Typical POWERFULL Doctorbass ebike wiring 5-10kW+
Archive of useful information. This is not a discussion area.
Doctorbass   100 GW
Post by Doctorbass » Sep 08 2012 1:39pm
-It protect your charger and BMS from reverse polarity
-It allow the cycle analyst to count the charged Ah
-No KFC risk... the fuse just blow
-no complicated main connection when using or charging the battery
- give you 12V for LED lamp, fan blower, or to power the low voltage rail of your kelly controller, etc
- allow to use a low current switch
The EV200 are availlable on ebay for about 40-50$ and can take up to 500A and 900Vdc and only consume 1.7watts with their integrated coil economizer.
The Dc-DC can be a simple 12V 5A switching power supply availle on ebay for about 10$
Doc
Doc typical electrical wiring on ebike.JPG (136.14 KiB) Viewed 3960 times
CURRENT PROJECT: 2WD duo MXUS/Max-E ebike 32kW
http://endless-sphere.com/forums/viewto ... =3&t=65764
-Fastest speed record 117 km/h on flat
-Fastest 1/4 mile@ 114km/h on flat and 16.316 sec
113kmh Gianthttp://www.evalbum.com/3406
Mongoosehttp://www.evalbum.com/1947
YOUTUBE---https://m.youtube.com/user/Doctorbasss
I speak FRENCH and english
