Motor comparison spreadsheet
Miles   100 GW
Post by Miles » Jan 01 2015 12:10pm
Developed from the ideas discussed in this thread:
http://www.endless-sphere.com/forums/vi ... 23#p980223
All columns are in protected mode, apart from the columns with white background ("speed" and "torque output" columns), but no password is needed to remove the protection.
Latest versions:
Motor Data V4.33.ods
(64.97 KiB) Downloaded 1226 times
Motor Data V4.33.xls
(257.5 KiB) Downloaded 816 times
Miles   100 GW
Re: Motor comparison spreadsheet
Source - Reference for the source of the data inputted, be it personal testing or publicly available data.
Motor - Reference for the specific motor, including the number of winding turns, if known.
Slot - Number of slots or teeth. For most brushless motors this number will be divisible by three.
Pole - Number of magnet poles. This is usually the same as the number of magnets but sometimes a magnet pole will be segmented and contain two or more magnets of the same polarity. The segmentation can be circumferentially or axially, or both. In all cases the number of magnet poles will be divisible by two.
Gap - Diameter of the airgap between the stator and the rotor, measured at the middle of the gap. If you know the dimensions of the stator it's usually accurate enough to add 1mm to the outer diameter for outrunners or subtract 1mm from the the inner diameter for inrunners.
Stck - Stack height or length of the laminated core.
Gap A - The area of the airgap in square centimeters, calculated from the figures in the previous two columns.
Mass - Mass or weight of the motor in kilograms.
T.B.C.
Miles   100 GW
Res.
teslanv   100 MW
Post by teslanv » Jan 01 2015 12:47pm
subscribed.
DD Hubs, Batteries, Controllers & Custom Ebikes.
http://westcoastelectrics.com
West Coast Electric Cycles
Bellevue, WA
USA
Miles   100 GW
Post by Miles » Jan 03 2015 6:14am
Do you think it would be useful to have a column for peak efficiency at the chosen speed?
John in CR   100 GW
Post by John in CR » Jan 03 2015 1:14pm
Miles wrote:Do you think it would be useful to have a column for peak efficiency at the chosen speed?
Sure, but include the power too so it has more meaning.
Miles   100 GW
Post by Miles » Jan 03 2015 1:57pm
Will do that.
John in CR   100 GW
Post by John in CR » Jan 04 2015 11:50am
Miles, I was looking at your motor's phase resistance. Is that correct? If so, are you sure you're not skimping too much on the copper to obtain such low iron losses. It seems like the end result will be extremely high efficiency at cruise with very low cogging, so you'll barely feel the motor if pedaling unpowered and regen braking can be part of the equation, which are great criteria. The compromise is increased losses during acceleration or the sustained loads of hills or strong headwinds, when higher current is required.
What peak power input are you planning? Based the rpm numbers, it looks like a 74V pack, so does that mean single digit current limits?
An approach that intrigues me for a European or Australian street legal ebike is one capable of efficiently delivering full legal limit power even at very low rpm and the controller limiting it to legal power across its operating range.
Miles   100 GW
Post by Miles » Jan 04 2015 1:03pm
John in CR wrote:Miles, I was looking at your motor's phase resistance. Is that correct? If so, are you sure you're not skimping too much on the copper to obtain such low iron losses. It seems like the end result will be extremely high efficiency at cruise with very low cogging, so you'll barely feel the motor if pedaling unpowered and regen braking can be part of the equation, which are great criteria. The compromise is increased losses during acceleration or the sustained loads of hills or strong headwinds, when higher current is required.
Hi John,
The phase resistance can only be interpreted in the context of the torque constant..... Of course it's only a simulation but note that my design has the highest specific Km of all the motors on the chart, so far. Which is precisely what I was aiming for :)
I did quite a lot of experimentation varying the loading of the electrical circuit against that of the magnetic circuit and I think I'm pretty much where I want to be with that.
Running it at 2400 rpm, which is the intended speed for this iteration, the efficiency is 94% for 1355 Watts output and the peak efficiency is 95.4% for 680 Watts output.
If I wanted to run it at 6000 rpm, the iron losses would still be manageable.
NB Just to be absolutely clear, the figure in the sheet should be the phase to phase resistance not the phase resistance.
Miles   100 GW
Post by Miles » Jan 04 2015 1:23pm
John in CR wrote:An approach that intrigues me for a European or Australian street legal ebike is one capable of efficiently delivering full legal limit power even at very low rpm and the controller limiting it to legal power across its operating range.
It's a reasonable idea but I'm not sure it would pass the testing criteria..... The European power limit is for continuous power capability. So, what limit would you set?
John in CR   100 GW
Post by John in CR » Jan 04 2015 1:41pm
Whatever the law said, and hopefully it's continuous power out, not power in. It would require something different in the way of controller, but the legal power limit at something like 10-20rpm would be tremendous hill climbing torque.
John in CR   100 GW
Post by John in CR » Jan 04 2015 2:29pm
Hi John,
Ah ok, at 20A it still looks great. The .166 ohms just took me by surprise, but you could always wind it for a Kv of 70rpm/v if you wanted to run higher power. Then the copper resistance is much more comparable to the Joby.
It will be interesting as we get a big population for your spreadsheet. We'll see different ways to skin the cat. To me efficiency is the "great equalizer" much more than Km, because it makes motors of all types and sizes comparable. I do love those super low iron losses that resulted from you targeting Km though. I want ridiculous power, but don't want to give up silence, so that means a bigger motor to keep the rpm down and very low resistance.
Miles wrote:NB Just to be absolutely clear, the figure in the sheet should be the phase to phase resistance not the phase resistance.
