XPD: open-source keywin e-bike lab replacement
chucho   1 kW
Re: XPD: open-source keywin e-bike lab replacement
Post by chucho » May 06 2014 11:21am
Thank you very much for the work and sharing :!: :!: :!:
Someone who does not doubt is a danger to the rest
9c+24slipo+60A lyen12fets+CAv3+26"hookworms=Fun commute
Cargobike+9c+13s33Ah=Fun transport
Kona entourage+ gng+ 40A lyen12fets+CAv3=Fun crosscountry
Flux+adaptto Max-e+Mxusv2+19" shinko= Monster fun Any Way
Cowardlyduck   100 MW
Post by Cowardlyduck » May 17 2014 6:14am
I've lost the install file I previously downloaded for V0.3.2 of xpd, and it seems all the links in this thread are now dead.
Is anyone able to re-post it somewhere for general download?
Cheers
My stuff:
Ebike Garage - My YouTube Ebike ramblings.
Cowardlyducks - Videos - Ride videos
BikeE recumbent commuter - 9C, 6Fet Grinfineon, internal 17AH, 52V, + on-board solar.
For Sale:
Custom made 18650/21700 battery packs - Australia only
High Power LiPo wiring harnesses - 4P - XT90, HXT4mm, 5.5mm. 200Amp+ capable. Global shipping.
Cowardlyduck   100 MW
Post by Cowardlyduck » May 18 2014 4:44am
izeman wrote:here you go: https://dl.dropboxusercontent.com/u/117 ... -0.3.2.zip
should include everything. pm me if it's missing something
Awesome! Thanks heaps, was just what I was after.
Unfortunately, it doesn't seem to be helping my issue like I thought it would. I was after the install files so I could repair everything. That didn't work, so I uninstalled/reinstalled everything also, but still no luck.
This is the error I'm getting when launching xpd.pyw.
I'm running Win 7 x64. It worked fine previously. I hadn't run it in a couple of months, but I can't think of anything major changing recently to have caused something like this.
Anyone got any idea's?
Cheers
My stuff:
For Sale:
Hyena   100 GW
Post by Hyena » Jun 17 2014 9:58pm
Hey guys,
I haven't used XPD in ages, was there any update in the last year or so that enables higher voltage regen ?
Or are we still stuck with the hardware R12 hack ?
www.HyenaElectricBikes.com
NeilP   10 GW
Post by NeilP » Jun 18 2014 11:09pm
Still with R12 mod from what I understand
:) Only Irish coffee provides in a glass all four essential food groups: alcohol, caffeine, sugar, and fat :)
jorijnsmit   1 mW
XPD Waiting Acknowledgment
Post by jorijnsmit » Jun 22 2014 11:43am
Love the XPD project, it is a shame I cannot find it at its usual spot anymore (http://xpd.berlios.de/ seems to be dead). Luckily the files did end up on Sourceforge somehow, at least that's where I was able to find them: http://sourceforge.net/projects/xpd.ber ... rce=navbar.
I got v0.3.2 running on OS X 10.9.3 (Mavericks) with some help of the pointers here in this thread, especially on how to get the Prolific's USB serial controller installed. All is well: I can start xpd from a terminal and, although it gives some errors about fonts and icons, get a GUI with which I was able to at least flash an EB212 I got from Lyen a long way back.
My actual goal however is to get an EB312 (12 FET 3077 MOSFET Extreme Modder Controller LYEN Edition) reconfigured but I do not get further than "Waiting Acknowledgement" after pressing the button on my USB cable. Letting go of the button and pressing it again gives me an error ("Upload failed: Invalid reply byte '55'" or "Upload failed: Invalid reply byte 'd5'", depending on how long I hold the button).
I am wondering if (1) anybody knows why my EB312 board does not reply with an acknowledgement and (2) if, despite not acknowledging, the board isn't flashed anyway.
Although I can not find a change log I decided it would be worth a shot to try v0.3.1 as well but to no avail. Can anybody recommend any other versions maybe?
NeilP   10 GW
Post by NeilP » Jun 22 2014 2:18pm
EB 3xx and EB2xx require different wiring on the programming cable.
The USB side is the same, but you need a jumper wire from pin 1 to pin 5 on the controller end
The info why is on the forum here some where...I know I posted about it in the past.
Programming adapter.JPG (113.23 KiB) Viewed 2911 times
jorijnsmit   1 mW
Post by jorijnsmit » Jun 23 2014 1:59am
Lifesaver! You just saved me a lot of headaches.
So yeah instead of a red wire on the fifth pin going back to the button it jumps directly onto the first pin (white).
NeilP   10 GW
Post by NeilP » Jun 23 2014 4:44am
The button unit and the rest is exactly the same.
I have a little 2 inch jumper unit made up with a male on one end and femail on the other..so you jsut stick the extension on to the end of the EB2xx program cable
jorijnsmit   1 mW
Post by jorijnsmit » Jun 26 2014 2:16am
I'm a cow, I found this adapter a short time after creating my own jumper, it must have been included with the board...
NeilP   10 GW
Post by NeilP » Jun 26 2014 2:55am
You will probably, ( if not already done so), make the same mistake I have done many times when using the adapter.
This basic mistake I refer to happens once you finish programming. It is very easy to disconnect the adapter from programming cable, and leave adapter connected to controller.
