Polaris Ranger EV
Electric cars, trucks, ATVs, NEVs - things bigger than a motorcycle.
ELI_ICE_MAN   1 mW
Polaris Ranger EV
Post by ELI_ICE_MAN » Dec 20 2010 12:37pm
The Polaris ranger EV is a side by side ATV, or UTV, with fully independant suspension front and rear. The vehicle weighs 1700 lbs and has a gasoline twin that weighs 650 lbs less. it is true on-demand 4 wheel drive. Is anyone familiar with the motor and controller used on the Polaris Ranger EV? The motor is an ABM Type DLGF112200-4 3-Phase AC High-Efficiency Induction Motor with 8.3 kW rated power. Polaris is claiming peak of 30 HP. I believe ABM is a German manufacturer? Also, the Controller is a SEVCON GEN 4 G4865. This is a 48volt, 650A RMS burst controller and the battery pack is a group of 8 lead acid 100 A/hr with two groups of 4 in series to make up 48V with a 200 A/Hr rating. I am interested in this unit as i have recently been infected with the EV virus. I have ATVs and have been wanting to upgrade to the Polaris Ranger and this makes sense as a first EV project. Anyway, new to the site, trying to take it all in, and wondering about possible modifications that might include converting the system over to 72 or 96 volts to increase the top speed from 25 mph to possibly 40mph. I know SEVCON makes a 80 volt version of this controller with the same physical layout and 550amp vs 650 amp RMS burst capability. Anyone familiar with the controller? I know EV mods are an expensive hobby, but I see future potential with knowing more about this technology and that makes it worth it to me. Anyone familiar with the motor and controller used here?
ev_nred   100 W
Re: Polaris Ranger EV
Post by ev_nred » Feb 14 2011 9:22pm
the one simple thing you could do to incress top speed is to go with a lithium battery pack 8) however this is expansive...
cheers,
jacob R
Lessss   10 MW
Post by Lessss » Feb 14 2011 9:25pm
Expensive as in lotsa money, as opposed to expansive as in most of America's waistlines.
Give me nuclear batteries I say!! Ripped off by Joshua Goldberg to the tune of almost $900 re headway groupbuy for batteries, no $ no batteries
http://www.openoffice.org/ or https://www.libreoffice.org/
http://distrowatch.com/dwres.php?resource=major
ELI_ICE_MAN   1 mW
Post by ELI_ICE_MAN » Feb 15 2011 2:57pm
Actually that is one of the first things I would want to do with this vehicle is build a battery pack out of A123 Prismatic 20A/h cells. However, I believe the controller might be set to limit the speed so that the vehicle qualifies as a LSV (Low Speed vehicle). In the US LSV's are allowed on residential roads that have a posted speed limit of 35mph or less, but are their top speed is also limited to 25 mph. So don't know if the controller is limiting speed to 25 mph or if it is a result of not being able to pump in enough current to overcome the back emf of the motor, or the current limits imposed by the controller. I am not sure what the limiting factor is. But that brings up another question, what would be required to boost the top speed up from 25 mph, to perhaps even 40 mph which is the ICE version's top speed? From what I can gather increasing the system voltage is the key to higher top speed. I know the gearing ratios, tire sizes, kW rating of the motor, and I can generate a spreadsheet that tells me what the rpm of the motor would be at at different speeds. Does anybody have any ideas for helping me understand top speed limits?
ev_nred   100 W
Post by ev_nred » Feb 18 2011 10:03pm
do you have the speard sheet?
ELI_ICE_MAN   1 mW
Post by ELI_ICE_MAN » Feb 21 2011 1:36pm
I am having trouble trying to post the spreadsheet, any advice on how to post a snippet from the preadsheet, or just how to format spaces between text; or post a picture that is not already on the web?
Sorry, I am a noobie
Lessss   10 MW
Post by Lessss » Feb 21 2011 2:42pm
ELI_ICE_MAN   1 mW
Post by ELI_ICE_MAN » Feb 21 2011 4:17pm
Lessss   10 MW
Post by Lessss » Feb 21 2011 6:42pm
hehe
click upload attachment on the screen where you write a post/comment. Seriously sometimes it's just a matter of reading what's on your screen. I do tech support. After the 50 thousandth time of user fails to read screen it gets a little tedious.
ELI_ICE_MAN   1 mW
Post by ELI_ICE_MAN » Mar 01 2011 3:08pm
I have attached a spreadsheet that shows my calculations for motor RPM to vehicle speed. I am trying to understand the top speed limitations for this vehicle. It has a top speed of 25 mph in High mode, 10 mph in Low mode and 15 mph in max range mode. Any ideas?
Polaris EV Calculations.xls
(360 KiB) Downloaded 399 times
MitchJi   1 GW
1 GW
Post by MitchJi » May 29 2011 6:07pm
HI,
Does it have a transmission? Because you could increase the top speed with larger tires. The reduced acceleration probably wouldn't be a problem if it has multiple gears.
Best Wishes!
Mitch
Buying a new Tesla? Please consider using our referral code https://ts.la/lynnem96959 to get one thousand miles of free Supercharging.
The best quality batteries and lowest priced batteries for DIY EV's are tier 1 OEM Quality Cells from salvaged (wrecked) EV packs. Three examples are Chevy Volt and Nissan Leaf and Tesla Model 3 packs.
