6x4110 Mini Monster Programmable Controller LYEN Edition $79
Lyen
Post by Lyen » May 28, 2010 2:30 pm
The controller is hacker ready. It was originally a special request item from a member. But word of mouths are making it becomes more popular so I had to make a few extra to meet the demand. :)
These are newly hand assembled Infineon 6 FET controllers I am selling, they are new and never used. It is originally designed for long distance commute in the San Francisco area. It is also best to be used on electric bikes with smaller wheels such as those 16" to 20" wheels found on most folding bikes & scooter style ebikes for more speed. For those who owns battery packs with 10-15Ah in capacity this is the controller for you to avoid getting the battery management system circuitry (BMS) tripped or experience power protection shutdown enabling due to insufficient current flow (low discharge rate) available from the battery and low amperage designs in most 10-15Ah capacity battery packs.
The controller is like a wolf in sheep's skin because it is under tuned in order to optimize for long range. There are lots of potential and features you can unveil and twist as you go. You can program functions such as enable power regeneration, regenerate braking, pulse width modulation, low voltage cut-off, interface with a Cycle Analyst, and others. You may also add an USB to TTL programming adapter and connect to the computer for tuning. (Electronics knowledge is required to unleash the potential however)
One unique feature on this controller is that it has an additional speed sensor circuitry built-in with an extra wire embedded for output. It is to be used with the scooter style electric bike and electric scooters that have a speedometer in the dashboard.
If you look carefully in the photos, you will notice this version also uses lock washers to secure the MOSFETs internally and the heat transfer bar outside to place tension against a nut after tightening. It is also to help prevent the nut from loosening. The MOSFETs will get overheated and damaged when detached from the heat-sink which used to be the case from the previous designs.
* For hackers, you may double and possibly triple the current output to make it a mighty wonder by adding braids wires (http://www.radioshack.com/product/index ... Id=2062744),add solders to beef up the circuit board traces and shunt. It may also be needed to upgrade to larger capacitors, gauge wires for both the battery and the phase wires to the motor.
Best motors to use:
200-500w geared motors
E-BikeKit 6x10 motor due to high torque & low current
Features:
Programmable
Small size
Lightweight
Long range
Good for low discharge rated batteries
Hackable features:
Higher power output
Cruise control with throttle only
Reverse
Security lock
Turbo mode
Status Indicator
Speed Limit
etc.
For hacking information, please see the links below:
https://endless-sphere.com/forums/viewto ... hilit=6fet
https://endless-sphere.com/forums/viewto ... =2&t=18641
Below is the specification:
Model: EC-064110-LYEN EDITION
Start immediate controller
Chipset: XCKJ8B116A (same chipset being used as in the 18 FET controller)
Circuit board version: EB206-A-3
6 x genuine IRFB 4110 MOSFET N-CH 100V (tested up to 110V before damage) for more information about the FET, click the link below:
http://search.digikey.com/scripts/DkSea ... 4110PBF-ND
36-60V battery optimized (for higher or lower voltage & current such as 24V, 60-100V, you may need to change the resistor network to avoid damage to the LM317 linear voltage regulator)
20A is the current rate at 72v or 25A at 48v (for higher current, you may need to beef up/reinforce the trace, shunt, and reprogram it via the software)
Low voltage cut-off: 29V
Battery and motor phase wires gauge size: 12AWG (High voltage capable wires equipped)
Dimension: 4.53" x 2.63" x 1.38" (115mm x 67mm x 35mm) plus mount extensions
I have only 50 made since I am busy working on my other ebike projects. My intention for selling at such low price is to share the fun with other ES forum members instead of making them jealous. :wink: I finally understand why Methods mentioned the cost of labor is steep after all this and I have to agree with him from now on. These controllers are not generic controllers. I have every single one serialized. Quantity is limited, buy it now and upgrade later once your piggy bank is filled up if needed. :lol:
$79 USD free ground shipping in the United States & Canada. For other locations, please PM or email me at LYEN@HOTMAIL.COM. I accept PayPal, cash or money order. The controllers will be shipped out from me in San Francisco, California, USA. I will provide a tracking number and ship it out as soon as I have received the fund.