When you do this, the bike will not run, and the first thougjh is usually one of 'oh frock, I 've killed the controller'
PeeHell   100 W
Post by PeeHell » Jul 01 2014 12:18am
Does any of you know what is the change in programming between EB2xx and EB3xx ? I mean why won't it work to program an EB3xx with the EB2xx controller type selected. Is it only software or it's more complex than that ? When Anpaza added "support for EBxx controller", did he do it simply by adding a few line in python ?
Kingfish   10 GW
Post by Kingfish » Jul 01 2014 11:32am
PeeHell wrote:Does any of you know what is the change in programming between EB2xx and EB3xx ? I mean why won't it work to program an EB3xx with the EB2xx controller type selected. Is it only software or it's more complex than that ? When Anpaza added "support for EBxx controller", did he do it simply by adding a few line in python ?
The difference between EB2XX and EB3XX is very much like looking at a Tangerine verses a Mandarin: They both appear to be like small thin-skinned oranges, yet beneath the surface there are subtle changes that are easily recognized if you had both in hand to compare.
Categorically, the count of features is different as are the options and the equations used to determine values which are compiled into a format that each class and type of controller can understand. In addition, the protocol for communication is uniquely different.
It was not a simple matter of “adding a few lines of code”; it was in fact a profound engineering effort to integrate a new profile having many similarities which could take advantage of the same framework and user interface in order to host the presentation.
Anpaza has my respect, and I am grateful for his contributions.
They are well-met. KF 8)
* My 2WD Garden Wall
* Kinaye MotorSports
* Epics: Going to California: 2011 8)
anpaza   10 W
Re: XPD Waiting Acknowledgment
Post by anpaza » Jul 03 2014 6:18pm
jorijnsmit wrote:Love the XPD project, it is a shame I cannot find it at its usual spot anymore (http://xpd.berlios.de/ seems to be dead). Luckily the files did end up on Sourceforge somehow, at least that's where I was able to find them: http://sourceforge.net/projects/xpd.ber ... rce=navbar.
The BerliOS open-source hosting deceased.
So I moved the project to Google Code: https://code.google.com/p/xpd-ebike/
I've updated the very first post of the thread as well.
Also I have added a pointer to my Infineon 3 document which I wrote long ago, but forgot to announce.
Alan B   100 GW
Post by Alan B » Jul 04 2014 10:39pm
Thanks for your support!
jorijnsmit   1 mW
Post by jorijnsmit » Jul 05 2014 2:39am
Yeah good stuff man, I am also happy that I got it working on OS X. If you want I could help with documentation on how to get it running on OS X.
ebike11   100 kW
Post by ebike11 » Jul 07 2014 10:35am
Does this program work for Infineon 4110?
I got one from em3ev and would like to program it thx
izeman   100 GW
Post by izeman » Jul 07 2014 2:31pm
sure. it doesn't depend on type of fets installed. just the number of fets, the number of shunts and the type of board is interesting to know to program it properly.
gwhy!   1 MW
Post by gwhy! » Jul 07 2014 3:08pm
ebike11 wrote:Does this program work for Infineon 4110?
i think the em3ev controllers have there own profile in XPD :? so you need to edit the correct profile before re-programming..
Edit:
Or the actual current will not be what it is set for,,
DAND214   1 GW
1 GW
Location: About 1200 miles south of Chicago, in sunny/rainny Port Richey, Florida!
Post by DAND214 » Jul 07 2014 5:00pm
If you bought it from EM3ev/Cell_man, you can get the software from him.
You will need the programming cable. you also need to know which board you have.
Why do you want to reprogram it? Once you flash it you can't go back, unless you have the qriginal profile from Paul/Cell_man.
Dan
ebike11   100 kW
Post by ebike11 » Jul 07 2014 6:36pm
DAND214 wrote:If you bought it from EM3ev/Cell_man, you can get the software from him.
Dan
hi there!
oh really, you cant flash back to stock settings with the .asv files that I downloaded with the software?
I have the cable and my board is 9fet 4110. I thought I could adjust the 3 speed setting through the software and turn off PAS and REGEN as I don't use them
Can I just short the 3 speed wires externally to get the highest speed possible instead of the software??
I don't need 3 speed settings, I only want the highest of the 3 speeds and leave it alone.
I noticed the 3 wires are red, black and green. I assume black/green or black/red wire combination would be the highest speed??
Not sure
Thanks!!!
DAND214   1 GW
1 GW
Post by DAND214 » Jul 07 2014 10:27pm
Yes you can reset it if you have the files.
Look at the asv.
the three speed switch is a nice option. It can tame the throttle down if needed.
What voltage and motor are you running?
Dan
ebike11   100 kW
Post by ebike11 » Jul 07 2014 11:37pm
DAND214 wrote:Yes you can reset it if you have the files.
Look at the asv.
Dan
Hi
I have the 30A 9fet 4110 controller and 8T
I have a 72V battery and Im sure its over kill for an 8T
so I wanna adjust the throttle/power etc. with the EB8 program
DAND214   1 GW
1 GW
Post by DAND214 » Jul 08 2014 12:09am
72v is a litle high for a geared hub.
You don't have to worry about regen or pas in the program, regen not possible and pas not there if you don't hook it up.
Dan
