Keywin E-bike Lab Parameter Designer Software Manual-ver 1.2
Arlo1   100 GW
Re: Keywin E-bike Lab Parameter Designer Software Manual-ver
Post by Arlo1 » Jul 03 2011 2:18pm
IM running or should I say blowing up 24 fet controllers and the xpd doesn't currently support them!
Does your project need a high performance motor drive, battery charger or other power electronics developed? Let's talk!
www.powerdesigns.ca
Leaf motor controller build. http://endless-sphere.com/forums/viewto ... 27#p963227
YSR build http://www.youtube.com/watch?v=BRo8r5g4NBg
Support me on Patreon. https://www.patreon.com/user/posts?u=6842045
http://www.undergroundelectrics.ca/
gensem   100 kW
Post by gensem » Jul 03 2011 2:58pm
Arlo1 wrote:IM running or should I say blowing up 24 fet controllers and the xpd doesn't currently support them!
It already has the 24 and 32 fet ones... just the 36 is missing.
Have a look.
https://developer.berlios.de/project/sh ... p_id=12389
Justin we really appreciate what you did!
Arlo1   100 GW
Post by Arlo1 » Jul 04 2011 8:55am
WHat is that my comeputer wont let me see it!
www.powerdesigns.ca
gensem   100 kW
Post by gensem » Jul 04 2011 11:50am
Its because of the invalid certificate;
direct download url below
http://prdownload.berlios.de/xpd/xpd-0.2.0-windows.zip
Bubba   10 mW
Post by Bubba » Aug 04 2011 3:49pm
I've got a question. I've searched for hours looking for a straight answer with no luck....
Which Switch setting do you use on the Lyen 12FET controller when using a Hall Effect throttle? I see Button and Switch options only.
Also, do the three speed settings have any effect?
Thanks in advance!
Arlo1   100 GW
Post by Arlo1 » Aug 05 2011 1:00am
Bubba wrote:I've got a question. I've searched for hours looking for a straight answer with no luck....
Thanks in advance!
Haha the switch setting is to choose wether your three speed switch is a switch or a button. And yes the speed settings work eg. 50% is 50% of everything power and top speed!
www.powerdesigns.ca
Bubba   10 mW
Post by Bubba » Aug 06 2011 7:29pm
Thanks in advance!
But I'm not using either a switch nor a button. I'm using a hall effect throttle.
Arlo1   100 GW
Post by Arlo1 » Aug 06 2011 9:02pm
Bubba wrote:[
What I meant is if you use a three speed switch that's what button mode or switch mode is for. Hall effect and Pot type throttles both vary a voltage some ware in between 0-5 v which is what controllers need.
www.powerdesigns.ca
Bubba   10 mW
Post by Bubba » Aug 07 2011 4:24pm
Ahhh! That's kinda what I thought, but just wanted clarification. Thanks!
Arlo1   100 GW
Post by Arlo1 » Aug 10 2011 7:40pm
kevo wrote:Three speed switch is nice!
yup i got "cop mode", "friends test ride mode" and "oh shit mode"
www.powerdesigns.ca
veloman   1 GW
1 GW
Post by veloman » Sep 16 2011 5:38pm
This thread has been very helpful, I wish I found it sooner.
Does anyone know why speed setting 120% doesn't increase top speed on my litte mxus geared motor? It's not a power limit, as at 17mph I'm nowhere near the amps it can pull on a hill or accelerating.
Mush! Mush you electrons! Push harder!
DAND214   1 GW
1 GW
Location: About 1200 miles south of Chicago, in sunny/rainny Port Richey, Florida!
Post by DAND214 » Dec 28 2011 12:08am
I don't know if this is a new program or old.
I ask Keywin for the software for the EB3xx controllers I received from him. So he sent this
xpd-0.2.2-windows.zip
(79.63 KiB) Downloaded 491 times
I am still assembling the boards, so I haven't tried this yet.
I'm sure I will be asking questions soon.
Dan
Kiwi   1 kW
Post by Kiwi » Feb 14 2012 5:25pm
there does not appear to be any EB3xx board option in there.
mxer   1 kW
Post by mxer » Feb 27 2012 4:02am
I have tried to download the Perameter designer setup ALL zip "Mike" installer zip package and i cannot unzip it?, it just say's "Unexspected end of archive" or corrupt ? Anyone else experience this ?
Or is my XPD software conflicting ?
DAND214   1 GW
1 GW
Post by DAND214 » Feb 27 2012 11:13am
I can't get it to load either.
I can't get the simulator on Ebikes.ca to run.
Running XP pro.
Gone thru all the posts I could and really it doesn't help.
Dan
johnrobholmes   1.21 GW
1.21 GW
Post by johnrobholmes » Mar 07 2012 2:48pm
Looks like the zip file is corrupt.
gensem   100 kW
Post by gensem » Mar 07 2012 3:11pm
XPD site is still up...
http://xpd.berlios.de/
Hope this helps.
toolman2   1 kW
Post by toolman2 » Apr 02 2012 9:42pm
that setup all file is corrupt? can someone post up a good copy, or is there another way of to do this?
being able to program an ecrazyman controller has been out of reach for me for years now, are we sure it can actually really be done with ant of these files?
i now even have the usb converter made for the new 24 fet, but the software?
toolman2   1 kW
Post by toolman2 » Apr 02 2012 11:40pm
i got things to kinda work, now getting invalid reply byte 'fe'
or invalid reply byte 38
any ideas?
Degull   100 W
Post by Degull » Apr 13 2012 10:48am
Hi everyone. I would like to play with the parameters on my motor controller. I have one of Cellman's EB312-AS-2 controllers and I would like to read and save the settings profile that is currently on the controller before I attempt to tweak them. Is there any way to read the profile that is installed on the controller now before I screw everything up? If I mess everything up I can always go back and install the original parameters. Not sure how I can go about reading the info off the controller. Thanks.
amberwolf   100 GW
Post by amberwolf » Apr 13 2012 1:32pm
No way to read from controllers that I am aware of. You're stuck with "blindly" overwriting whatever is there with your new settings.
You might ask Cell_man if he knows what those defaults are, or see if anyone has published them here on ES.
Degull   100 W
Post by Degull » Apr 13 2012 10:02pm
Cellman kindly provided the values via email. Thanks for the suggestion. Let see if can make some smoke.
Mowolar   1 µW
Post by Mowolar » Jun 05 2012 9:30am
Hi Guys,
I have a new e-bike with attached (picture) controller.
Is the e-bike software and cable compatible with my controller?
Thanks, Lars
ambroseliao   100 kW
Post by ambroseliao » Jun 05 2012 10:47am
Hi Lars,
It's hard to tell from the label. Can you open the case up and take a photo of the motherboard?
http://www.ebikes.ca/ is the best!
TidalForce M-750X, Tidalforce S-750 with Crystalyte HS3540, 1x TF iO-X Cruiser. E+ 1000W hybrid bike. ebikes.ca DrainBrain & Cycle Analyst meters. GoPro HD Hero2 camera. Bosch Fat Packs, 37V 10Ah LiPO pack. Turnigy Multistar batteries
My blog: http://ebikerider.blogspot.com
Remember LiFEPo4 HVC is 3.65V and LVC is 2.7V
Mowolar   1 µW
Post by Mowolar » Jun 05 2012 1:37pm
Hi ambroseliao,
I didn't know where to focus on, but see attachment for 2 pictures of the mainboard.
Thanks for your help and look forward hearing if it's possible!