For only $10 more, I can include the the following:
1. CA connector
2. Regenerative enable/disable (Enabled simply by connect the wires together without the need to open the case)
3. USB-TTL 5 pin connector (for use with the USB-TTL adapter that is sold separate)
I also have the USB-TTL adapter for adjust and alter the controller settings on your computer. It has the extra 5 pin plug and a "SEND" button. It is also compatible with Windows XP/Vista/7 32/64 bit operating system (real 32/64bit drivers). $15 with purchase, $20 if purchase separately.
You may click on the PayPal Buy It Now link below. For accessories, please send money via PayPal or send me a private message for the total price. Thanks!
https://www.paypal.com/cgi-bin/webscr?c ... Q2J7L8VBNW
If you are not satisfy with the results or if it is too fast for you, you may send it back to me within 30 days in an unmodified condition.
Update: March 21st, 2015 > I can adjust the controller for 24V, 33V, 36V, 48V, 60V, 66V, 72V, 84V, and other battery settings upon request.
Quantity updated as of 6/4/2013 : 49 left (buyer bought 1 from Ehrendingen, Switzerland )
Quantity updated as of 6/12/2013 : 48 left (buyer bought 1 from Lemignano di collecchio, PR, Italy )
Quantity updated as of 7/28/2013 : 47 left (buyer bought 1 from Tularosa, NM )
Quantity updated as of 8/11/2013 : 46 left (buyer bought 1 from Melbourne, Victoria, Australia )
Quantity updated as of 8/12/2013 : 45 left (buyer bought 1 from Ashfield, NSW, AUSTRALIA )
Quantity updated as of 8/18/2013 : 44 left (buyer bought 1 from Santafe, NM, United States )
Quantity updated as of 8/23/2013 : 43 left (buyer bought 1 from San Francisco, CA )
Quantity updated as of 9/2/2013 : 42 left (buyer bought 1 from Yakutsk, Sakha (Yakutiya), Russia )
Quantity updated as of 9/2/2013 : 41 left (buyer bought 1 from Queen Creek, AZ, United States )
Quantity updated as of 9/14/2013 : 40 left (buyer bought 1 from Gyor, Hungary, Hungary )
Quantity updated as of 10/8/2013 : 39 left (buyer bought 1 from Springfield, MO, United States )
Quantity updated as of 10/8/2013 : 38 left (buyer bought 1 from Kankakee, IL, United States )
Quantity updated as of 10/15/2013 : 37 left (buyer bought 1 from Baton Rouge, LA, United States )
Quantity updated as of 10/19/2013 : 36 left (buyer bought 1 from Ann Arbor, MI, United States )
Quantity updated as of 10/29/2013 : 35 left (buyer bought 1 from Berkeley, CA, United States )
Quantity updated as of 11/6/2013 : 34 left (buyer bought 1 from Cardiff, CA, United States )
Quantity updated as of 12/31/2013 : 33 left (buyer bought 1 from Grenoble, France )
Quantity updated as of 1/3/2014 : 32 left (buyer bought 1 from 5 Takahe Terrace, St Leonards, New Zealand )
Quantity updated as of 1/13/2014 : 31 left (buyer bought 1 from Palm Beach Gardens, FL, United States )
Quantity updated as of 1/13/2014 : 30 left (buyer bought 1 from Rockaway, NJ, United States )
Quantity updated as of 1/15/2014 : 28 left (buyer bought 2 from Tel Aviv, Israel )
Quantity updated as of 2/8/2014 : 27 left (buyer bought 1 from Moskow, Russia )
Quantity updated as of 2/9/2014 : 26 left (buyer bought 1 from Pittsburgh, PA, United States )
Quantity updated as of 3/13/2014 : 25 left (buyer bought 1 from Bellevue, WA, United States )
Quantity updated as of 4/9/2014 : 24 left (buyer bought 1 from Den Haag, Netherlands )
