Leaf / leafmotor / leafbike high efficiency 1500w motor
neptronix   100 GW
Post by neptronix » Jan 28 2015 8:47pm
It's that time of year that i throw money at a new ebike product and test it to see if it lives up to the hype..
A couple members here mentioned that a few companies were offering 1500w rated hub motors for sale and i had to investigate.
reference threads:
http://endless-sphere.com/forums/viewto ... =3&t=65743
http://endless-sphere.com/forums/viewto ... =3&t=65793
Motor kit link:
http://www.leafbike.com/products/diy-bi ... t-987.html
Standalone motor link ( as of writing, shows incorrect graph, but still the same motor ) http://www.leafbike.com/products/e-bike ... l-991.html
These 35mm stator motors.. so they would be similar in dimensions as the Crystalyte HS35xx series of motors.
Stated efficiency seems to vary per vendor.. from a maximum of 80% to a maximum of 90%.
Leaf motor makes a claim about this motor as having higher grade laminations. I suspect this could mean ~0.33mm laminations, which would somewhat explain the high efficiency claim of these motors. They make a claim of difference in efficiency for their newer 1000W motor as well. So, i figure this may be legit
Here is the data on their new motor.
http://www.leafbike.com/products/e-bike ... r-998.html
So, i have ordered up the motor.. i asked for a 24mm internal width rim and they spoked it up at no additional cost, so that's cool. It's in transit and i should get it in a week or two.
Worst case scenario: This company is full of crap and it's really a 80% efficient motor. The motor is still useful, but i will talk crap about them eternally. The axle may be actually be 142mm since many of these companies aren't honest about that... we'll see.
Best case scenario: looking at the spec sheet, this motor's power would be understated by quite a bit. At 2000w input, it should be making around 200w of heat; that seems like a sustainable constant power level. I have something that is almost as powerful as a Crystalyte HS40xx and i pay myself on the back for being a first adopter.
More on this later.
edit: note after the fact:
If you order the default winding, the 4T..
For a 26" wheel, you will want a controller and battery capable of pushing 60 amps continuous during acceleration or hill climbing in order to hit the top speed of the motor and have decent torque.
60A x 48V = 2880W peak.
Your continuous wattage at 100% speed will be about 2000W, or approx. 41A continuous.
You'll want nothing smaller than a 12FET 4011, or preferably 3077 FET controller in order to do this. I run an 18FET 4011 controller myself with this winding, because i wanted large amounts of thermal overhead, as i run about 90-100 amps. Even the 12FET 3077 ( lowest resistance FET type is the 3077 ) would get hot on 80A.
For this winding, i would use either a RC Lipo type pack above 20AH or A123 pack around 20AH as well in order to deliver the needed current. 20C Lipo would work.
If you want something other than the two above chemistries, you're going to need 40-60AH worth most likely, if you're dealing with a 2C-5C chemistry. 1C is out of the question unless you can figure out how to jam 50-60AH into the triangle.
The 4T is an amp guzzler, not a volt guzzler..
Another note after the fact:
Here are some figures for speed per volt in a 26" wheel:
I measured my no load at 645rpm at 49 volts ( 13.16 kv ), so keep that in mind. By that math:
4T: 631rpm / 48v = 13.16 kv ( measurement by me, adjusted down 1 volt )
5T: 485rpm / 48v = 10.1 kv ( fluxshifter's measurement )
6T: 336rpm / 48v = 7kv ( assumption based on 3kV steps per winding )
Rough idea of 48v speeds in a 26" wheel:
4T: 39mph ( observed )
5T: 30mph ( calculated but not observed )
6T: 21mph ( assumed )
Efficiency is everything :bolt:
My first major build: 8T MAC motor on a Trek 4500.
The new all-arounder: Leafmotor 1500w on a Turner O2 full suspension.
The monster scooter: ? on a Cannondale Semi Recumbent.
madin88   100 MW
Re: Leaf / leafmotor / leafbike 1500w motor
Post by madin88 » Jan 29 2015 5:32am
hopefully you will get the 205 / 35H motor on the latest sheet. this looks not bad.
