Cycle Analyst V3 preview and first beta release
amberwolf   100 GW
Re: Cycle Analyst V3 preview and first beta release
Post by amberwolf » Apr 24 2012 3:12pm
miro13car wrote:So how accurate it is after you enter correct wheel tire curcumstance
For a while I had both the CA and an old bike computer on CrazyBike2, same wheel size set in both, and readings were the same on each one for distance. The bike computer only read out in 0.5MPH increments and was very slow to display changes in speed, so I am not sure how comparable the speed display was--it always was close, but with the lag in display I couldn't always tell for sure. Can't recall the name of the BC right now, but there should be pics of it in my CB2 thread starting about September 2010.
miro13car   1 MW
Post by miro13car » Apr 24 2012 10:10pm
I like to have seperate speed measuring device and Cateye is dead accurate after entering right circumvence.
It is not cheap computer /$35 minimum/ and shows speed in 0.1 km/h increments so not all BC are cheap crap.
It has to be measured with measuring tape on tire compressed under load of rider NOT just entered from the chart in manual.
So you say CA sampled speed much more often?
Couldn't you just measure distance? Did they shaw the same distance?
justin_le   10 MW
Post by justin_le » Apr 25 2012 12:32am
miro13car wrote: So you say CA sampled speed much more often?
In the CA you can set the display refresh rate for most items between 0.025 to 1.6 seconds. However, the speed is asynchronous from this setting and is updated instantaneously with each wheel revolution. On the V3 CA beta firmware, it's actually updated at each pole pulse at the moment, so with a hub that has 23 poles that means a very snappy feedback on the speed reading but it also means the numbers can move faster than you can read them, so I'll likely slow this down.
As with all bike computers, the distance and speed accuracy are just a function of how accurate you are able to know your wheel size, which you can tweak up and down to get the result you want. It's a rather moot question. -Justin
Previously competed in the Suntrip race on a back to back tandem solar powered row/cycle trike. 550 watt solar roof, dual Grin All Axle hub motors, dual Phaserunner controllers, 12 LiGo batteries, and a whole wack of gear.
Now back in Vancouver learning to be a dad with my Big Dummy Frame (yes This One, thanks ES!) with GMAC 10T rear hub motor, Phaserunner controller, and 52V 19Ah EM3EV pack
My website: http://www.ebikes.ca
Please contact via email, info@ebikes.ca, rather than PMs, which are disabled
justin_le   10 MW
Post by justin_le » Apr 25 2012 12:37am
hjns wrote:Hi all,
I am trying to hook up my CA v3. I am runnng 30S 126V HOC.
For that, you should be OK connecting it up directly. Max voltage that the CA will display with the current resistor values is ~150V, so 126V off the charger will be alright. But for the production run we are considering changing the stock divider for 100V max, which gives better accuracy of the more normal ebike voltage range and encourages people running higher voltages to be safer in the installation and not send that directly to the handlebars.
-Justin
amberwolf   100 GW
Post by amberwolf » Apr 25 2012 1:56am
miro13car wrote:So you say CA sampled speed much more often?
I have no idea if the speed was sampled any different, but the *display* was updated much less often on the bike computer.
I'll refer you to my post for that answer:
amberwolf wrote:readings were the same on each one for distance.
BTW, I checked, and the bike computer is a Vetta Innovator C100:
probably from the late 1980s or early 1990s. No idea if it's a great unit or crappy one; it came on the Nishiki when I got that at Savers for I think $20. It is so old that they don't have a manual on the website anymore for it, or any similar unit.
http://www.vetta.com/Instruction-Manual
hjns   100 kW
Post by hjns » Apr 25 2012 3:34am
justin_le wrote:For that, you should be OK connecting it up directly. Max voltage that the CA will display with the current resistor values is ~150V, so 126V off the charger will be alright. But for the production run we are considering changing the stock divider for 100V max, which gives better accuracy of the more normal ebike voltage range and encourages people running higher voltages to be safer in the installation and not send that directly to the handlebars.
-Justin
Great, exactly what I need. Thanks for the quick response!