Quantity updated as of 4/30/2014 : 23 left (buyer bought 1 from Surbiton, Surrey , United Kingdom )
Quantity updated as of 4/30/2014 : 22 left (buyer bought 1 from Rio Rico, AZ, United States )
Quantity updated as of 5/5/2014 : 21 left (buyer bought 1 from Heddesheim, Germany )
Quantity updated as of 5/11/2014 : 20 left (buyer bought 1 from Chicago, IL, United States )
Quantity updated as of 5/18/2014 : 19 left (buyer bought 1 from Blagoveschensk, Amur Reg., Russia )
Quantity updated as of 5/25/2014 : 18 left (buyer bought 1 from Portland, OR, United States )
Quantity updated as of 6/12/2014 : 17 left (buyer bought 1 from Grouville, United Kingdom )
Quantity updated as of 6/20/2014 : 16 left (buyer bought 2 from Moscow, Russia )
Quantity updated as of 6/25/2014 : 14 left (buyer bought 1 from chicago, IL, United States )
Quantity updated as of 6/25/2014 : 13 left (buyer bought 1 from Werndorf, Austria )
Quantity updated as of 7/6/2014 : 12 left (buyer bought 1 from Tel, Aviv, Israel )
Quantity updated as of 10/7/2014 : 11 left (buyer bought 1 from Unna, Germany )
Quantity updated as of 10/15/2014 : 10 left (buyer bought 1 from Spokane, WA, United States )
Quantity updated as of 11/10/2014 : 9 left (buyer bought 2 from Manhattan beach, CA, United States )
Quantity updated as of 11/22/2014 : 7 left (buyer bought 1 from Kaunas, Lithuania )
Quantity updated as of 11/24/2014 : 6 left (buyer bought 1 from Cape Coral, FL, United States )
Quantity updated as of 12/8/2014 : 5 left (buyer bought 2 from Leganes, Madrid, Spain )
Quantity updated as of 1/15/2015 : 3 left (buyer bought 1 from Singapore)
Quantity updated as of 2/22/2015 : 2 left (buyer bought 1 from Lünen, Germany)
Quantity updated as of 3/5/2015 : 1 left (buyer bought 1 from Saratoga, CA, United States)
Attached are the pictures of the controller. Please allow time for the images to load.
Additional accessories (prices are reflected with controller purchase only. Please contact if you are interested to buy without controller):
$15 throttle (full/half/thumb) with mated left rubber grip (very good quality) (ebikekit retails @ $36)
$19 cruise control (manually installation required)
$15 three way speed switch (manually installation required)
$15 PAS - Pedal Assist System add-on (manually installation required)
$15 electric brake levers a pair
$29 motor/controller hall/phase tester
Items For Sale
Please sign up here and donate your marrow to save life.
mwkeefer
Re: 6x4110 Mini Monster Programmable Controller LYEN Edition
Post by mwkeefer » May 28, 2010 2:33 pm
Lyen,
I tried your pay now link to order one of these but at the paypal checkout screen it lists:
1x controller @ 79.99 and S&H is coming up as 79.99 - I assume this is an error with the link.
I would like to buy one of the 6 fet controllers and was wondering if you have h/m/l switches for these or not...
Thanks in advance,
Mike
Regards,
Mike
{My Rides]
2010 Dahon Jack - GNG v1 - LYEN 6FET - 20/40A - 18S2P10AH - Nom:66.6v,1332w
2004 Hard Rock Pro Disc - Recumpence ms eDrive v4 - Astro 3220 4T - 12S2P16AH - HV110 - Left Side Drive - Gearing: 38mph
Nominal Peak Power @ 60 seconds: 5328 watts - Maximum Power: 49.8v, 120A, 5872w
2010 Downtube 8FH - Stock GNG v1 Stock Controller - EB809XC - 12-16S
2012 Downtube Nova 7spd - Stock GNG v2 - 12S2P10AH - EB809 - 12S-16S - 20A/30A,Nom VCC: 44.4, 888w
Lyen
Post by Lyen » May 28, 2010 2:38 pm
mwkeefer wrote:Lyen,
Thanks in advance,
Mike
Hi Mike!
