Electric liveaboard catamaran project
I've bought a boat!
It's a 1976 Catalac 9M catamaran, older than me. Now it had two 30HP perkins diesel motors. These were completely overpowered for a sailboat like this, they usually have two 10HP diesels. They're also really heavy, and smell like diesels. This is a major problem for my wife, as she is part bloodhound and would simply not live on a boat that smells of diesel.
So the diesels have been removed, along with the gearboxes, shafts, and propellors. Then as I like things simple, I've decided to replace them with two 6kW ePropulsion outboards. This also frees up a huge amount of space in the giant engine bays that I have other uses in mind for.
Then in terms of batteries I'm thinking of a 16S1P pack of Eve 280AH cells or similar for just over 14kwh of power. I could be persuaded to go for a 16S2P or two 16S1P packs, which would increase range, but I'm tempted not to as I think the 1P pack would be enough battery for my typical use, and I like the idea of lightening the boat somewhat. Another option would be to put a Yamaha 9.9 outboard for added range/redundancy, but if that can be avoided I'd rather do that.
To keep it all charged my plan is for somewhere between 2800w and 3600w of solar, made up of between seven and nine Sunpower Maxeon 3 400w panels. These will be all in parallel to avoid shading issues, and run to three 48v Victron Smartsolar 100/20 MPPT charge controllers.
From someone I know with a similar boat, he gets around 5 knots on 2500 watts of power, so in good sunlight I could motor a very long way and still have power for using at night. When not motoring, the large battery pack will send power to a 48v inverter, to give my wife some of the creature comforts of home, such as hot showers, a washing machine, and all the electricity she wants for other things.
In our current apartment we use around 10kwh per day, and the amount of panels on the boat should support that on non-motoring days.
The 12v bank will be a 4S1P pack of the same batteries, charged by a DC to DC.
I've attached some pictures, but note that they're 3+ years old from before the boat was stored on land, so it's quite a lot worse for wear. As I plan to live onboard I'm willing to put in the time and money to get it back into even better condition again.
Happy to hear your thoughts, and if you have any better ideas on what to do.
- Attachments
- 1.gr.jpg (69.71 KiB) Viewed 910 times
- 16 Cockpit6 Anonymous.jpg (107.28 KiB) Viewed 910 times
- 42108-scaled.jpg (230.97 KiB) Viewed 910 times
- 145593-scaled.jpg (247.62 KiB) Viewed 910 times
- 841687-scaled.jpg (117.71 KiB) Viewed 910 times
- 891050.jpg (96.32 KiB) Viewed 910 times
Greyb.org, Cromotor, Headway 83.2v 20AH, Lyen 18 fet: http://endless-sphere.com/forums/viewto ... =3&t=45514
Kona Kahuna, x5305, Headway 76.8v 10AH, Crystalyte 72v48A: http://endless-sphere.com/forums/viewto ... =3&t=10256
Bladez Scoot, 450W motor putting out 3kW, Headway 38.4v 10AH, Lyen special controller: http://endless-sphere.com/forums/viewto ... 35&t=25872
- Location: Sydney ..(Hilly part !) .. Australia/ Down under !
Re: Electric liveaboard catamaran project
Nice boat !.... i have happy memories of living on a cat ..more than a few years ago !
I dont know where you are based , or plan on going to.....but if you are happy to rely on the sun for motor power etc, then you should consider using direct solar water heating also .
Many experienced free campers have found that hot climates generally heat water more than enough for showers, washing etc, even without a managed defined solar heater system.
It is not sensible to waste solar generated electricity on a water heater ! .
So just one quick update. I was able to spend another week on the boat and get the first piece of the project done... The engines are out! It was a monumentally difficult job due to the hardtop making it impossible to use a crane, and the boat being out of the water, over 2 meters above the ground. Fortunately the previous owner was around again, and was hugely helpful. He designed a crane we strapped to the cockpit and the very strong rear arch with a manual winch to lift and lower the motors.
I also think I've decided on the solar layout. It'll be for 3.2kW of panels, all in parallel to minimize the effects of shading, with two panels per mppt controller.
I'll only be back at the boat in April so between then and now it'll be a lot of research, ordering components and watching videos on how to work with fibreglass. If anyone has some good resources on that please let me know.Greyb.org, Cromotor, Headway 83.2v 20AH, Lyen 18 fet: http://endless-sphere.com/forums/viewto ... =3&t=45514
Nice boat project!
Have you already bought the electric outboard motors? If not, you could look into the QS Motor range to replace the diesel engines. More info on them here on E-S:viewtopic.php?f=31&t=65972
Water cooled QS138 is probably more than enough:https://nl.aliexpress.com/item/1005002741157530.html
QS180 motor:https://nl.aliexpress.com/item/1005003493746855.html
Ref solar panel rating... remember you will not get near the full panel rating with them mounted horozontal, and when you are under way with sail and wave motion, the output is very erratic.
