3D printed 400mm EDF project
Re: 3D printed 400mm EDF project
Hi thanks, it looks exactly like the cutaway in the blue diagram. It's just a simple single speed gearbox.
Very nice project.
Could you provide information about the BLDC motor?
Who manufacturer it?
Which ESC have you used?
Regards
Regards
Thanks. It's a TP 5870 inrunner. I am running it with a Hobbywing 14s ESC. I previously used a Castle Edge HV 12s ESC
New Prototype
- Wider shaft to prevent flexing
Drive shaft secured at both ends to prevent vibration
Washout added to blades
Duct lengthened to allow air to accelerate
Thinner walls and shorter screws to save weight
Narrower gearbox to not obstruct air
Stators are now aerofoil sections
Nylon blades
- Attachments
- Screenshot 2021-10-12 at 12.12.03 pm.jpg (139.01 KiB) Viewed 1013 times
Nice.
Can't wait to see the test results.
Ask for it by name.
my eTownie build thread: http://endless-sphere.com/forums/viewto ... =6&t=23701
Magazine article https://www.electricbike.com/nicks-etownie/
Seriously impressive project, might as well use it to propel a bikeSkyersJet wrote: ↑Oct 12 2021 5:18pmNew Prototype
Nylon blades
But unless your nylon is higly CF/GF-filled, it is not that much stiffer than petg in my experience, so you'll still have problems with blades contacting the shroud at high RPMs I suspect. They might *survive* it though, but this is still not very nice...
Using CF/GF filled filament (not nessesarily nylon, CF petg works well according to my tests, to promote epoxy adhesion) and carefully gluing strips of uni CF to stiffen the construction over it will work, but balancing it would be a nightmare (I think it was already suggested).
These blades are actually PLA.
Can people see the video? I just see a blank.
Yes I can see/view the video.
Did you also have a thrust measurement in place (suitcase weighting scale) to see the amount and difference in thrust?
I could see the video too. At least it held together this time. Which one gave the most thrust?
Hmm must be my browser.
circular intake gave 5.7kg @1492W and the elliptical one gave 5.8kg @1439W
Hi, nice work.
you are likely loosing a lot of thrust because your diffuser thrust straightening fins are not angled and are likely in a stall. you might study pictures of ones off actual aircraft. the air coming out the back of the fan is turning about the aixs and this needs to be caught with angled fins that cancel the rotational moment of the airstream, a lot of the thrust is made by streightening the flow with angled stator blades that also have an optimal spiral twist to them and the duct nozzle is non parallel in most ducted fans also to enhance thrust .
keep up the experiments you may also like to try a pancake style drone motor that is made for the slower rpm of the big fan instead of a lossy gearbox an 80 or100mm dia one can be had inthe same power level as the motor your using
I tried angled fins, it was a flop https://twitter.com/SkyersJet/status/14 ... 0553483269
If you mean an outrunner the problem is torque, not power hence the gearbox.
Is that strain gauge reading lbs.? If so 161 lbs is great!
Ask for it by name.
That's still respectable! I was having trouble believing it could pull 161 lbs.
Ask for it by name.
