Mid-drive Motors in 2021
Grantmac   10 kW
Re: Best Mid-drive Motors in 2021
Post by Grantmac » Jun 27 2021 12:10pm
https://www.trial-bikes.com/en/bike-trials-cranks/
Trials cranks will do what you want while not needing to cut off the spider.
Actually it's been a while since I looked at trials cranks and now I see that they are available in BB30 with a Shimano splined interface to a freewheel. That opens up a lot of interesting possibilities for various DIY mid-drives.
Bullfrog   10 kW
Post by Bullfrog » Sep 22 2021 9:02am
The Bafang BBSHD has been great for me plus there are all kinds of upgrades available from Luna, Grin Tech, and other companies. California Ebike carries every part in the motor should you ever need to replace anything and other companies carry the common stuff. Lekkie sells the motor sprockets from 28 teeth on up. Very simple to install with the only exposed gears being the sprocket on the motor that drives the chain...unlike some other kits like the Lightning Rod that has several exposed gears, chains, belts. BUT you are going to need more power if you are going to maintain speeds over 50 kph. With a high amperage controller you can easily maintain over 50 kph but the motor temps may be an issue...I don't know.
If I wanted to maintain more than 50 kph and use a mid drive, I'd go with one of the Lightning Rod kits.
A better and simpler choice for higher speeds is a Direct Drive motor.
My choices would be a mid drive for anything off road (because you can get the gearing you want/need), a MAC if you want to go less than 50 kph on pavement (higher acceleration per amp than any IGH or DD ebike motor), and a Direct Drive if you want to go over 50 kph on pavement (simple and won't over heat).
Bullfrog   10 kW
Post by Bullfrog » Sep 22 2021 9:03am
Ignore...where is the delete button?
raylo32   10 kW
Post by raylo32 » Sep 26 2021 8:28am
Yes it does have an internal gearbox reduction. Hills are no issue, especially if you shift the bike's gears appropriately.
azad wrote:
Apr 30 2021 11:58am
Compoundbike wrote:
Apr 27 2021 1:48pm
CYC X1 Pro has a torque-sensing and has more power then a bafang.
It doesn't seem to have a gear box. Wonder how it would fare uphill. Also I notice a chain drive, these kinds are noisy and chain derailing can happen as well. I had a similar setup in the past it was very painful.
raylo32   10 kW
Post by raylo32 » Sep 26 2021 8:31am
Vaporware??
Deafcat wrote:
Jun 26 2021 1:17am
what could it be :?:
Tom   1 kW
Post by Tom » Sep 27 2021 5:36pm
raylo32 wrote:
Sep 26 2021 8:31am
Vaporware??
:lol:
Ecyclist   1 kW
Post by Ecyclist » Sep 28 2021 10:14pm
Grantmac wrote:
Jun 27 2021 12:10pm
Thank you for posting the link. I was looking for something like that.
I build a medium power electric bike and now I'm working on 4-5 Kw version. It should be good for 45 - 50 mph.
The one on the photo is good for 30 mph and can climb a tree.
Avian with the battey installed..JPG (98.11 KiB) Viewed 1124 times
Don't expect from life to be easy and then it will be.
My builds:
Avian with hypocycloidal drive https://endless-sphere.com/forums/viewt ... 2#p1318056
2016 GNG extreme drive https://endless-sphere.com/forums/viewt ... 28&t=82252
Deafcat   100 W
Post by Deafcat » Oct 01 2021 1:59pm
raylo32 wrote:
Sep 26 2021 8:31am
Vaporware??
Deafcat wrote:
Jun 26 2021 1:17am
No sir! The motor is already in six bikes with 30 more in production. I will share more details when the time is right, very soon!
Our team is very hard at work ensuring this is the absolute best mid-drive ebike drivetrain available in North America, and testing against the best offerings from Bafang in particular. I have been absolutely blown away by the latest ride-testing experiences. Fierce performance particularly in steep grade climbing and rough terrain at high speed, without a single mechanical downtime. Maximum fun times, personally I've never had so much fun with fast, uninterrupted climbing, almost better than rapid descents!
raylo32   10 kW
Post by raylo32 » Oct 01 2021 2:46pm
Words, words, words are cheap. Like I said, vaporware!
