3D Cad Software
Archive of useful information. This is not a discussion area.
TylerDurden   100 GW
3D Cad Software
Post by TylerDurden » Sep 21 2013 8:25am
Lotta software out there... some is free, some is useful...
Here is a newcomer that might be both, depending on your needs.
http://www.designspark.com/eng/page/mechanical
It is direct-editing, similar to Sketchup:
UN-like Sketchup, it outputs some useful filetypes:
It will import STEP files, but not export them.
If you're on a tight budget, Designspark Mechanical might be suitable.
I downloaded it (450MB) but, I haven't tried it yet.
Update:
Tried it a bit... quite nice for a free 3D application.
This is not exactly "new", this is a spinoff of Spaceclaim.
http://www.deskeng.com/virtual_desktop/ ... #more-7531
Have a Nice Day,
TD
___________________________________________________________
FYI: Adding pictures?
Bored?... take a crack at the unanswered posts
Please post your Watts-at-speed in the survey.
TylerDurden   100 GW
Re: 3D Cad Software
Post by TylerDurden » Sep 25 2013 8:47am
Here's another:
http://solvespace.com/index.pl
From the site:
  • Release 2.0 is available for download, now as GPL'd free software.
    SOLVESPACE is a parametric 3d CAD program. Applications include:
    modeling 3d parts — draw with extrudes, revolves, and Boolean (union / difference) operations
    modeling 2d parts — draw the part as a single section, and export DXF, PDF, SVG; use 3d assembly to verify fit
    3d-printed parts — export the STL or other triangle mesh expected by most 3d printers
    preparing CAM data — export 2d vector art for a waterjet machine or laser cutter; or generate STEP or STL, for import into third-party CAM software for machining
    mechanism design — use the constraint solver to simulate planar or spatial linkages, with pin, ball, or slide joints
    plane and solid geometry — replace hand-solved trigonometry and spreadsheets with a live dimensioned drawing
(I've not tried it yet.)
Have a Nice Day,
TD
