75-7 motor
Looking for something? Need a special part, but can't find it online anywhere? Post what you need, maybe others will have it to sell.
ebike11   1 MW
75-7 motor
Post by ebike11 » Jan 18 2022 12:15am
Looking for one of these..are there any still around??
calab   100 kW
Re: 75-7 motor
Post by calab » Jan 24 2022 9:34pm
New or used?
ebike11 wrote:
Jan 18 2022 12:15am
ebike11   1 MW
Re: 75-7 motor
Post by ebike11 » Jan 25 2022 12:00am
calab wrote:
Jan 24 2022 9:34pm
New or used?
ebike11 wrote:
Jan 18 2022 12:15am
Either
liveforphysics   100 GW
Re: 75-7 motor
Post by liveforphysics » Jan 25 2022 2:07am
Pity I have no more of them to give. They are such a fantastic and efficient beast of a motor, and we know Zero makes and sells a ton of bikes, and people wreck motorcycles as a fact of life, and they often get motors controllers and batteries parted out of them. Parts should be available if you keep hunting around.
ebike11   1 MW
Re: 75-7 motor
Post by ebike11 » Jan 25 2022 5:13am
liveforphysics wrote:
Jan 25 2022 2:07am
Hi...yes I agree.
Do you know which particular Zero bike(s) that motor was from? Thx
CONSIDERABLE SHOUTING   10 kW
Re: 75-7 motor
Post by CONSIDERABLE SHOUTING » Jan 25 2022 10:49am
Jan 25 2022 2:07am
And if I could ask- what ARE the different motors Zero makes? I thought they maybe only made two, but I'll admit I never did a deep dive.
c70r   10 W
Re: 75-7 motor
Post by c70r » Jan 25 2022 2:17pm
CONSIDERABLE SHOUTING wrote:
Jan 25 2022 10:49am
Jan 25 2022 2:07am
As of now there are only 3 different motors, 75-5, 75-7 and 75-10. Not sure if they still make a 75-7R?
They are all IPM motors.
Before it was:
75-5, 75-7, 75-7R of which all three came in SPM and IPM configurations. I believe the SPM to IPM switch over was 2016?
The "R" motor just has magnets that can handle higher temps. The 75-5 and 75-7 are identical other than one being slightly wider than the other.
If I remember correctly the newer IPM motors produce more torque and a little better at heat management.
If you want to go even further back there was a 75-7 designed to be used with the old lower voltage bikes of 66V or something.
Also every year or two they received some update but it was something minor like shaft design and phase cable length and cable colour.
So essentially you have two bases, SPM or IPM. Then you have three sizes 5, 7 and 10. And the R for high temp magnets :mrgreen:
c70r   10 W
Re: 75-7 motor
Post by c70r » Jan 25 2022 2:22pm
ebike11 wrote:
Jan 18 2022 12:15am
Are you in Europe?
I have a 75-7 SPM I might be able to sell. Though it did have the angle grinder taken to it to remove some fins to fit in a previous project. Not much, about 10cm by 3cm and only a few mm's deep.
I'm in the UK so don't think it's worth selling to an NA buyer considering postage and import tax.
Re: 75-7 motor
Post by liveforphysics » Jan 25 2022 7:54pm
Great job on defining the Zero motor varieties. One thing you forgot C70R, is the 75-10 motor has a substantially improved thermal pathway from the windings to the housing through a thermally conductive stator potting. It also has a more effective heatsink, but at the cost of larger packaging radius.
amberwolf   100 GW
Re: 75-7 motor
Post by amberwolf » Jan 25 2022 9:30pm
If it's useful, I think I have a Sevcon from a Zero that used one of the 75 motors, though I don't know which one (never had the motor). I may also have the main connector/wiring harness (not the battery/phase wires, just the big rectangular connector).
(I don't have any of the programming stuff for it. While it should work with whichever motor it was previously setup for, assuming all control signals to it are setup correctly like they were on the Zero it likely came from, you'd need the programming hardware and software (that I don't have) to make it work with anything else or in any other way. )
If you found this advice helpful, supporting contributions are accepted here.
Beginning of a New Life
Give a listen to my music!
(More here, including experimental)
