12 FET 84-132V High Voltage Racing Controller - LYEN $199
steveo   1 MW
Re: 12 FET 84-132V High Voltage Racing Controller - LYEN $19
Post by steveo » Jun 13 2010 11:55pm
Hey Everyone,
For all of you that know me i have run a 24 mosfet irfb 4110 controller with 145v of a123 for months .. even before lynn has released his controllers in for sale thread
Lynn
You must modify r115 as per knuckles .. IT WILL FAIL; I gaurentee it, I've had failure 2 times since march 2010; that ive been running this controller
R10, r11, r12... WILL BURN OUT
the current is to high ..
I could even take a photo of the resistors on my board... the resistors are turning brown due to the heat over last 3 mnths
I don't want to hurt your thread... but buyers must beware that if they but this board .. it will faill .. may not be for a few months ... but it will happen..
-steveo
Repair Thread
http://endless-sphere.com/forums/viewto ... =3&t=27170
Hub Monster bike ~ 24s7p A123 15.4ah/18kv Six Phase Motor/Dual Max-E Adapttos/32kw~42.91Hp/Est 140LBS
X6 Kmx Trike ~ 24s4p 20ah/X6 MHM 602/Infinion EB324 IRFB 4110/20Kw~26.82Hp/Est 120LBS ~SOLD~
Lightening rods bike ~ 18s2p 10ah/1500w Inrunner/Infinion EB312 IRFB4110/2KW~2.68hp/Est 60LBS
EV Outboard ~ 12s8p 40ah/5KW GM Inrunner/Infinion EB324 IRFB 4110/18Hp Evinrude Drive/Est 100lbs
http://www.youtube.com/user/trdfreak03
Lyen   10 kW
Post by Lyen » Jun 14 2010 1:25am
Hello Steveo!
Thanks for letting me know another potential failure. Yes, please take a picture of your "browned" resistors on your circuit board. May I also ask what was circuit board revision that failed on you? I appreciate it!
Regards,
Lyen
steveo wrote:Hey Everyone,
Lynn
-steveo
Items For Sale
Please sign up here and donate your marrow to save life.
The Mighty Volt   10 MW
Post by The Mighty Volt » Jun 15 2010 11:05am
Hi Lyen, in light of SteveO's post, do you mind if I wait until the issue is resolved before I pay you the remainder of the money I owe you for the controller?
Thanks.
PS I am sure SteveO is a legit dude who just wants the best for forumites.... 8)
Lyen   10 kW
Post by Lyen » Jun 15 2010 11:56am
Hi Mighty!
Yes, I would not sell any controllers with potential issues. The potential issue that Steveo suspected is being escalated and reviewed by the engineers from the manufacturer and me. I will get back to you once it is clarified. :)
Regards,
Edward Lyen
The Mighty Volt wrote:Hi Lyen, in light of SteveO's post, do you mind if I wait until the issue is resolved before I pay you the remainder of the money I owe you for the controller?
Thanks.
Items For Sale
Tom_D   100 mW
Post by Tom_D » Jun 15 2010 1:36pm
Hi, Lyen,
I have a few questions on the controller I just received from you:
:arrow: You posted the mod June 5, and sent mine out June 9. Does it have the resistor mods to it as pictured above? I just want to make sure.
:arrow: . Your screenshot on page 1 shows parameters for an 18fet (EB218) board. All the examples I find from Methods are for EB218 boards as well. Can you provide the .asv file for this EB212 (12 fet) board showing the default values for all the parameters ?
:arrow: Can you just change and flash one parameter value, or do you have to populate them all ? I don't want to upset the rest of defaults values.
Thanks in advance for your help. :mrgreen:
-- Tom
Bike: wally world 26" Roadmaster mtn
Trailer: Bob
Motor: front Clyte 5305
Controller: LYEN 124115 HV
Charger: Soneil 4808 SRF (onboard), parallel charging (4) 48V blocks, NO BMS
Batt: 84s2p Toyota Prius Gen III
Dashboard: Cycle Analyst
Lyen   10 kW
Post by Lyen » Jun 15 2010 2:48pm
Hi Tom!
I have replied back to you via PM. Thanks! :)
Regards,
Lyen
Items For Sale
Tom_D   100 mW
Post by Tom_D » Jun 15 2010 4:21pm
Lyen, PM received. You have answered all my questions with real information. :mrgreen: You are good guy.
Thanks.
--Tom
Trailer: Bob
Post by The Mighty Volt » Jun 15 2010 5:50pm
Lyen wrote:Hi Mighty!
Regards,
Edward Lyen
Thanks.
Thanks Lyen. As soon as everything is clear, just send me a PM and I will pay you the remaining 75% plus the postage. Thanks and good luck with everything!
Lyen   10 kW
Post by Lyen » Jun 17 2010 4:48am
Here is the remedy. I have engaged a bunch of people from the manufacturer for the potential issues that was mentioned by the young fellow Steveo again. I was told by the engineer and designer of the circuit board being used was good as is. But to relief the worrying of people, here are more changes as shown on the pictures below. The R115 resistor will not turn brown. The possible reason was because Steveo operated his controller at 145-150v which was not safe to begin with. The engineer told me the R115 resistor can sustain 15 degree Celsius above normal operation temperature. The engineer has also said switching power circuitry for voltage regulation is embedded onto the circuit board, so the additional VR or voltage regulation circuitry is unnecessary. Resolved. :)
Your Truly,
Edward Lyen
Items For Sale
Post by The Mighty Volt » Jun 17 2010 7:18am
Hi Lyen, in a PM you mentioned 18 Fet and 12 Fet.