Thanks for the acknowledgment on the PayPal error. I have corrected the shipping cost in PayPal. I appreciate it.
I do have the h/m/l switches but they are labeled as I/II/III for easier readout and is in a more blended black color instead of red. Manual installation is required. :)
Regards,
Lyen
Items For Sale
mwkeefer
Post by mwkeefer » May 28, 2010 3:04 pm
Thanks... paypal sent, so I guess that means 9 controllers remain = )_
-Mike
Regards,
Mike
{My Rides]
mwkeefer
Post by mwkeefer » Jun 07, 2010 10:27 pm
You'e got Money again... please ship this one out as fast as possbile for under 40USD... if I owe you anything at the end, I will happily remit via paypal.
I needed this here before end of week, I ordered one already (can' always use a spare) but when I inquired about how much shipping would be, you said it was a deal for free shipping.....
I know you said 10.00 for express but I threw a few more on top.
Thanks in adance,
-Mike
PS: Ive had 3 6FET units go pad on me in a week, the latest the one on my Dahon Jack = ( Now I personally really need another controller.
Regards,
Mike
{My Rides]
GrayKard
Post by GrayKard » Jun 07, 2010 10:51 pm
Got my controllers in today and spent a few hours removing the old ones and hooking these up. Have a slight throttle problem with one of my lines reading high so that the controller doesn't start up. I can get around that but I need to fix it before I start tweaking the controllers.
What are the low and high limits that these controllers read for valid throttle voltage so I can adjust what mine are outputting with some resistors?
Just so it's clear, the problem is with my hacked throttle, and not the controllers. :D
Gary
Lyen
Post by Lyen » Jun 08, 2010 1:01 am
GrayKard wrote:Got my controllers in today and spent a few hours removing the old ones and hooking these up. Have a slight throttle problem with one of my lines reading high so that the controller doesn't start up. I can get around that but I need to fix it before I start tweaking the controllers.
Gary
Hi Gary, the throttle voltage should not be more than +5v. May I ask what kind of throttle are you using or hacking? The it a hall effect throttle or if it simply a resistor POT throttle such as those being used by the Currie style & Magura 5K type? If the later is the case, then you can simply add a 4.7k resistor in between. Please let me know if it helps. :)
Regards,
Lyen
Items For Sale
GrayKard
Post by GrayKard » Jun 08, 2010 2:19 pm
Lyen wrote:Hi Gary, the throttle voltage should not be more than +5v. May I ask what kind of throttle are you using or hacking? The it a hall effect throttle or if it simply a resistor POT throttle such as those being used by the Currie style & Magura 5K type? If the later is the case, then you can simply add a 4.7k resistor in between. Please let me know if it helps. :)
Regards,
Lyen
I use a hall half twist throttle. Here's the link to the hack that Methods came up with: https://endless-sphere.com/forums/viewto ... &start=169
It basically creates a two in one throttle so you can avoid a ground loop when running one throttle into two controllers. The problem is that it throws the the voltage off between the two halls as one is further from the magnet. I need the minimum and maximum threshold voltage to which the controllers will respond.
The controllers Methods was using were two 18 fet 100volt 100amp models and he lists their thresholds as this:
Off voltage:
Threshold: 1.2V
WOT voltage:
Threshold: 3.14V
Do you think that would be the case with the 6 fet or do I need to do some testing to find the right values?
Let me know if you want to move this discussion to my build thread instead.
Gary
Lyen
Post by Lyen » Jun 08, 2010 2:27 pm
Regards,
Lyen
Off voltage:
Threshold: 1.2V
WOT voltage:
Threshold: 3.14V
Gary
Hi Gary!
The threshold should be identical as you have mentioned with the 18 FET controller since they both are using the exact same ECU and same designs on the throttle portion of the circuitry. :)
Items For Sale
swbluto
Post by swbluto » Jun 16, 2010 9:07 am
mwkeefer wrote: PS: Ive had 3 6FET units go pad on me in a week, the latest the one on my Dahon Jack = ( Now I personally really need another controller.