Yes, of course phase-to-phase.
amberwolf   100 GW
Post by amberwolf » Jan 04 2015 11:02pm
Even though they are discussed in the linked threads in the OP, it might be useful to have a post in this thread with the specific step-by-step instructions to measure what's needed for each column of data about a new motor to be added to the spreadsheet (for anything that isn't calculated by the spreadsheet from other columns).
Miles   100 GW
Post by Miles » Jan 05 2015 1:05am
Sure, I was planning to do this amber - that was the reason for reserving the subsequent posts. I'll try to make a start this evening.
amberwolf   100 GW
Post by amberwolf » Jan 05 2015 1:47am
Ah, ok. :) It'd certainly help people like me that get lost in long threads :oops: cuz I'd like to try to help by measuring any functional motors I happen to have around here.
cycborg   1 kW
Post by cycborg » Jan 05 2015 8:46am
amberwolf wrote:Even though they are discussed in the linked threads in the OP, it might be useful to have a post in this thread with the specific step-by-step instructions to measure what's needed for each column of data about a new motor to be added to the spreadsheet (for anything that isn't calculated by the spreadsheet from other columns).
Looking forward to Miles' writeup, but in the meantime Justin describes the basic measurements and calculations here:
1) Put a known current through a pair of phase wires and measure the voltage with a multimeter.
2) Measure RPM and no load amperage at full throttle at one voltage V1
3) Measure RPM and no load amperage at full throttle at another voltage V2
Kudos to Miles for putting this all in one place; this will be a great resource.
teslanv   100 MW
Post by teslanv » Mar 17 2015 11:58am
I have confirmed via inspection and testing on the MXUS 3000W Motors as follows:
21X3T Winding:
12.02 Kv
0.796 Kt (Nm/A)
0.072 Ohms resistance (Measured from end of base phase wire, (~1 meter Lead to Motor axle)
Weight (Bare Hub Motor): 9.0 Kg
Km (per Miles' Database Formula): 2.965
16X4T Winding:
8.9 Kv
1.073 Kt (Nm/A)
0.112 Ohms resistance (Measured from end of base phase wire, (~1 meter Lead to Motor axle)
No-Load Current at 50.2V: 0.6A, 447 RPM
Km (per Miles' Database Formula): 3.206
12X5T Winding:
7.2 Kv
1.335 Kt (Nm/A)
0.170 Ohms resistance (Measured from end of base phase wire, (~1 meter Lead to Motor axle)
Km (per Miles' Database Formula): 3.239
On the 3T Winding which I upgraded the Phase Wires, I have the following:
21X3T Winding:
12.02 Kv
0.796 Kt (Nm/A)
0.060 Ohms resistance (Measured from end of base phase wire, (~0.5 meter Lead to Motor axle)
Km (per Miles' Database Formula): 3.248
Bellevue, WA
USA
crossbreak   100 MW
Post by crossbreak » Jun 03 2015 9:55pm
Km constant is an interesting thing to compare torque production capability. A reduction drive does not reduce Rm but it increases Kt (as it reduces Kv). So Km get a lot larger (if a 10:1 reduction is used for example). sKm is Km/mass (specific Km). this value may stay the same (or could even be reduced), as a reduction gearbox increases over all weight
we could easily expand this spreadsheet with sKm values from existing drives! pure benchmark?!
Miles   100 GW
Post by Miles » Jun 04 2015 4:49am
Sure. In practice, we are doing this already when geared hubs are used for comparison.
Lebowski   1 GW
1 GW
Post by Lebowski » Jun 04 2015 7:34am
Miles wrote:Sure. In practice, we are doing this already when geared hubs are used for comparison.
long time no Miles ?
Miles   100 GW
Post by Miles » Jun 04 2015 7:57am
It's true. I haven't been very active on the forum this year.... Hope to start the first motor build soon, though :)
John in CR   100 GW
Post by John in CR » Jun 04 2015 8:58am
crossbreak wrote:we need a value for parasitic loss. like [Watts/rpm²]
We already have that...no-load current X voltage. The current is so low that copper losses are negligible, leaving just the parasitic losses. Measure the bare motor, and then again with wheel or gearing to get those parasitic losses at a given rpm.
Mile's spreadsheet goes further and computes the torque side of core losses.
marcexec   1 kW
Post by marcexec » Jun 04 2015 10:08am
Awesome idea. Just added a few minor details on the 80-100 and attached it.
I'd actually like to extend this to the physical dimensions and manufacturer specs similar to http://www.diyelectriccar.com/forums/sh ... #post61212 and put it into the wiki.
The table should maybe be an overview only, including the link to a detailed "motor fact sheet".
I don't want to derail this thread from the very detailed info here on the technology, so I started a new thread:
http://endless-sphere.com/forums/viewto ... 30&t=69970
your input would be very welcome
Motor Data V1.02.ods
(36.49 KiB) Downloaded 169 times
A motorcyclist is never late, Frodo Baggins. Nor is he early. He arrives precisely when he means to.
My Suzuki RF400 build: now with Enertrac MHM602 and 6kWh AESC modules protected by a Zephyr BMS
Renault Equation modded to 10S6P recycled laptop 18650s & 1kW controller.
Master of Electric Motor Selection: "Adopt a motor" (PM me if you have trouble editing)
All the gear, all the time!
crossbreak   100 MW
Post by crossbreak » Jun 04 2015 6:01pm
strange data. no load current should rise linearly, shouldn't it? It's all parasitic loss. which should rise with the square of rpm. So both no load voltage and current shall rise with rpm, doesn't they?
In the data given, no load current rises less than linearly