- 10kW belt drive with Neumotor 8057: viewtopic.php?f=30&t=91144&start=50#p1377787
- Fully road legal (L1E approval) e-bike based on Votec V-FR frame
/ MXUS 3T / 17" Mitas MC11 / Adaptto Max-E / 20s12p 25R
- KTM Hardtail Pedelec / eZee V2 6T / 27,5" / Kelly KBSX @ 1,5kW / Torque PAS / CA-V3 / 13s4p Sanyo GA in Shark case
neptronix   100 GW
Post by neptronix » Feb 04 2015 4:53pm
I just got the leafmotor 1500w model in the mail today and pulled it apart just now.. 0.35mm laminations, very tight windings ( way better than the 9c/crystalytes i've seen, 35mm wide stator, and it fits into a 135mm dropout. VERY IMPRESSED.. all signs point to this motor being more powerful than the crystalyte 35xx series and magic pie. More pics and data later!
TheBeastie   1 MW
Post by TheBeastie » Feb 04 2015 5:41pm
Cool.
Looking at those charts its great to see it has listed Nm (newton meters) for torque ability, I shouldn't pretend to be some kind of knowledgeable motor guy but a little while ago I went nuts trying to chase up these kinds of charts on motors and most don't list Nm or any kind of torque numbers which is really annoying.
For me just seeing some Nm numbers displayed inspires a lot of confidence.
Speed Kills Range, 10mph = 46 miles range, 20mph = 20 miles, 30mph = 8 miles rangehttps://goo.gl/1JNL53
Over Charging Kills ur battery bit.ly/1hzWKl4
Consider PAS as your only throttle https://goo.gl/Kg1F8F
Fuel-Cell is the ultimate battery coupled with 4th-gen Nuclear
https://goo.gl/TcKtHs https://goo.gl/ZhFFot https://goo.gl/gfa215
10 Square Miles of solar panels = 0.12GW average power! https://goo.gl/Ub1S39
arkmundi   1 GW
1 GW
Post by arkmundi » Feb 04 2015 5:53pm
Sorry to hang my ignorance out there, but can someone please explain this chart to me? Or point me to a thread or URL where there's an explanation? Got this chart in my inbox this morning for the Zhenlong 1500 watt motor and first time I've cared what it means.
neptronix   100 GW
Post by neptronix » Feb 04 2015 7:38pm
I can summarize that graph for you...
That motor is horrible. 77% peak efficiency is awful; the worst i have seen for a direct drive motor. 1500w peak power is not a nominal rating. It's more like a 1200w (or less) motor. Do not buy.
neptronix   100 GW
Post by neptronix » Feb 04 2015 7:50pm
Pretty standard packing job
I asked for a 24mm internally wide rim, and they certainly delivered.. spokes look like 12-11 gauge.
Axle is about 8.5 inches or 215mm wide.
Are you serious... these phase wires are more for a 500w motor... :(
Came with 2 extra spokes and some fuses, etc. Nice touch.
I had to know... are these laminations actually 0.35mm or not.. :)
Nice stator construction.. windings are also fairly flattened.
Within a rounding error of being 35mm wide.. okay!
Yup, 0.35mm laminations it seems.. :)
I couldn't get a really accurate measure here, but it appeared as if the magnets were just a tiny bit wider than the stator.
There is a bit of a gap in the magnets..
Stator pic.
Phase wires look like 18 gauge.. this needs to be remedied... very inadequate for the rating of the motor ( and the hell i plan on putting it through )
It actually fits a 135mm dropout!! ( many similar cheap 35mm wide stator motors do not! )
7.94kg for the entire wheel.. nuts, disc brake bolts and all.. so, about 17.5lbs in total. I'd imagine that the hub weight is about 16lb.
645rpm / 49v = 13.16kv and about 95W no load. The wheel was bouncing up and down a lot due to the wheel being out of true ( typical china build ), so the real no load might be more like 90w. This is impressive for a 35mm wide motor, actually. My memory is fuzzy, but i remember my MAC 8T no-loading at ~150W and the Crystalyte HS3548 no-loading at a similar wattage.
I feel good about this motor, though the wheel build is hilariously off.. so i've sent it to the local bike shop to get trued.
cwah   10 GW
Post by cwah » Feb 04 2015 9:12pm
How does it compare to a mxus?
neptronix   100 GW
Post by neptronix » Feb 05 2015 3:54am
Don't own a mxus, haven't even had a single ride with the motor yet.. settle down over there.. :P
arkmundi   1 GW
1 GW
Post by arkmundi » Feb 05 2015 9:31am
neptronix wrote:I can summarize that graph for you...
