Aerodynamics thread?
StevenR   100 W
Re: Aerodynamics thread?
Post by StevenR » Aug 03 2008 9:24am
Here...
http://www.mueller-hp.com/windtunnel.htm
...is wind tunnel testing of Mueller fairings done by Mueller.
Basically says recumbant with fairing is no better than an aero tuck. For me, given the recum disadvantages, I will stick with an areo extension on flat bars. Now if I could just get the throttle and cruise control onto the old Scott AT-4's...
Bianchi Alante MTB with C'lyte 5303 Front Hub Motor / Motobecane hardtail MTB with C'lyte 5303 Rear Hub Motor
CT48V35A Controller / method monster 100A100V controller
Schwalbe 26"x2.3" Big Apples / 26" Schwalbe Ice Spiker Pros
Ping v3 48V20aH with 60A v2.5 BMS / Headway 48V10aH BMS used to balance, bypassed on discharge
Pick one from each row above
recumpence   100 GW
Location: On Earth right now. That can change at any time, though..........
Post by recumpence » Aug 03 2008 11:36am
If that were the case, why are recumbents banned from upright bike racing classes?
What you have to look at with recumbents is, is it a low recumbent or a high recumbent? Is the seating upright or low?
The Vision recumbents he was testing are not lowracers. They are relatively upright seating style recumbents. I am sorry, but all this expensive wind tunnel testing can be easily avoided by using common sence. Look at the frontal area of the bike in question. If the frontal area is large, it will be slow. If the frontal area is small, it will be fast (generally speaking).
I am not trying to push anyone into a recumbent. Buy and ride whatever you enjoy most. But, I am tired of people giving this arguement.
A low recumbent that is setup well is faster than an upright bike, period. The world record is evidence of this and anyone who has ridden a lowracer knows it.
Again, ride whatever you enjoy. Heck, I have a couple uprights and a couple recumbents. Recumbents do have their drawbacks. But, don't kid yourself into thinking they are slower than an upright.
A lowracer recumbent is the fastest layout available.
Matt
1% of the world's population can think "Outside the box". The rest are firmly stuck within the box. Where are you?
D-Man   1 MW
Post by D-Man » Aug 03 2008 12:58pm
Can't you get more pedalling leverage on a recumbent vs upright with a backrest and everything?
408 front hub
21000+ miles on many sla's.
5 tires worn out
recumpence   100 GW
Post by recumpence » Aug 03 2008 1:37pm
Yes, somewhat.
One thing to consider, as well, is the fact that a recumbent does not require any muscle input to hold your torso. Therefore, with a recumbent, you always have all your nervous system energy devoted to pedal power. With an upright bike, the most power is available when you stand up. But, that standing reduces your available power for pedalling. So, with a recumbent, you have maximum power available to the legs all the time. Then if you go with a lowracer, you have lower frontal area as well. That is why they are so fast.
Recumbents have poor visibility, though. It is hard (on a lowracer) to turn your head to look around. That is one of the main drawbacks.
Matt
paultrafalgar   10 kW
Post by paultrafalgar » Aug 04 2008 3:10am
recumpence wrote:Yes, somewhat.
Matt
No argument about superiority of recumbent aerodynamics, Matt. Add to this comfort (seat doesn't crunch the gonads and neck isn't cricked by stretching back to view road ahead) and the only disadvantage is PERHAPS the visibility. How about a fibreglass pole which typically has flag but instead has a police-style rotating LED about 6 foot from the road? Would the battery drain be too great? I think not. I've not patented the idea, so feel free to exploit it :D
Regards,
Paul
If we knew what it was we were doing, it would not be called research, would it? Albert Einstein
A paranoid is someone who has SOME idea of what's going on. Allen Ginsberg(?)
If the greatest pleasure is giving, be selfish - give pleasure.
John in CR   100 GW
Post by John in CR » Aug 04 2008 9:37am
I was talking to one of my employees over the weekend about ebikes, and I find out he's into competitive downhill racing. They do a few km in a few minutes, so avg close to 60km and that includes slower stretches through the technical stretches. I said at those speeds a fairing will help him go faster, and would likely be far more beneficial than spending a fortune trying to save 100's of grams here and there. Anyone want to help me design something that could hold up to those rigors? The only similar thing I could find through searches is the fairings the gravity bike racers use, but that's just coasting down hills on streets at insane speeds.