A wind generator can be very effective on a sail boat..and at night !
- SafeDiscDancing 10 kW
I have been pondering the idea of getting into sailboats or should I just say "boats" because I'm not exactly sure which direction I'd end up with. (big, small, single hull, cat or tri)
There are very well done ENTIRELY solar boats. Catamarans seem to be the preferred shape.
If you do the math on it you could just dump the sails and make something that can go great distances at a slow pace entirely on the sun. And with enough battieries (60kwh) you could run at night too.
Just look at your boat... you are covering maybe a third with solar and getting 3200 watts. (3.2 kwh)
Do the whole thing solar and what do you get? 10 kwh.
So if you get six hours of good sun per day you recharge the battery.
Run the motor at 2500 watts and move along at 5 knots. (60,000 / 2,500 = 24 hours)
For emergencies you have a back up generator to add charge.
And most docks have electrical plugs so you could jump from dock to dock while touring.
The wind gets you a lot more motive power for a lot less work and money. I'd hesitate to give that up. (And the wind can even charge your batteries from your forward motion if your drive is set up to do that.)SafeDiscDancing wrote: ↑Jan 13 2022 12:07amIf you do the math on it you could just dump the sails and make something that can go great distances at a slow pace entirely on the sun. And with enough battieries (60kwh) you could run at night too.
Right. Now look at sails.Just look at your boat... you are covering maybe a third with solar and getting 3200 watts. (3.2 kwh) Do the whole thing solar and what do you get? 10 kwh.
If you have 60 square meters of sail, and are making 10 knots in a 20 knot wind, you're generating about 45 kilowatts of motive power. And that works day and night.
A hybrid of both is pretty ideal.
Outboards aren't bought yet, but while an inboard may have some advantages, I'm going for a boat with no holes below the waterline. The head will be composting, and with outboards I can close up the shaft tube too.SlowCo wrote: ↑Jan 12 2022 12:06pmNice boat project!
I would get around 10kW covering the whole boat, but it's hard to go back from that. I suspect the mix of sails and solar will do very nicely for my needs, but I'm not ruling out a phase 2 if it turns out I hardly ever sail.SafeDiscDancing wrote: ↑Jan 13 2022 12:07amI have been pondering the idea of getting into sailboats or should I just say "boats" because I'm not exactly sure which direction I'd end up with. (big, small, single hull, cat or tri)
I'll look into it, but for the start I'll go pure solar. I know someone with a similar boat, and he moves along nicely with 1kw of power, which I should get fairly easily.
Although a project on its own, I love the EV conversion of an outboard motor "goatman" is doing for his Bayliner:
viewtopic.php?f=39&t=107045&start=100
There seem to be a lot of ready made electric outboard motors available these days:
https://www.elcomotoryachts.com/product ... outboards/
https://www.edyn-marine.com/product/101 ... m-battery/
The bottom line is whether you are in a big hurry or not.
And it also depends on where you plan to operate the boat. Sunny Florida or some place less sunny.
Probably the wisest move is to install a motor of sufficient size to get you out of trouble when you have no choice but otherwise in calm conditions to operate at low power most of the time.
If a hurricane were heading straight at your boat you need the ability to rapidly get out of the way.
A large battery is a safety measure to guarantee you get away.
Whatever you decide to do is great and I love the idea and have been thinking about it for a few years... might do it someday but I'm kind of stuck in place for family reasons for now so I'm not free to leave.
Before you finally commit ...patrickza wrote: ↑Jan 13 2022 1:10amOutboards aren't bought yet, but while an inboard may have some advantages, I'm going for a boat with no holes below the waterline. The head will be composting, and with outboards I can close up the shaft tube too.
..... but for the start I'll go pure solar. I know someone with a similar boat, and he moves along nicely with 1kw of power, which I should get fairly easily.
Have you sailed a Cat with outboard drives before ?
Unless you plan on staying in rivers or lakes, the pitching of a cat in open water waves will lift a transom mounted outboard prop clear of the water.. they need to be mounted as far forward as possible.
..and i would not venture into open water with only 1 kW of power..unless you are a very confident sail boat user.
You would need much more than that to move safely in a tidal or river current..let alone against a headwind.(Catalac has a lot of freeboard windage )
I won't be fully committed until I punch in the credit card numbersHillhater wrote: ↑Jan 13 2022 5:33pmBefore you finally commit ...
I must admit, I do quite like Justin's new marine kit... I'm going to speak to him and see what it would take to connect a couple of his big marine motors to each of my shafts...