It goes to the question of professional evaluation of hub motors. There is a significant growth of interest and adoption. So companies in China are building capacity. This will not be the first time that a Chinese company comes online at Alibaba with product. What I'm asking for is methodology for competent comparative analysis. If you have some additional tips, that would be great. For instance, what are the range of efficiency values across a range of motors?
cwah   10 GW
Post by cwah » Feb 08 2015 2:45pm
You need a sine wave controller to truly enjoy this motor performance
Dauntless   100 GW
Post by Dauntless » Feb 08 2015 3:39pm
cwah wrote:You need a sine wave controller to truly enjoy this motor performance
Do you have a particular controller in mind?
Any sufficiently advanced technology is INDISTINGUISHABLE FROM MAGIC!
- Arthur C. Clarke
neptronix   100 GW
Post by neptronix » Feb 11 2015 9:36pm
There's no reason specific to this motor that you'd need a sinewave controller.
Anyway, i hooked this up to my turner full suspension bike and a 3077 9FET infineon-type controller from cellman on a saggy 12S Lipo battery cranked the controller up to 45A and 100 phase amps for a ~2.22:1 phase:battery amp ratio. Initial torque was a bit sluggish, but once you got the motor to about half speed, the power started kicking in. Then i tuned it to 45A & 120 phase amps for a 2.6:1 ratio and the acceleration improved considerably.. this confirms something i've known about high speed windings - you're gonna need a high phase amp ratio to get the motor rolling. I would have tried a 3:1 phase amp ratio, but the 9FET was already getting rather hot.
So i pushed the bike up and down 10% grades a few times at 2000w with no pedaling. At the end of a few miles of this, the motor felt like it was maybe a few degrees above ambient after this abuse. I didn't have a speedometer set up just yet, but could tell that i was running at around 35mph on the flat sections because the water was being swept away from my eyes.
So the preliminary, not so scientific judgement of this motor is that yes indeed, it is rather efficient and powerful despite being driven lightly and through those tiny little 18gauge phase wires it comes with.
I have a 12FET 3077 controller coming that i plan on running at 65A and 180A phase amps, to push this motor up to 3000w nominal. Then i will actually gather some videos and figures etc.
diggler   1 kW
Post by diggler » Feb 12 2015 2:57am
Bookmarked!
I will be following with much excitement!
So did you get the 731rpm/3 turn one?
No of course there is no need for a sine wave controller with this motor, but it would be sweet because the closer you can get to %100 motor/controller/battery efficiency the way better.
Mate that with a recumbent bike, ceramic bearings, light weight and high psi low drag tires for the ultimate in performance and efficiency.
Anyway it's really nice to have someone with experience putting this motor through the ringer and opening it up and everything.
Thanks for your work!
O and when I was emailing them they said they were 2mm wires so this equivalates to about 14 AWG.
Unless they were lying to me. :wink:
* Phase wire is 2.0mm.Because no enough room to put thicker wires.
* If possible,we also can make wire to be 4mm.Need to modify axle.If we modify axle,we also need to use other cover to make it.(the bearing is bigger).But the spacing of front motor will more than 120mm,the rear hub motor will be about 155mm.
GAS ELECTRIC FAT BIKE 49CC/3000W MXUS V1 18s Lipo 18 Fet BUILDING...http://endless-sphere.com/forums/viewto ... =6&t=65638
600W CAPACITIVE SPOT WELDER BUILDING... http://endless-sphere.com/forums/viewto ... =2&t=66466
HOLANDIA BEACH CRUSER 1000W 9C ?TURN REBUILDING... no thread yet.
Next project will be 18" Iron Horse hard tail mid drive
neptronix   100 GW
Post by neptronix » Feb 12 2015 2:49pm
As i stated a bit above.. My winding = 645rpm / 49v = 13.16kv and about 95W no load.
A sine motor controller isn't necessarily more efficient. Nobody has ever tested that. The commutation may be more complex.. i suspect that it will be less efficient, or just equal in efficiency
Given that the phase wires fit in my wire cutter at the 18 gauge point, i'd say that what they're claiming is not matching up one bit ;) ( see pic above also )
What i will do is simply cut the phase wire at about 1.5 inches out of the axle and replace with 12 gauge, as i do with all other motors. Then i get 90% of the benefit of upgrading the entire length of wire. Good enough :)
I am wondering if i can order a stator with an additional turn. Leafbike does have a stator winding item for sale on their webpage, so maybe this is possible. But i do like this winding as it is..