Deafcat wrote:
Oct 01 2021 1:59pm
Deafcat   100 W
Post by Deafcat » Oct 01 2021 2:58pm
raylo32 wrote:
Oct 01 2021 2:46pm
Apologies, words will simply have to suffice until we're prepared to release information officially. This is not a personal venture and even if it were, I wouldn't be willing to spill the beans until bikes have been in reviewers hands and bikes/motors in stock to sell :wink:
Bullfrog   10 kW
Post by Bullfrog » Oct 01 2021 3:47pm
Deafcat...how can we keep up with the latest info on the bikes you mentioned?
Depending on what they are and how they turn out, I may be interested in buying one.
Thanks
raylo32   10 kW
Post by raylo32 » Oct 03 2021 4:07pm
You want to buy a balloon full of vapor?? ;-)
Bullfrog wrote:
Oct 01 2021 3:47pm
Thanks
Bullfrog   10 kW
Post by Bullfrog » Oct 03 2021 4:21pm
raylo32 wrote:
Oct 03 2021 4:07pm
Bullfrog wrote:
Oct 01 2021 3:47pm
Thanks
Just reserving judgement until I see what they have to offer.
raylo32   10 kW
Post by raylo32 » Oct 03 2021 5:10pm
If it's real and if it really has a torque sensor it might be worth a look.
Bullfrog wrote:
Oct 03 2021 4:21pm
999zip999   100 GW
Post by 999zip999 » Oct 03 2021 7:30pm
every ebike is different just like tennis shoes you need to find someone who sells them go out try it right and see what you think there are people who sell fast ebikes.
Where where where the stealth B-52 has free test drives in my neighborhood. See if he even like going that fast
999zip999   100 GW
Post by 999zip999 » Oct 04 2021 2:26pm
just get this one.
viewtopic.php?f=9&t=113619
Ecyclist   1 kW
Post by Ecyclist » Oct 05 2021 4:54pm
999zip999 wrote:
Oct 04 2021 2:26pm
just get this one.
That is not a mid-drive and probably weighs a ton.
But it looks fast so why not. :D
My builds:
999zip999   100 GW
Post by 999zip999 » Oct 05 2021 5:48pm
Whoops it looked and sounded fast whoops an expensive for a used bike. Oh yes options ?
How much money you got ? Or the wrecking ball.
markz   100 GW
Post by markz » Oct 05 2021 7:00pm
Why are you always so late that you need to go so fast?
Ecyclist   1 kW
Post by Ecyclist » Oct 08 2021 5:46pm
Sometimes I'm fast and sometimes slow. It's up to my wife. :shock:
My builds:
Deafcat   100 W
Post by Deafcat » Oct 09 2021 10:30pm
Bullfrog wrote:
Oct 01 2021 3:47pm
Thanks
I'll keep you guys posted here for news, we're making quick progress with the film work (marketing), and other things that need to be checked off before product reveal... It's been a very exciting couple of weeks for the whole team!
raylo32   10 kW
Post by raylo32 » Nov 25 2021 11:23am
So a couple of weeks turn into a couple of months. Is it "soon" yet?
Deafcat wrote:
Oct 09 2021 10:30pm
Bullfrog wrote:
Oct 01 2021 3:47pm
Tom   1 kW
Post by Tom » Nov 28 2021 12:24am
Ha, I was also just checking back to see if there was any update.
tomjasz   10 GW
Post by tomjasz » Nov 28 2021 12:33pm
Bullfrog wrote:
Sep 22 2021 9:02am
Will Bafang leave DIY builders in another round of no replacement parts available when their Bosch like complete kit with battery is our only choice? I have a few pre 2016 versions that have no parts stream. Very disappointing to this happy BBSxx series builder.
Bullfrog   10 kW
Post by Bullfrog » Nov 28 2021 12:42pm
I can't answer on the Bosch/Bafang question.
I have had good luck getting parts from https://california-ebike.com/contact/...they may be able to get the parts you are wanting for the older BBS01/02 even though they are not listed on their web site. They have been very good to work with for my needs. I'd give them a call and tell them what you are trying to find. They have one of the best supply of Bafang parts I have seen :) .
