48v for 2011 A2B Metro
Omohm   1 µW
Post by Omohm » Jan 19 2015 9:31pm
Hello--anyone have any advice or experience over-volting an A2B Metro? My original battery croaked and a buddy had a cheap 48v 22ah LiFePo which I tried to hook up to the second battery connector, without success. There are four power pins and a bundle of four tiny wires which do not appear to be connected with anything in the native battery pack. Hooking up the 48v lights up the speedometer but the throttle does not produce motion.
Any advice much appreciated!
Omohm   1 µW
Re: 48v for 2011 A2B Metro
Post by Omohm » Jan 21 2015 12:27am
Thanks very much for those leads--I'll check them out!
Gregory   100 kW
Post by Gregory » Jan 21 2015 12:45am
Pretty sure Ypedal tested his on a 48V Headway LiFe pack, and it worked.
1) x5305 Hub Motor in a 24" Sun rim with 10G spokes, Kelly 72601 controller, 74V 10Ah Turnigy LiPo 20C Battery and CycleAnalyst
2) Mac 10T rear hub in a 700C "comfort bike" 15S 5Ah LiPo, stock 28A Xie Cheng controller
3) 38" Longboard, Turnigy 6374, CC Mamba XL2 ESC
atom1025   100 W
Post by atom1025 » Jan 31 2015 12:14am
Thought this was the best place to put this since its recent. Two zippy 5s 8000mah packs fit perfectly into the stock a2b downtube battery box.
http://www.hobbyking.com/hobbyking/stor ... P_30C.html
Bashed Synergy Cycle runs
1800w peak, 31mph tops.
2004 Cannondale Jekyll with a MAC 10
15s 8ah lipo (2100w peak) 31mph tops.
Metro_E-cart   1 mW
Post by Metro_E-cart » May 25 2015 11:51pm
Hi Omohm,
I have the same issue with my A2B Metro Gen 2. Connected a 48V pack via the rear pack connector. LCD lights up but throttle shows no response.
Were you able to resolve your issue?
If so, could you please share the solution?
Thanks