John
TylerDurden   100 GW
Post by TylerDurden » Aug 05 2008 9:10am
Safe was a gravity racer. You might be able to pry some info outta him. :lol:
Have a Nice Day,
TD
___________________________________________________________
FYI: Adding pictures?
Bored?... take a crack at the unanswered posts
Please post your Watts-at-speed in the survey.
truckerzero   100 W
Post by truckerzero » Aug 26 2008 9:42pm
i know alot of people useing coroplast to make fairings its light and strong
its that stuff like corragated cardboard but is plastic and they make politcal yard signs out of it
it can be baught at local printing companys for 20 bucks for a 4 foot by 8foot sheet just call around to local printers and tell them you want
a sheet in 4mm thickness
try calling smaller print shops a lot of the bigger ones would not sell to me not worth their time i guess
i made a radio controlled airplane out of it and its tuffer than any one elses plane and not much heavyer
ford explorer 12 mpg
pontiac sunfire 30 mpg
883 harley sportster 55 mpg
raze rc nitro buggy 196 mpg on 5% nitro methanol fuel
stryker electric rc plane 3.3 watts per mile@80 mph(too bad i cant ride on that thing)!!!
TylerDurden   100 GW
Post by TylerDurden » Aug 26 2008 9:46pm
Coroplast is good stuff. Watch the heat though, it can get soft over 160F.
http://www.coroplast.com/resin.htm
(The small sign shop in my town sells 4'x8' white for ~$15. :mrgreen: )
Have a Nice Day,
TD
Zoot Katz   1 MW
Post by Zoot Katz » Aug 26 2008 10:07pm
TylerDurden wrote:Coroplast is good stuff. Watch the heat though, it can get soft over 160F.
This is what I did with unclaimed campagain signs.
Dinos Against Fossil Fuels.
heads, claws and segmented tails are coroplast
TylerDurden   100 GW
Post by TylerDurden » Aug 26 2008 10:12pm
Nicely done... who needs a tailbox, when you have a 2m tail??? :mrgreen:
Have a Nice Day,
TD
Zoot Katz   1 MW
Post by Zoot Katz » Aug 26 2008 10:39pm
TylerDurden wrote:Nicely done... who needs a tailbox, when you have a 2m tail??? :mrgreen:
The tail is only ~65" but works okay for towing kids on skateboards.
Mathurin   100 kW
Post by Mathurin » Sep 01 2008 11:17am
So i've played around with a recumbent handtrike, a Speedy Laser
http://www.speedy.de/laser/laser.htm
Big fun but terribly impractical. You have to come to a near complete stop anytime there's a risk of cross trafic cause you can't see shit, captn'. I'd guess cars couldn't really see me well either, but dunno. Can't take the slightest bump, couldn't make it jump over stuff, forget about hopping curbs eh, gotta slow down to a near stop for sidewalk lips. I guess it would be neat on a long distance closed circuit with no other traffic or something, but in real life it kinda sucked. Aero really isn't everything.
You have to know, not fear, that someday you are going to die. Until you know that and embrace that, you are useless. - Tyler Durden, Fight club. Ditch the fake identity you've created for yourself, walk your own way in a society of mindless drones to become real, you are not your social status.
eCue   10 kW
Post by eCue » Feb 06 2018 5:46pm
a Old thread with some good suggestions and great title
The first post is my sentiment exactly , improve the aero rather then add more battery and larger motor. I may end up on a recumbent they look fun as a go cart and life is short
I adjusted this aftermarket 1/4 fairing to be less street warrior and more aero
So far ive noticed a about a 2kmh top speed improvement and its nicer pedaling against the wind.
I am going to do coast down tests on a little steep hill that goes down to a bridge and back up the other side in a gentle yet steep flow. I tag in behind cars on it and hit 75kmh on the pedal bike , for this test i will lift my feet and coast with and without the fairing on
With it picked up 2kmh from 38 to 40 on the above straight stretch although on different days so it was not a tightly run test.
I need run back to back test on a hand picked still day
Solar charge station on wheels join the Revolution
wturber   10 MW
Post by wturber » Feb 06 2018 7:12pm
Only the second image is visible. All others have a circle with a dash. I'm guessing the problem is images size?
