Cycle Analyst V3 preview and first beta release
ZeroEm   100 kW
Re: Cycle Analyst V3 preview and first beta release
Post by ZeroEm » Sep 26 2020 7:46am
by cnrd » Aug 04 2020 2:38am
Does anyone know if it's possible to set different speed limits for PAS and throttle?
I would like to set a lower speed limit on PAS, but still have extra speed available on the throttle.
Yes you can have different speed limits for PAS and the Throttle!
Here in Texas PAS can be up to 28 mph but Throttle only the speed limit is 20 mph. Different than what you want. Make sure regen is off or you will be pedaling and charging your batter when you hit the limits.
abundans cautela non nocet
2019 Performer E-Trike 9w/km
2013 Nissan Leaf S 7 bars 331.5w/KM
alexayala.ut   1 mW
Post by alexayala.ut » Sep 27 2020 11:45am
Djhandz wrote:
Sep 26 2020 7:02am
Hi all. Reading a few horror stories about people blowing there cycle analyst
Please can someone tell me if it's safe to use this pas sensor
https://www.ebikes.ca/shop/electric-bic ... p-chr.html
Plugged in to the pas plug on 10v running a 22s battery fully charged 92v
Will this setup be ok or do I need to reposition the 10v to the 5v inside the cycle analyst?
Thanks
At 92V, you have about 8mA for accessories, per the unofficial user guide. Typical hall throttle takes 5mA, typical PAS takes 10mA. With just these two, you're asking almost double the current the CA can provide. You need a different power source for the PAS. You could pull from the controller throttle +5V, or run a dc converter off the DC power output jack on the CA to the PAS.
Djhandz   100 mW
Post by Djhandz » Sep 27 2020 11:58am
Thankyou very much alexayala. Very understanding answer
I will get power from my controller throttle
Thanks again dude
HrKlev   100 W
Post by HrKlev » Sep 29 2020 2:03am
justin_le wrote:
Sep 23 2020 6:09pm
HrKlev wrote:
Aug 03 2020 3:30pm
Is there any reason why the "electric freewheel" feature that is inlcuded in the Phaserunner controllers is not implemented in the Cycle Analyst?
This is a great question and was actually on the CA3 roadmap for a while, but we decided to pull it from the list. As NCC1941 pointed out, the CA3 only sees your battery current, not your phase current. At constant phase current the battery current is almost 0A at low speeds and then linearly increases until reaching your actual phase amps once you get near the unloaded cruising speed. It is possible for the CA3 to emulate this behavior and have a setting that is a fixed watts/kph, so as you go faster then it will inject proportionally higher watts even with the throttle off. But even with that algorithm in place it there were also the following two problems:
a) Many motor controllers do not behave well at all when you try to command a very low wattage from them in a constant watts by modulating the throttle. and
b) Many setups have lights, DC-DC converters, and other accessories powered by the CA in a way that the CA also shows the watts of these accessory components. So then if you flip on your headlights or blast a horn or whatever it could add some 10's of watts to the CA's power reading which it couldn't distinguish from watts going into the motor which would mess up this behavior.
Thanks a lot for the in-depth explanation. It makes a lot of sense. I am enjoying the feature on a phaserunner controller now :)
I lnow the CA is a little limited now, but Im just throwing an idea out here; Would it be possible to implement a EMTB mode/ torque mode? It is a mode for tecnical terrain where the output relies on the torque input from the BB torque sensor, and not torque and rpm combined. Im getting pretty much the behavior as I want with setting the avg pole to 1, and fast PAS ramps, but a torque mode would be icing on the cake. Assist from zero rpm would also be very useful when not using a throttle (not allowed here, unfortunately). Maybe in a new version in the future if its not possible with todays HW?
Edit: So I just realized after I wrote this.... Since Im not using throttle, maybe I could just split the 0-5v signal from the torque sensor to the throttle input and set up one of the presets to be throttle input only. That should get me torque mode with assistance from 0rpm, and I could adjust the throttle input ramping to get the desired behaviour.... hmm....