I have a basic notion, more fet's = better.
Is this correct.
How much is the 18 Fet controller?
Thanks.
Lyen   10 kW
Post by Lyen » Jun 17 2010 7:38am
The Mighty Volt wrote:Hi Lyen, in a PM you mentioned 18 Fet and 12 Fet.
Is this correct.
Thanks.
Hi Mighty!
Here is the link for the 18 FET High Voltage controller I am also selling:
http://endless-sphere.com/forums/viewto ... 31&t=18605
In theory, more MOSFETs can generate more power with less heat. But a properly optimized configuration between battery and motor and price are also important. In addition, enclosure size, range, weight, and battery discharge ability should be consider. :)
Regards,
Edward Lyen
Items For Sale
AmpEater   10 W
Post by AmpEater » Jun 18 2010 10:26pm
Is that last one still for sale? I'll take it
Lyen   10 kW
Post by Lyen » Jun 18 2010 10:35pm
AmpEater wrote:Is that last one still for sale? I'll take it
Hi AmpEater!
Thanks for your interest in the controller. Yes, it is still available for purchase. :)
Regards,
Edward Lyen
Items For Sale
steveo   1 MW
Post by steveo » Jun 18 2010 11:36pm
how about r12 heat issue?
Repair Thread
Lyen   10 kW
Post by Lyen » Jun 21 2010 10:53am
steveo wrote:how about r12 heat issue?
The issue was escalated and resolved. I appreciate your respect and concerns. :)
Regards,
Edward Lyen
Items For Sale
steveo   1 MW
Post by steveo » Jun 21 2010 11:04am
Regards,
Edward Lyen
do you have any photos of the r12 circuit fix... i'm curious to see your fix :)
-steveo
Repair Thread
Lyen   10 kW
Post by Lyen » Jun 21 2010 11:36am
Regards,
Edward Lyen
-steveo
Why don't you show me yours first? :wink: What do you have to hide? Also, you never show me your browned resistor issue as you said you were going to show me? I am curious to see your fix as well. :)
Lyen
Items For Sale
steveo   1 MW
Post by steveo » Jun 21 2010 3:35pm
... I have nothing to hide? ... why would i?.... the resistors are very very small .. but i will do my best to take a photo for you... i think i need a magnify glass for everyone to see... i will try without one...
i have not yet found a proper fix... but my guess would be a higher wattage resistor.
-steveo
Repair Thread
Arlo1   100 GW
Post by Arlo1 » Jun 21 2010 9:32pm
Steveo & lyen I fried my r12 in my 18 fet methods controller its just to small the disapate that much heat. I used a 1/8th watt resistor and mounted it up off the bord and its fine now.
Does your project need a high performance motor drive, battery charger or other power electronics developed? Let's talk!
www.powerdesigns.ca
Leaf motor controller build. http://endless-sphere.com/forums/viewto ... 27#p963227
YSR build http://www.youtube.com/watch?v=BRo8r5g4NBg
Support me on Patreon. https://www.patreon.com/user/posts?u=6842045
http://www.undergroundelectrics.ca/
Lyen   10 kW
Post by Lyen » Jun 22 2010 1:20am
Arlo1 wrote:Steveo & lyen I fried my r12 in my 18 fet methods controller its just to small the disapate that much heat. I used a 1/8th watt resistor and mounted it up off the bord and its fine now.
Hi Ario1!
Thanks for getting back to me on your PM. The 18 FET Infineon Controller you have purchased from Methods was built using a legacy circuit board. The one you are looking at here does not have the legacy electronic component such as the LM317 and the 7805 voltage regulators. In addition, I have replaced the on board SMD resistors network to sustain high temperature. Again, I have spoken with a few engineers/circuitry designers and executed what needs to relief the worrying from potential buyer although they thought it may not be necessary. :)
Items For Sale
geetarboy   100 W
Post by geetarboy » Jun 28 2010 10:05pm
Yes Edward, I am ready for "higher voltage"....can't wait :twisted:
Lyen   10 kW
Post by Lyen » Jul 06 2010 5:09am
Here's the latest video from an Italian running his electric bike at 116.8V with the Crystalyte 5305 motor using 32 of Headway 38140 cells in series along with the EC124115 controller. He was running at 70-92 KPH or 43.5-57 MPH. You may noticed the sound from his low speed high torque motor sounded like a jet engine when running at high speed. I have asked for his approval to share the video with us. :)
Enjoy the video! :)
Lyen
Items For Sale
Post by The Mighty Volt » Jul 06 2010 8:06am
What I really want to see is some of these bikes going up big hills. Thats where their true worth is. I want to see some of these volt-guzzlers climbing!!
John in CR   100 GW
Post by John in CR » Jul 09 2010 9:58pm
The Mighty Volt wrote:What I really want to see is some of these bikes going up big hills. Thats where their true worth is. I want to see some of these volt-guzzlers climbing!!
Can I show you 85-90mph instead? It's coming to a theater near you, summer 2010. :mrgreen:
Post by The Mighty Volt » Jul 10 2010 6:43pm
Top Speed is all good. I mean, it is impressive- but I am more impressed by brute acceleration and the ability to chew out any hill not called Everest.
What's your system anyways? :D
