18 x 4115 MOSFET 84-132V Real Highway Speed Controller $259
zombiess
1 GW
1 GW
Re: 18 x 4115 MOSFET 84-132V Real Highway Speed Controller $
Post by zombiess » Apr 30, 2013 3:32 pm
alsmith wrote:Does anyone have the shunt resistance value- it's for the cycle analyst RShunt setting. It doesn't seem to be the same as the 18 x 4110 FET controller.
Should be 3 shunts which means the controller is expecting a 1.33 mOhm shunt. Typically 3 shunts ends up around 1.2x mOhms. Try 1.25mOhms and then start calibrating from there based off of how many amp hours you drain from your fully charged pack vs how many you put back in. Then calculate the error percentage and multiply the shunt value times that. I.E. you pulled 10Ah from your pack and put back 9.5Ah. 10/9.5 = 1.05263% difference. If your shunt is 1.25mOhm multiply it by 1.00105263 and you find out your shunt value is now around 1.316mOhm. Do this 2-3 times and you should have a shunt value that is fairly accurate.
I've written how to do this process before if you search through my posts.
alsmith
Post by alsmith » Apr 30, 2013 5:16 pm
Many thanks. I've seen your post (saved on my computer) but was looking for the starting point.
itchynackers
Post by itchynackers » Apr 30, 2013 7:42 pm
Mine ended up at 0.962mohm
9c 9x7f w/ 12awg phases
9c 8x8r w/ 10awg phases, temp sensor, vented
9c 6x10r w/ 10awg phases, temp sensor, liquid cooled, 3rd Place Pikes Peak 2012!
"Don't argue with the galactically stupid...they drag you down to their level and beat you with experience"
pendragon8000
Post by pendragon8000 » May 02, 2013 6:39 am
great info :D . My new build seems like its using more power on the screen than it is in reality.
i'll try 1.0m mohm
8)HYENA high power ebike kits
My builds
scott 29er + Hyena kit, mon-goose to MON-STER 6KW, Free Agent RC Mid Drive, videos
my bike goes so fast 'cos it charges the battery while I pedal
ROG130
Post by ROG130 » May 07, 2013 1:44 am
hi lyen
is this controller overkill for a 1000w conhismotor
i am running 48v a123 20ah 20c prismatic battery cells from osn with a 50amp bms
at the moment i am running your 12 x 4110 MOSFET Extreme Modder Controller LYEN Edition $129
but was looking for a bit more go :twisted:
Falco
Post by Falco » May 07, 2013 3:08 am
ROG130 wrote:hi lyen
Why dont you try boosting the current on you controller you have now? This controller is really for if you want to do high voltage and gain more speed with the power with that. No gain to be had if you stay at 48v.
2012 Giant Anthem SL0 Carbon fiber bike running BBS02, 13s4p Samsung 18650 25r, Di2 XTR shift kit.
trevc2
Post by trevc2 » Dec 03, 2013 8:38 am
Do any owners of this model have experience with bumping the current up a bit (on an un-modded unit)? Just curious how hard I can push mine. It's running at the stock 45A now on 24s. 55 or 60 would be good. Thanks :)
John Bozi
Post by John Bozi » Aug 23, 2014 5:21 pm
agree with trevc above, just got mine will trial 60amps unmodded, hopefully doesnt fail.
More importantly the main feature I really would like to be able to programme is regen over 75v. Why is that the maximum on a controller listed at 84-132v?
thanks
p.s. I bought this off another member who bought it from Lyen, so I didn't have a chance to ask for customizations
pendragon8000
Post by pendragon8000 » Aug 24, 2014 8:10 am
If your trying yo program it, all the voltages are double in the menusfor the 4115 controllers. Well with the software iI use it is.
My builds
John Bozi
Post by John Bozi » Aug 24, 2014 3:18 pm
pendragon8000 wrote:If your trying yo program it, all the voltages are double in the menusfor the 4115 controllers. Well with the software iI use it is.
link to the software? thanks
Newb said something about xpd...
wish i had more time to finish my soldering of the plugs
BobTheBuilder
Post by BobTheBuilder » Dec 17, 2015 8:34 pm
Love this controller
70.6mph @ 28s 117v 10ah
Defkon5 D2
ecycler
Post by ecycler » Dec 21, 2015 12:45 pm
70mph is some serious speed... do you have a build thread? Assuming you are running 120v+ on a MXUS3k 3T?
Any grease is better than no grease.
The best exercises are the ones you enjoy doing.
I strongly prefer vehicles without doors.
jokr
Post by jokr » Dec 21, 2015 5:42 pm
BobTheBuilder wrote:Love this controller
Good job!
Ilike the mobile display!
maxRpm
Post by maxRpm » Dec 28, 2015 9:18 pm
ecycler wrote:70mph is some serious speed... do you have a build thread? Assuming you are running 120v+ on a MXUS3k 3T?
+1 I too want to see a build log!
Mad Huey
Post by Mad Huey » Jan 04, 2016 3:51 pm
Lift your back wheel off the ground and then WOT. You too can have 70+ MPH displayed for a quick photo :))
BobTheBuilder
Post by BobTheBuilder » Jan 23, 2016 12:34 pm
QS 96V V3 from Shaun James
http://youtu.be/GatAvPzqFbk
BobTheBuilder
Post by BobTheBuilder » Jan 23, 2016 12:35 pm
Mad Huey wrote:Lift your back wheel off the ground and then WOT. You too can have 70+ MPH displayed for a quick photo :))
Thank you Mad Huey
BobTheBuilder
Post by BobTheBuilder » Jan 23, 2016 12:40 pm
http://youtu.be/kNzq1T-_ayU
Another 4115 build in progress. I used the cruise control button on my on/off switch for the "precharge" button . I hold it in for 3 seconds then power on.