DIY lightweight mid drive with torque sensing build thread: viewtopic.php?f=6&t=107622
justin_le   10 MW
Post by justin_le » Sep 29 2020 3:23am
HrKlev wrote:
Sep 29 2020 2:03am
Yes, actually more to the point I'm strongly considering in the next update that we just drop the watts/Hwatt scaling factor and have it instead be Watts/Nm. This is actually the original implimentation of the CA3 way way in the early beta/alpha firmwares. It was switched over to being W/HW because we thought that would be a more straightforward parameter for people to understand (oh, it just doubles my power), but I think most people would prefer if the motor power scaled linearly with pedal torque regardless of RPM. Then the RPM is just an on/off gate, and it makes it easier to have torque assist at 0 rpm, and if after like half a second ifthere is still no pedal cadence detected then it would shut off the PAS. Probably not in 3.15, but likely in 3.2.
You can absolutely do this. And you can actually do it even with a throttle too by just parallel connecting the analog signals together. The throttle can't pull down but it can pull up which means you don't need any diodes for this. Just put like a 500 Ohm resistor between the torque signal and the throttle input while the throttle signal connects directly. If you don't use the throttle, the signal will come from the torque sensor, and if you do use the throttle then it will generally read the higher of the torque or the throttle signal.
Previously competed in the Suntrip race on a back to back tandem solar powered row/cycle trike. 550 watt solar roof, dual Grin All Axle hub motors, dual Phaserunner controllers, 12 LiGo batteries, and a whole wack of gear.
Now back in Vancouver learning to be a dad with my Big Dummy Frame (yes This One, thanks ES!) with GMAC 10T rear hub motor, Phaserunner controller, and 52V 19Ah EM3EV pack
My website: http://www.ebikes.ca
Please contact via email, info@ebikes.ca, rather than PMs, which are disabled
HrKlev   100 W
Post by HrKlev » Sep 29 2020 6:53am
justin_le wrote:
Sep 29 2020 3:23am
Very, very interesting! Just a note from a tsdz2 equipped bike I had where I could choose pure torque lode; It was very hard to maintain a high cadence when I was cycling on a normal road. It might be something with the torque sensor or the motor, so maybe it is not applicabke at all.... But it was a lot easier with power mode. So maybe have a way to switch between the modes?
justin_le wrote:
Sep 29 2020 3:23am
Awesome! Sorry for being such a electronics noob (I have no idea what that resistor does :lol: )... do you mean like this?
Im really excited how this will turn out. The electronic freewheel feature makes the mid drive system so responsive, and with a torque mode in addition I think it will be even better for the technical stuff.
DtiK   1 W
1 W
Post by DtiK » Oct 03 2020 3:40pm
Is there possibility to get somewhere Grin tech stickers? 8)
ZeroEm   100 kW
Post by ZeroEm » Oct 03 2020 10:26pm
I want one, throw it in my next order :wink:
michaelkramer11   1 W
1 W
Post by michaelkramer11 » Oct 07 2020 10:43pm
Please Help?!
Sorry if this has been mentioned or discussed before, but i've been dealing with this problem for years and i've finally decided to look for answers.
I got my cav3 dp back in 2014 and for as long as I can remember I've had sporadic screen cutouts/random characters flash on the screen or the screen will just go blank. It continues to operate when the screen cuts, so it hasn't been a total loss, but I know these products don't typically have these issues. The backlight also stays on the whole time so I know its not losing power. I did wire this unit into a controller purchased off of ebay but i'm quite certain the problem is in the CA.
I'm running 16s lipo's and i feel like the handful of times that I've powered up without the pre-charge circuit could be to blame? Is there anywhere to look for diagnosis/fix tips?
wal mart "next" brand bicycle, yescom rear 1000w kit, 16s15ah turnigy lipo's, greentime 72v45amp controller
grizzlymann   1 µW
Post by grizzlymann » Nov 16 2020 2:20pm
It looks like the attachment for the Unofficial User Guide might have been removed. Does anyone have a copy or could restore the file?
amberwolf   100 GW
Post by amberwolf » Nov 16 2020 11:01pm
Just be aware that Teklektik is likely to ream a new asshole in anyone that actually posts it, as he did me some years back when I attempted to help everyone by copying it to the archival Tech forum here, and insisted that *only* links to his single post of the file (that apparently now no longer exists) were allowed. He was quite strongly and angrily rude about it.