Nissan Leaf Module specs are here
Chevy Volt Pack Info - Salvage 16kwh Packs Under $2k here
speedmd   100 MW
Post by speedmd » Sep 21 2017 7:08am
Has anyone here built a Li pack for this UTV? Starting to look into it myself.
Alan B   100 GW
Post by Alan B » Sep 21 2017 8:12am
I would use Leaf battery components, or similar available from other existing automotive designs that are available on the used market.
speedmd   100 MW
Post by speedmd » Sep 21 2017 10:01am
Alan B wrote:I would use Leaf battery components, or similar available from other existing automotive designs that are available on the used market.
That is my plan also. Like also the chevy volt and the larger ford c-max cells. The C-max have built in fuses so all I would need to setup is a balance charging setup. I can get a big pack for around 1K on the salvage market. I need to make charging and battery monitoring idiot proof as the spouse will be the main user. Just a work cart so It should be good with 12s, but thinking 14s may be good also. The stock batteries are still healty so I have the time to think it through. Know very little about the subsystems so far. Need to get a shop manual to learn all the subsystems and relay connections. The winch setup is powered by two separate six volt batteries up front. Not sure if anything else needs them. Looking at a 48V Ware winch or swapping out the motor for a small BLDC and reversible trike controller if I can find the right shaft setup. I am wondering the need for a separate Lead battery setup at all. Charging a separate Li 12v pack setup (automatically from the main pack) if need be would be the main concern if I try to keep the 12v winch setup.
Update: What a great UTV! Spouse loves it also. Battery box can fit a boat load of Li capacity. Stock batteries are still acting near new. Will see how it winters over in use. At a closer look it measures out to easily be able to fit 6 (or possibly 8 if you want killer range) chevy volt 2kwh sections. Will be a interesting project swapping over to a Li pack on it.
Looking for some sort of battery charge / voltage display that can show individual series cell strings adapto style. Simple led voltage indication strips for each string would be good. Hate to go with just a gross idiot light setup showing low battery or a simple but effective pack voltage indicator.
speedmd   100 MW
Post by speedmd » Sep 29 2017 7:53am
Found these on Ebay that look like possibly a good choice for a cell string level indicator.
speedmd   100 MW
Post by speedmd » Sep 30 2017 9:51am
Finding some more good options for cell level indicators. Blue tooth BMS?
Larger BMS w/bluetooth
https://www.alibaba.com/product-detail/ ... 18621.html
bms w/dedicated display
https://www.aliexpress.com/item/Free-sh ... 17ff739a-8
whereswally606   100 kW
Post by whereswally606 » Sep 30 2017 9:56am
speedmd wrote:Found these on Ebay that look like possibly a good choice for a cell string level indicator.
I bought a couple of these years ago. For some reason some of the top green LEDs died, happened to both which then rendered them useless as the made you think the cells were imbalanced and not full when indeed they were.
Sent from my ALE-L02 using Tapatalk
Distributing "Lebowski" FOC Controller PCB (Through hole) since 2016
Moped: Emax 110s 2009
speedmd   100 MW
Post by speedmd » Sep 30 2017 10:01am
I was also thinking that it would not be good having them on full time. Would need to tie them in to the key switch.
speedmd   100 MW
Post by speedmd » Oct 03 2017 12:31am
Got the shop manual for the 2013 ranger ev. No mention of the winch 14v battery system unfortunately. Looks to be reasonably simple emergency low use setup. No charge built into the main pack charge circuit unfortunately. While the unit is running, a small separate voltage converter runs a bit of charge to the small batteries. Made for a Low duty cycle use and may need a upgrade for high winch use apps. Not finding any other use for the small batteries so they may go if I switch to a 48v winch when I get to updating the main pack. Sevcon 4 runs very nice. Well programed on the factory settings. In low speed range, the added torque and regen works very nice in tighter and hilly spots. Easy to control with just the accelerator pedal. In high it feels fast and free wheels much better. In max range, it feels more like a typical old folks golf cart, just a bit faster and has a great near silent high end brushless sound. Not finding any issues with the programing so far.
fechter   100 GW
Post by fechter » Oct 03 2017 9:25am
The speed limit is most likely programmed into the controller. With the right programming interface, you might be able to change this. My understanding is the Sevcon programmer is ridiculously expensive, so you'd probably want to find someone that already has one.
speedmd   100 MW
Post by speedmd » Oct 03 2017 10:34am
Certain it is. It's mainly the spouses garden work cart so I will not be looking for more speed out of it and with two young grand sons (the older one likes speed a bit much), I don't want it any faster. 25 mph in H (high) in the yard is way too fast now. Nice feature that is programmed in, is the seat belt feature, that limits the speed to some 15 mph when it is not on.
speedmd   100 MW
Post by speedmd » Oct 19 2017 8:49am
Looking further into lithium battery swap and charger- bms options. Nice looking on-board stock 1000W delta q charger for the lead batteries.
https://delta-q.com/product/quiq-1000-i ... y-charger/
They claim it may be suitable for lithium also (certainly with BMS). Need to look into this a bit more. Has a bunch of built in algorithms - program settings, and I will need to lower the charge level a bit as it does boil the electrolyte a bit more than I like. Oxide deposits on the terminals looks to be normal to bad and not something that will be missed. Something that will require routine messing with until they are gone.