Henk
All men dream: but not equally. Those who dream by night in the dusty recesses of their minds wake in the day to find that it was vanity: but the dreamers of the day are dangerous men, for they may act their dreams with open eyes, to make it possible. T.E. Lawrence
miro13car   1 MW
Post by miro13car » Apr 25 2012 11:18am
The question was how accurate was CA speed reading
I tried 2 $8 bike computers and no matter how accurate you enter
tire cucimvence still reading not even close to GPS.
So not so moot simple is not only matter what you enter but what alogartm
they use to calculate, right?
I understand for speed reading you still use magnetic pick up.
On newest CA?
Why do mention poles of motor?
oatnet   10 MW
Post by oatnet » Apr 25 2012 11:33am
miro13car wrote:I understand for speed reading you still use magnetic pick up.
On newest CA?
The CA can use either a magnetic pickup in the standalone or speedo version, or get the signal from the hall sensor in the the direct-plug version. The questions you are asking can be answered with a quick RTFM, this site lays out what the CA is and does:
http://ebikes.ca/drainbrain.shtml
Here is the actual manual:
http://ebikes.ca/drainbrain/CA_Large_V223_Web.pdf
Member 117 of 26,000+
153v DUNE BUGGY © 164v Vectrix E-Moto © 72v Norco A-line/x5403 © 60v Specialized Enduro Comp/BMC © 72v x5tracycle © 48v TF IO/BMC © 36v Kepler FrictionDrive © Spot-Welding a123 © Pelican Front Packs © Vectrix Battery Replacement © MORE !!
Image大鸡巴 Motors
Knowledge is acquired through experience, everything else is just information - Albert Einstein
"Cheater?" I'm not competing, I'm Commuting!
Tench   100 kW
Post by Tench » Apr 25 2012 12:28pm
All versions of the CA can be wired either for a speed signal from the motor or the external wheel speed sensor, 2 minute job to switch from one type to the other.
Project one http://endless-sphere.com/forums/viewto ... ilit=tench
Project Two http://endless-sphere.com/forums/viewto ... =6&t=37489
The uk's first Stealth Bomber
There is a box inside your head, inside amongst others are the words "Wont fit" stop looking for answers in the box, there are no answers only excuses.
teklektik   10 GW
Cycle Analyst V3 - Unofficial User Guide / User Manual
Post by teklektik » Apr 25 2012 3:06pm
    UUG Files orig
>>> Subscribe to this thread to be notified of new firmware and Guide updates! <<<
Tench   100 kW
Post by Tench » Apr 25 2012 4:46pm
I have just wired mine in, i get the throttle slider going up and down but no motor? :shock: i have set the ramp down to 001 so i will go and change that. I only have the DP connector between CA and controller, do i need to use the original controller throttle input wire? I am seeing over 4v on the green wire in the DP connector with a closed throttle so i presume the controller has shut down because the start voltage is too high on the throttle wire, or am i wrong? :(
I have set the voltages for input and out put below the actual min throttle output and the actual voltage the controller needs to start, i didnt know i could read them from the CA so i can do that aswell.
Been and made some adjustments,,
My throttle min output voltage is 0.85v so i set the min input to 0.87v
max input displayed by the CA is 4.19 so i set this to 4.10v
Min out put is set to 1.40v as i know the controller does not start til just above this voltage (even tried stting this to 0.40v)
Max out put is set to 4.10v.
Ramp up set to 500, ramp down to 999.
When i look at the throttle display screen, if i just open the throttle a little the bottom left read out starts to rise untill it max's out even with the input voltage only showing 0.9v, is this correct?
I still dont have any drive, i have the tried speed and current settings aswell as pass through, no drive? what am i doing wrong?
I should stick to hammers and welding!! :D
Simon.
lizardboy   10 mW
Post by lizardboy » Apr 25 2012 6:26pm
Got mine and starting the wire up.. Where do the wheel sensor leads go? The rpm inputs I guess? And the the throttle just wires to the cycle analyst and not to the controller?