I've heard that the TO-220 package style risks "blowing" past 75 phase amps. Phase amp limiting should ensure it'd last a bit longer, although I personally would just use a 12fet model.
John in CR
Post by John in CR » Jun 16, 2010 10:39 am
Hey Lyen,
Do you have the 6fet with the sensorless board, and/or board with the switching supply instead of resistors?
Lyen
Post by Lyen » Jun 16, 2010 11:10 am
John in CR wrote:Hey Lyen,
PM sent. Thanks! :)
Regards,
Lyen
Items For Sale
Kingfish
Post by Kingfish » Jun 22, 2010 2:38 pm
Greetings
First, please allow me to thank you for your expedient delivery of product! :D
Second, I ran into a blocking issue with the Prolific USB-Serial Drivers. Though they would install, when connecting the cable I received an error Code 10 which equates to “unable to start device”. After some frustrating minutes, searching I came upon a workaround:
http://www.usglobalsat.com/download/546/win_drivers.zip
This link resolved the problem.
I am running Windows 7 x64.
Thank you again; I can’t wait to give it a go!
~KF
* My 2WD Garden Wall
* Kinaye MotorSports
* Epics: Going to California: 2011 8)
Lyen
Post by Lyen » Jun 22, 2010 2:48 pm
Hi Kingfish!
I'm glad you have received the two controllers. There is a better driver for the USB-TTL programming adapter. I have just PM you the link to download.
It's also good to know you have found another work around with another driver for it. Thanks for the info. :)
Best Regards,
Edward Lyen
Kingfish wrote:Greetings
~KF
Items For Sale
mwkeefer
Post by mwkeefer » Jun 22, 2010 3:58 pm
These were all my own stupidity, I mixed them up and used a LV with a HV pack and vice versa.... insufficient or excessive voltage to LM317 and poof, repairable but... I hate working on these things.
Lyen, if you have one of these with the switching regulator circuit... I'll take one also in addition to John in CR's requests - Express Mail Please :)
-Mike
Regards,
Mike
{My Rides]
snath
Post by snath » Jul 08, 2010 6:16 pm
I received my controller in a timely manner and the packaging was great!
Had some problems initially with the driver for the programing cable (Lyen sent me the correct one) and with a broken wire in the USB part (Hint: open the USB covers and look for broken wires at the soldered joints).
These problems were exacerbated by an old computer that chose this time to konk (slowly) out.
Anyway, Lyen's customer service is impeccable (even after I told him about the broken wire and that I had fixed it, he still sent me a new cable) and I'm a happy camper.
Larry Barefield
ambroseliao
Post by ambroseliao » Jul 08, 2010 6:56 pm
Have you looked at this thread?
https://endless-sphere.com/forums/viewto ... =2&t=14807
Ambrose
http://www.ebikes.ca/ is the best!
TidalForce M-750X, Tidalforce S-750 with Crystalyte HS3540, 1x TF iO-X Cruiser. E+ 1000W hybrid bike. ebikes.ca DrainBrain & Cycle Analyst meters. GoPro HD Hero2 camera. Bosch Fat Packs, 37V 10Ah LiPO pack. Turnigy Multistar 10Ah batteries
My blog: http://ebikerider.blogspot.com
Remember LiFEPo4 HVC is 3.65V and LVC is 2.7V
snath
Post by snath » Jul 08, 2010 7:13 pm
Yes, and what a great resource! Any progress I have made towards programing the Lyen controller is solely due to it's contents.
Thank you for pointing it out!
Larry Barefield
ambroseliao
Post by ambroseliao » Jul 08, 2010 7:15 pm
I didn't say it was easy! :shock:
Lyen sometimes misses emails. Have you tried to contact him outside of ES? Do you have his direct email?
Ambrose
Lyen
Post by Lyen » Jul 09, 2010 1:52 am
snath wrote:I received my controller in a timely manner and the packaging was great!
That's where my good experience with the Mini Monster ended.
