Question re Cycle Analyst (V2.3)
kiwipete   100 mW
Post by kiwipete » Feb 21 2014 5:24pm
I have a MTB with a standard MAC kit with the 25A 6Fet controller.
I also recently purchased the Cycle Analyst V2.3 (also from cell_man) and I'm pretty happy with it.
One thing doesn't seem to be working properly though: I've set the CA Max Amps to limit the amp to 15A. Yet after a ride Ive seen AMax values of 19,20 and 22A. So it doesn't seem to be working.
Any ideas?
captain387   100 W
Re: Question re Cycle Analyst (V2.3)
Post by captain387 » Feb 21 2014 6:46pm
The C.A. amp limit has a slight delay in cutting back the power. Anytime you need high current such as taking off from a dead stop or even when you try to accelerate quickly while moving the peak amps can go beyond the set point but will quickly return to the set parameters.
04 Norco Atomik - Cycle Analyst - Hs3540 - 40amp Infineon Controller - 12s2p 5.8 Ah Turnigy Lipo
95 GT Timberline FS - Converted back to pedal only.
teklektik   10 GW
Post by teklektik » Feb 22 2014 12:05pm
See the CA 2.3 Manual sections: 7.2, 7.3, 8.9, and possibly 8.11, 8.12.
Some overshoot is normal (yours seems acceptable), but excessive overshoot or 'hunting' may benefit from tweaking AGain and possibly ITermMin and ITermMax.
Wishes   1 kW
Post by Wishes » Feb 23 2014 9:52am
captain387 wrote:The C.A. amp limit has a slight delay in cutting back the power. Anytime you need high current such as taking off from a dead stop or even when you try to accelerate quickly while moving the peak amps can go beyond the set point but will quickly return to the set parameters.
In the CA's settings, you can actually tweak that delay in response for the amp limiter. Reducing the delay can lower the overshoot . Mine is set to 39 amps and over shoots to 43 under specific situations. 15 amp to 22 amps seems a little high overshoot.
Wishes
Equality is about providing everyone with equal opportunities, it is not about guaranteeing equal results.
1st Build GNG Mid-Drive Kona http://endless-sphere.com/forums/viewto ... 28&t=52029
2nd Build, Stong GT-S210 modified with 5kw hub motor http://endless-sphere.com/forums/viewto ... =7&t=58056