I had an idea which I've yet to check out but could the programmer that Lyen supplied with my controller be used, with a wiring adaptor to do the firmware updates? Gonna beep out the wiring and report back.
Darrin
teklektik   10 GW
Post by teklektik » Apr 25 2012 6:27pm
Tench wrote:I only have the DP connector between CA and controller, do i need to use the original controller throttle input wire?
Yep. The problem is that pin 6 on the DP connector is Throttle Out on the CA side but Throttle Override on the controller side, that is, the controller is only using the voltage in a 'limiting' capacity...
The DP connector (pin 6 - green wire) is connected to the CA PCB ThO pin (Throttle Out). This is tied inside your controller with a resistor and diode to cause the external DP throttle connection to operate as a current sink to pull down (limit) the real throttle input to the controller - current flows out of the controller during limiting and any apparent voltage on the green DP lead cannot flow in to drive the controller. See section 7.1 of the v2.23 CA Manual. You need to get around this current sink limitation - at the moment, you have no controller throttle input so motor no go...
Pin 6 is really 'Throttle Out' on the CA but 'Throttle Override' on the controller
Assuming that your real throttle leads are tied to the three adjacent pads +5/Thi/Gnd (Throttle In) on the CA PCB, start simple and configure ThrI->CntrlMode = Pass-thru. Next you have a few choices:
EDIT - see the detailed instructions by Justin in this post.
Tench wrote: I am seeing over 4v on the green wire in the DP connector with a closed throttle...
This does not sound good - with the throttle closed you should be seeing the configured value ThrI->MinInput on that pin. Before you do any of the above, fix all the configuration settings and look at the real time voltage display. You should see Vi track your real throttle as you turn it and Vo should show the re-mapped values between the Throttle Out min and max voltages you have set. A quick check on pin 6 of the DP connector should show the same Vo voltage.
teklektik   10 GW
Post by teklektik » Apr 25 2012 6:54pm
lizardboy wrote:Where do the wheel sensor leads go? The rpm inputs I guess?
No - if you mean the magnetic speedometer pickup, the leads go to Gnd and Sp (in place of the yellow wire from the DP connector). However, unless you have a gear motor you don't need the speedometer pickup - the DP connector supplies pulses from the halls in the motor but with a gear motor and clutch, the motor and bike speeds can be unrelated so you need the pickup.
lizardboy wrote:And the throttle just wires to the cycle analyst and not to the controller?
Yes.
lizardboy wrote:I had an idea which I've yet to check out but could the programmer that Lyen supplied with my controller be used, with a wiring adaptor to do the firmware updates?
The mini audio connector attached to the CA (Tx/Rx/Gnd connections) can drive an Analogger or can be used with a simple TTL->USB converter to do firmware updates. Not sure what Lyen supplies but an appropriate adapter is available from ebikes.ca.
Tench   100 kW
Post by Tench » Apr 25 2012 6:58pm
Thank you very much, so if i take the green wire off the CA board and run one from that pad to my controllers original throttle input wire it should all work?
Tench   100 kW
Post by Tench » Apr 25 2012 6:59pm
Thats what i did with my wheel speed sensor wires, one to SP and one to G, that works fine.
teklektik   10 GW
Post by teklektik » Apr 25 2012 7:35pm
Okay - a little cross-posting going on :D
Here's some catch-up:
Tench wrote:Been and made some adjustments,,
Sounds good - to summarize:
ThrI -> Cntrl Mode = Pass-thru (yes?)
ThrI -> Min Input = 0.87 Volts to ensure no output with closed throttle at 0.85
ThrI -> Max Input = 4.10 Volts so actual throttle voltage (4.19) will guarrantee max output
ThrO -> Output Mode = Voltage
ThrO -> Min Output = 1.40 Volts
ThrO -> Max Output = 4.10 Volts
Tench wrote: When i look at the throttle display screen, if i just open the throttle a little the bottom left read out starts to rise untill it max's out even with the input voltage only showing 0.9v, is this correct?
This is odd. With the throttle closed, the screen should show Vi=0.85 Vo=1.40.