I'm all for fairings if they can be made practical. My limited experience is that they are more trouble than they are worth. OTOH, since I've added a front basket to my bike, it has caused me to wonder what I could wrap around it to smooth the air flow. Since I already have a area carved out, a limited fairing might actually work.
"Commuter - DC Booster"
viewtopic.php?f=2&t=90369
eCue   10 kW
Post by eCue » Feb 06 2018 7:37pm
John in CR wrote:
Jul 29 2008 12:58pm
OK, I've had it with the wind slowing me down. My good road routes put me directly into a headwind to start every ride. While it's great for the return trip, it's time to get sleeker. In addition to a small front fairing and a tailbox, I want to do some little things that will hopefully add up.
Tires- These knobby off-road tires have got to go. I don't like them in the curves anyway, and they must be a real aero thief too. Whenever I lift the tire off the ground for a spin test it's like I'm turning on a powerful fan.
Front suspension- I forget the exact relationship, but something I learned in my sailboat design research is that a cylindrical form has the same aero drag as proper foil that is 3-4 times thicker. I want to build some AL or fiberglass sleeves to turn those front shock housings into air foils, along with something similar for any exposed tubular shapes.
John
This is the info I need to push me into action as I have been thinking on making aerodynamic shields for in front of the suspension fork and down down tube behind the front wheel.
I will definitely make the tube fairings now that I know they will reduce their drag upto 3x
not sure if I will but thinking of making a coroplast rear wheel fairing that starts at the seat tube and surrounds the rear wheel so its a full fairing fender.
eCue   10 kW
Post by eCue » Feb 06 2018 7:53pm
I tried to fix the photos logged out and could view them so Im thinking they are visible now. A aero shield should help about every circumstance Im thinking anyways. I know they would not be allowed in competition :D
big bulky aero shields are not needed imo a bullet head is good enough :D
wturber   10 MW
Post by wturber » Feb 06 2018 8:00pm
I can view the photos now.
eCue   10 kW
Post by eCue » Feb 06 2018 8:20pm
Nice , thanks for letting me know I had no clue.
eCue   10 kW
Post by eCue » Feb 06 2018 8:52pm
Im finding at 30 to 40k the air hits the shield and keeps going off in the direction it was headed. It does not turn back in on you like at highway speed . As it is I search around with my nose to find the air stream as its send off and around. Despite being a small fairing it does not perform small at low speeds.
On a sunny day i will take photos of the garden hose spraying it
Papa   1 kW
Post by Papa » Feb 06 2018 10:13pm
Non transparent farings are a real bad idea - especially in a tuck when it's most beneficial.
~ Recycle... Ride your bike again ~
wturber   10 MW
Post by wturber » Feb 06 2018 10:34pm
Papa wrote:
Feb 06 2018 10:13pm
I guess it depends on how high your head is and such. It looks to me like you can sight down the slope of that fairing and not have your view obstructed any more than my my front basket.
Here's a "cafe racer" fairing that costs a mere $35. I'd have to raise my headlight to make it work on my bike and basket tho.
eCue   10 kW
Post by eCue » Feb 06 2018 10:48pm
Motorcyclists and bicyclists have a lot in common both benefit from wind protection and both require unhindered vision.
You will find the 9 out 10 Motorcyclists cut their windshield down with in 1 week of putting it on.
Why ? because they cant see clearly through it nor can I they suck. First thing I do with a motorcycle windshield is cut it or take it off. As do 95% of Motorcyclists. The remaining 5% don't last long :mrgreen:
Don't listen to Naysayers who pretends to know topics :D Obviously he does not know what he talking about , some people like to pretend. The beauty of a fairing is you look over it. Its NOT A WINDSHIELD lol
eCue   10 kW
Post by eCue » Feb 06 2018 11:15pm
Thing with the fairing is the normal riding position is wind protected tucking down becomes unnecessary. The fairing allows you to ride a regular position and enjoy the scenery heads up.
eCue   10 kW
Post by eCue » Feb 06 2018 11:21pm
I have a idea , a kids Halloween captain America shield , painted to match the bike. :D Im trying...
About all i come up with is to add domed front shield