I wanted to program the unit to meet what I deemed to be my unique needs but to my dismay, the software that Lyen sent me wouldn't load and the USB device driver was incorrect.
Now I profess my ignorance with computer programing/software troubleshooting but it doesn't seem to me that it should be this much of a problem.
After one email exchange, Lyen never responded; and perhaps, rightly so because I am, at this point, out of my depth and, he did say that "electronics experience is required". However, software that won't load and USB drivers that don't work seems to be a little much.
Long story short, I ordered a Kelly... their software seems to be designed for the non-programmer and, more importantly, seems to work.
Larry Barefield
Dear Larry Barefield,
Please accept my apology for not responding your last private message since June 28th. I have to admit I missed it due to overwhelming messages. I also have to clarify the one email exchange was only a request to send you the link of the program and driver on 6/26/2010. The rest of the communication were via private messages on the forum.
Anyway, here was your last private message:
Sent: Mon Jun 28, 2010 5:20 pm
by snath
Hi Edward,
Thanks for the tips but am not quite to the implementation point.
I have the software loaded but have a couple of questions:
The examples populate the template but when I select a controller model from the pull down menu the template does not automatically fill. I can however, operate the pull down boxes and select values. Is this normal?
The other problem I'm having is that my computer won't recognize the USB driver. It seems to load ok but maybe it's because I'm running Windows XP Professional. Or, maybe I need to move the driver somewhere?
I hate to take up a lot of your time. I feel that I owe you lunch maybe in the second week of August when we are out for our son's wedding.
Thank you,
Larry
Here are the answers to your previous questions.
1. You are correct that the pull down menu does not automatically fill. It is normal to select the values manually.
2. The driver from the link I emailed you back on 6/26/2010 does contains drivers for Windows 2000/XP/Vista/Win7 on both 32bit and 64bit versions. May I ask the symptoms that received? Do you get an exclamation mark under the device manager in Windows?
Again, I am very sorry for that. I should take you out for lunch instead. :)
Let's continue the escalation via email since this is a sales thread. I have sent you an email as of 7/8/2010 @ 11:48pm PST to continue to escalation process. I appreciate it.
Sincerely,
Edward Lyen
Items For Sale
joe tomten
Post by joe tomten » Jul 10, 2010 10:22 pm
Ok,
I want two, cause it is time to get a bit more serious about learning about these controls. And it looks like Lyen has made the learning curve a little more gentle.
Keeping the thread toward the top here so i can refer back to it when it gets to be tech time
Joe
Lyen
Post by Lyen » Jul 11, 2010 2:21 am
joe tomten wrote:Ok,
Joe
Dear Joe,
Thanks for your interest in the controllers. I have just sent you a response via email as requested. :)
Best Regards,
Lyen
Items For Sale
amberwolf
Post by amberwolf » Jan 12, 2011 2:22 am
Been a while since this thread has seen anything, but thought I'd update that this controller is still working for me on DayGlo Avenger, first with a 9C 2807 and a couple of different NiMH packs, and now with a Fusin geared hubmotor designed for 36V, running on a 48V Vpower LiFePO4 pack.
https://endless-sphere.com/forums/vi ... 03#p352003
In case anyone else needs to use it for such a motor, the combination I found for phase and halls is:
Phases and halls are the same:
Fusin  Lyen
B       G
G       Y
Y       B
Wiring BB YY GG will work, too, but it runs backwards. If you have the version with no freewheel, this is fine, but if you have the freewheel version it won't move the bike. ;)
Stielz
Post by Stielz » Jun 02, 2011 3:12 am
Hi Lyen,
I just curious about the regen braking feature, does it have any control over what voltage and current is generated? to prevent overcharging lipos etc
Cheers,
Alex
Lyen
Post by Lyen » Jun 02, 2011 1:53 pm
Hi Alex,
Thanks for your interest in the controller. I have just sent you a PM with answer to your question.
Best Regards,
Edward Lyen
Stielz wrote:Hi Lyen,
Cheers,
Alex
Items For Sale