In a quick search, I couldn't find another post of his that contains the file, so unless he's not going to light into people for reposting it now that it is gone from there, I dont' see any other way to get it back, as there's no file to link to now.
john61ct   100 GW
Post by john61ct » Nov 16 2020 11:06pm
Wayback Machine at the Internet Archive?
Santacruz   10 W
Post by Santacruz » Nov 17 2020 5:01am
Both the official and unofficial are available on Grins site under Cycle Analyst
amberwolf   100 GW
Post by amberwolf » Nov 17 2020 11:50pm
I only see a link to this thread for the UUG on the CA info pages at Grin's site.
Santacruz   10 W
Post by Santacruz » Nov 18 2020 3:02am
amberwolf wrote:
Nov 17 2020 11:50pm
My appolgies.
It was only a few weeks ago that I downloaded the UUG. I see now that it is not available.
So, disregard my post, it is obviously wrong.
But, Grin should remove it from their site, I think.
john61ct   100 GW
Post by john61ct » Nov 18 2020 10:43am
5sec google found the B22 version, is that latest?
https://www.google.com/search?q=Grins+C ... unofficial
john61ct   100 GW
Post by john61ct » Nov 18 2020 10:57am
Looks from Wayback, latest version was
document version 3.0-e
2016.02.16
teklektik
Found this at a German site fasterbikes.eu
CaV3-Anleitung-Endless-SphereojLDyj5SH3bt5PfU69hV2rlPoH.pdf
https://www.google.com/search?q=CaV3-An ... 2rlPoH.pdf
Made a backup https://drive.google.com/file/d/1635vQM ... p=drivesdk
EddySPalm   100 W
Post by EddySPalm » Nov 23 2020 8:48am
I have, in two different ways (which I don't intend to reveal as I don't want to destroy my reputation on the forum :lol: ) burnt the PCB/main PIC of my CA's.
I am now currently on my third PCB. I choose to desolder the pads as this is quicker than rerouting the wires through my old Vespa frame again. The newest CA PCB I have which I am now soldering to, is missing a whole bunch of solder pads, including the thermistor pads.
being able to monitor temperature was actually one of the key features I wanted in my CA. Now I'm "stuck" with two loose wires inside the CA which don't have anywhere to go. or do they? Did Grin do something to their PCB that allows me to solder them elsewhere?
I cannot find any info that refers to the "sudden" lack of solder pads on the newer PCB's. Wherever I find info on how to convert CA's from one type to another, it says that all PCB's are the same, so you can convert to and from anything you'd like.
I have asked Grin in an e-mail also, but half of my e-mails remain unanswered, and I am really eager to get going on this project...
HrKlev   100 W
Post by HrKlev » Jan 04 2021 3:15pm
justin_le wrote:
Jun 03 2020 3:25am
Agreed. We will aim to support inputting higher PAS pole capabilties in future releases.
Any news on this, or other smart workaround? I have a 36 pole torque sensor on one of my bikes. Im using 18 pole setting for now, and just use half the assist numbers and divide all the statistics in 2. It works kind of OK, but one of my favorite things with the CA is all the data you get instantly, and when the numbers are not what they really are it is quite annoying :p
Allex   1 GW
1 GW
Post by Allex » Jan 24 2021 5:44am
Why cant I set a shunt value lower than a 0,767 on CA?
My shunt is 0,5mOhm
DanGT86   100 kW
Post by DanGT86 » Jan 24 2021 10:20am
You need to switch over to high range mode for shunts under .8mOhm
Page 28 of the official users manual
"Most high current shunts will be less than 0.8 mOhm and the Cycle Analyst must
be set to High Range (0.1A) mode to accomodate them. The High Range mode
will show power in kilowatts instead of watts, and current to the nearest 0.1A
instead of 0.01A."
https://www.ebikes.ca/pub/media/downloa ... 31_Web.pdf
qwing   1 µW
Post by qwing » Jan 29 2021 2:37pm
EddySPalm wrote:
Nov 23 2020 8:48am
Just ordered Phaserunner and CA and one reason is the temp. sensor. I‘m pretty sure, the input is still available. Will come back as soon as I got the stuff.
Cheers
Qwing