As you increase the throttle Vi should rise to 4.19 and Vo should rise to 4.10.
Your situation is outside my limited testing this afternoon - this one will need help from Justin...
teklektik   10 GW
Post by teklektik » Apr 25 2012 7:44pm
Tench wrote:Thank you very much, so if i take the green wire off the CA board and run one from that pad to my controllers original throttle input wire it should all work?
Exactly - you need that connection.
Your Vo level in your last post confuses me, but I'm just hacking this along with everyone else, so there may be other parameter interactions in play we haven't quite figured out yet that will explain the different Vo behavior between your unit and mine - it will all become clear soon I'm sure :).
Anyhow - make the throttle connection and see how it goes.
Cowardlyduck   100 MW
Post by Cowardlyduck » Apr 25 2012 8:26pm
I know it's probably a bit late for new features in this version of the CA, maybe for a future version.
Would it be possible to measure and display the current motor efficiency as a percentage?
I guess it would rely on the motor load being readable in some way.
I have no idea if it's technically possible, but thought it would be a nice feature if it is. :)
Cheers
My stuff:
Ebike Garage - My YouTube Ebike ramblings.
Cowardlyducks - Videos - Ride videos
BikeE recumbent commuter - 9C, 6Fet Grinfineon, internal 17AH, 52V, + on-board solar.
For Sale:
Custom made 18650/21700 battery packs - Australia only
High Power LiPo wiring harnesses - 4P - XT90, HXT4mm, 5.5mm. 200Amp+ capable. Global shipping.
lizardboy   10 mW
Post by lizardboy » Apr 26 2012 12:02am
Ok thanks I couldn't see the silk screening over there as it was blocked by a square yellow component. All is working great now. Used the yellow wire to send the throttle signal to the CA and the green wire to send it back to the controller Very neat. Thanks for the help
Tench   100 kW
Post by Tench » Apr 26 2012 7:39am
I connected the throttle output up correctly and all is well, it runs :D i have had a brief play but still need to spend some time experimenting with the ramp up and gains to find the best setup for my bike, the improvement in initial throttle action is well worth the cost of the V3, i can now ride as slow as i like in the lowest gear with brilliant control yet it still wheelies away if you want it to :D
shorza   1 kW
Post by shorza » Apr 26 2012 8:51am
Hey Justin, any idea when these might be off 'Beta'? I'm trying to figure out if it's worth buying one now, or waiting.
teklektik   10 GW
Post by teklektik » Apr 26 2012 11:32am
Tench wrote:I connected the throttle output up correctly and all is well, it runs :D i have had a brief play but still need to spend some time experimenting with the ramp up and gains to find the best setup for my bike...
Excellent news! I'll be doing the same tweaking myself today.
I updated the v3B12 setup notes based on the questions above so basic setup is a little more step-by-step. This isn't as good as doc from Justin but he's kind of overloaded - maybe this will help a bit until an official version can be produced...
hjns   100 kW
Post by hjns » Apr 26 2012 12:19pm
teklektik wrote:I updated the v3B12 setup notes based on the questions above so basic setup is a little more step-by-step. This isn't as good as doc from Justin but he's kind of overloaded - maybe this will help a bit until an official version can be produced...
Brilliant. In order to facilitate development of this "step-by-step-manual", I created a Google Docs Word document, to allow other people to contribute, because you should not be the only one "responsible" for this. If you and/or anybody who really wants to contribute to this can PM me your email address, I can give you editing rights. All people can leave comments, so the sporadic visitor can help out as well.
https://docs.google.com/document/d/1x8S ... uVRVU/edit
Maybe after exploring / explaining the most important stuff, we can submit it to the WIKI pages / create a nice printable booklet.
Henk
oatnet   10 MW
Post by oatnet » Apr 26 2012 2:38pm
Personally, I'll continue to refer to teklektik's post, because it keeps the data on E:S, and as a rule I avoid giving Google any more data than I have to. I don't see much point to porting knowledge off E:S and into a wiki someone else controls either.
Teklektik, thanks for the content you generated! :D
-JD
Image大鸡巴 Motors