More later.
diggler wrote:Bookmarked!
neptronix   100 GW
Post by neptronix » Feb 12 2015 3:29pm
Ooh, the 12fet 3077 is here... time to get soldering ^_^
parabellum   10 MW
Post by parabellum » Feb 12 2015 7:28pm
Nep, those wire cutter are not made for feflon coated wire, where insulation is minuscule. 36awg teflon wire is about1/3 in the diameder to regular vinil? insulated wire (with insulation) :D. To make sure, I measure strand D then calculate area times N of strands. You may be surprised at the end. :wink:
teslanv   100 MW
Post by teslanv » Feb 12 2015 7:52pm
Subscribed.
Keep the updates coming, Neptronix. :)
DD Hubs, Batteries, Controllers & Custom Ebikes.
http://westcoastelectrics.com
West Coast Electric Cycles
Bellevue, WA
USA
neptronix   100 GW
Post by neptronix » Feb 12 2015 8:43pm
Para, you're probably right, but i cut the wires with the 18ga. setting and replaced the wires with 12 gauge anyway. The 12 gauge looked like double the width.
I have the 12fet 3077 controller all soldered up with 4mm hobbyking bullet connectors as i usually use.. ( these are rated at 90A, yet i've never seen them get warm/hot at 4000w ( battery ) continuous loads for up to 20 minutes, so they should work fine. )
I just have to finish the disc side torque arm tomorrow, hook up & calibrate the cycle analyst, and i'm good to start doing some real tests.
Should be a nice 60 degrees here in Utah for the next few days, and my arthritic joints have been being nice to me so you'll hear back from me soon for sure. :)
parabellum   10 MW
Post by parabellum » Feb 12 2015 10:12pm
It was just me trying to screw the party. :D I always do same thing cutting those wires anyway. Have fun and report back!
diggler   1 kW
Post by diggler » Feb 13 2015 2:23pm
Awesome!
I'm learning a lot.
Thanks for sharing some of your tricks and real world experience!
How are you doing your torque arms?
crossbreak   100 MW
Post by crossbreak » Feb 13 2015 7:17pm
awesome find! I like it for having such high KV. Really makes it usable at 48V. Only the phase wires and the missing thermistor need some treatment. Are the phase wires easy to change? like with the crystalytes and MagicPies where you just have to get the bearing out and new wires installed? I'd like to test the DrBass method using flat desoldering bread as phase wire.
The thin lams make it also a candidate for middrive single reduction setup like bzhwindtalker once did: the LMX. Maybe it runs fine in Delta termination, too (22.5kV would be a NUMBER!!)? Guess it is terminated in star like all DD hubs?
Sorry for asking so many questions :)
neptronix   100 GW
Post by neptronix » Feb 13 2015 9:31pm
Cross: the phase wires come out before the axle touches the dropouts, kind of like how a crystalyte is set up. I don't know how easy modifying the phase wires from inside the hub would be. I found that after my test ride at 3000w, the section of original phase wires i'd left ( about 2 inches ) wasn't even hot or warm to the touch.
Dudes, this motor is the real deal. I just pushed it up the 8% grade test hill again a few times on 65A batt, 173A phase. ( about 3000W ) The 12FET 3077 was extremely hot at the end of this run ( it is sitting in a frame bag though, which does not help ). The motor was barely warm to the touch, i was amazed. I was running it at around 3000W continuous and it barely flinched.
I hit 38mph on a slight ~-0.25% grade in 100% mode, and 44mph up that ~0.25% grade in 120% mode.
I would compare this to my magic pie, except i don't know the limits of the motor just yet because the controller can barely hang. I would say that i get more power per watt inputted for certain than the magic pie.
This motor would be a crapton of fun if you were to order it up with a stator that had an additional turn on it and ran it at 72v.
Reason: note about the controller being in the frame bag.
neptronix   100 GW
Post by neptronix » Feb 13 2015 11:05pm
I sent an email asking leafmotor about getting a stator with another turn on it.. i just have to know how she rolls on 72v!
fechter   100 GW
Post by fechter » Feb 14 2015 1:21am
What size wheel is that? That thing looks like it goes pretty good :twisted:
