Wiki is down
Things related to the E-S Wiki
wesnewell   100 GW
Wiki is down
Post by wesnewell » Feb 28 2015 10:48am
Don't know how long, but this is what I get.
Warning: preg_match(): Compilation failed: group name must start with a non-digit at offset 8 in /home/sphere/public_html/w/includes/MagicWord.php on line 739
Warning: preg_match_all(): Compilation failed: group name must start with a non-digit at offset 4 in /home/sphere/public_html/w/includes/MagicWord.php on line 717
Warning: Invalid argument supplied for foreach() in /home/sphere/public_html/w/includes/MagicWord.php on line 718
Warning: preg_replace(): Compilation failed: group name must start with a non-digit at offset 4 in /home/sphere/public_html/w/includes/MagicWord.php on line 722
amberwolf   100 GW
Re: Wiki is down
Post by amberwolf » Feb 28 2015 1:59pm
I know there is some sort of problem with the SQL server, which is intermittent on ES itself but may be causing the wiki issues?
Progress on fixing is presently unknown last I heard several hours ago.
JamStrong   1 mW
Re: Wiki is down
Post by JamStrong » Mar 04 2015 4:54am
Yah... I'm seeing the same exact error.
neptronix   100 GW
Re: Wiki is down
Post by neptronix » Mar 05 2015 11:32pm
I'm getting in touch with the people up top to see what can be done. Will update this thread with the results.
neptronix   100 GW
Re: Wiki is down
Post by neptronix » Mar 06 2015 4:48pm
Hi guys, i took initiative and fixed the wiki myself. I notice that a lot of articles are blank. Since i do not have a lot of experience with the wiki, i don't know if this is normal or not.
We did experience some issues with our database recently due to performance issues, which should be resolved at this point.
Can one of you folks who uses/reads the wiki do me a favor, and see if everything is still in one piece? if not, i can look into the issue further.
amberwolf   100 GW
Re: Wiki is down
Post by amberwolf » Mar 07 2015 1:57am
On the blank articles I checked out, they have a "history" that does contain an actual article.
I dunno if you can just restore a previous version, or how it works there (havnet played with it before and am too tired to safely mess with thngs).
AFAICT some like Li-ion batteries "blank" article says in the History tab that it actually has something in the present article but it just isn't showing up on the rendered page?
neptronix   100 GW
Re: Wiki is down
Post by neptronix » Mar 07 2015 2:01am
Are you talking about this page? it does have data in it.
http://endless-sphere.com/w/index.php/L ... 28LiIon%29
Can you give me some links to pages that you know show blank, yet have a history that i can uncover?
amberwolf   100 GW
Re: Wiki is down
Post by amberwolf » Mar 07 2015 2:19am
Sorry, I misnamed the one I'd looked at--it was the LiPo article
http://endless-sphere.com/w/index.php/L ... mer_(LiPo)
but that one now has data in it. Weird...it didn't have that when I viewed it earlier.
What I did was middle-click on every article link in the index down to Battery Safety (the last one visible on the page for me without scrolling down). Then switched to each tab and looked at the results, and the first of the Lithium battery articles was blank.
Here are some that are blank but have history data.
http://endless-sphere.com/w/index.php/Acronyms
if you look at it's "view source" tab
http://endless-sphere.com/w/index.php?t ... ction=edit
it does have the data there in the edit window (I didn't look at that tab for any article previously)
http://endless-sphere.com/w/index.php/L ... _(LiFePO4)
blank but this
shows what it should display
http://endless-sphere.com/w/index.php/N ... ide_(NiMH)
http://endless-sphere.com/w/index.php/B ... erioration
Etc.
DrkAngel   100 GW
Re: Wiki is down
Post by DrkAngel » Aug 14 2015 10:47am
ES Wiki problems since "server change".
1. Unable to upload pictures.
2. Logged out in attempt to correct = unable to log in!
Code: Select all
"   Unexpected non-MediaWiki exception encountered, of type "Exception"
exception 'Exception' with message 'There was a problem when connecting to the phpBB database.<br />Check your Host, Username, and Password settings.<br /><br />MySQL Error Number: 0<br />MySQL Error Message: <br /><br />' in /var/www/html/w/extensions/Auth_phpBB.php:703
Stack trace:
#0 /var/www/html/w/extensions/Auth_phpBB.php(431): Auth_phpBB->mySQLError('There was a pro...')
#1 /var/www/html/w/extensions/Auth_phpBB.php(494): Auth_phpBB->connect()
#2 /var/www/html/w/includes/User.php(726): Auth_phpBB->getCanonicalName('Drkangel')
#3 /var/www/html/w/includes/User.php(318): User::getCanonicalName('Drkangel', 'valid')
#4 /var/www/html/w/includes/specials/SpecialUserlogin.php(493): User::newFromName('Drkangel')
#5 /var/www/html/w/includes/specials/SpecialUserlogin.php(629): LoginForm->authenticateUserData()
#6 /var/www/html/w/includes/specials/SpecialUserlogin.php(138): LoginForm->processLogin()
#7 /var/www/html/w/includes/specials/SpecialUserlogin.php(34): LoginForm->execute()
#8 [internal function]: wfSpecialUserlogin(NULL, Object(SpecialPage))
#9 /var/www/html/w/includes/SpecialPage.php(851): call_user_func('wfSpecialUserlo...', NULL, Object(SpecialPage))
#10 /var/www/html/w/includes/SpecialPage.php(578): SpecialPage->execute(NULL)
#11 /var/www/html/w/includes/Wiki.php(251): SpecialPage::executePath(Object(Title))
#12 /var/www/html/w/includes/Wiki.php(63): MediaWiki->handleSpecialCases(Object(Title), Object(OutputPage), Object(WebRequest))
#13 /var/www/html/w/index.php(114): MediaWiki->performRequestForTitle(Object(Title), NULL, Object(OutputPage), Object(User), Object(WebRequest))
#14 {main}    "
Index - Homemade Battery Packs - Updated - December 2019
EBike Toolbox - Bargains! $
Endless Sphere Wiki - Lost?
gammaray   10 W
Re: Wiki is down
Post by gammaray » Aug 16 2015 5:11pm
DrkAngel wrote:ES Wiki problems since "server change".
#14 {main} "
Could you give it a shot again? I changed some configuration files around.
SysAdmin Joke: A man with one clock knows what time it is – a man with two is never sure.
DrkAngel   100 GW
Re: Wiki is down
Post by DrkAngel » Aug 16 2015 6:27pm
Able to Log In. ... Thanks
Tried uploading picture and got ...
"Upload warning
The upload directory (public) is not writable by the webserver. "
UPDATE:
Log in = working properly
Picture uploads = working properly
pwd   1 kW
Re: Wiki is down
Post by pwd » Apr 27 2018 9:02am
Wiki is down: here is what the page showed:
Code: Select all
Try waiting a few minutes and reloading.
(Cannot access the database)
Backtrace:
#0 /var/www/html/w/includes/libs/rdbms/loadbalancer/LoadBalancer.php(995): Wikimedia\Rdbms\Database->reportConnectionError('php_network_get...')
#1 /var/www/html/w/includes/libs/rdbms/loadbalancer/LoadBalancer.php(666): Wikimedia\Rdbms\LoadBalancer->reportConnectionError()
#2 /var/www/html/w/includes/GlobalFunctions.php(3062): Wikimedia\Rdbms\LoadBalancer->getConnection(0, Array, false)
#3 /var/www/html/w/includes/page/WikiPage.php(384): wfGetDB(-1)
#4 /var/www/html/w/includes/page/WikiPage.php(467): WikiPage->loadPageData()
#5 /var/www/html/w/includes/page/WikiPage.php(508): WikiPage->exists()
#6 /var/www/html/w/includes/page/WikiPage.php(230): WikiPage->getContentModel()
#7 /var/www/html/w/includes/page/WikiPage.php(217): WikiPage->getContentHandler()
#8 /var/www/html/w/includes/actions/Action.php(96): WikiPage->getActionOverrides()
#9 /var/www/html/w/includes/actions/Action.php(154): Action::factory('view', Object(WikiPage), Object(RequestContext))
#10 /var/www/html/w/includes/MediaWiki.php(155): Action::getActionName(Object(RequestContext))
#11 /var/www/html/w/includes/MediaWiki.php(778): MediaWiki->getAction()
#12 /var/www/html/w/includes/MediaWiki.php(523): MediaWiki->main()
#13 /var/www/html/w/index.php(43): MediaWiki->run()
#14 {main}
Commuter/Street Build viewtopic.php?f=6&t=98286:
Rocky Mountain Element
Magic Pie 4 front + Leafmotor 1500 rear w/ WCEC 18fet
Samsung 40T 14S7P
Offroad Build viewtopic.php?f=6&t=102195:
2019 Rocky Mountain Blizzard 20
Cyclone "3kw" 13T motor to 36T chain ring then 32T chain ring to 11T-46T Cassette
em3ev 14S5P 30Q or 14S6P 25R pack
neptronix   100 GW
Re: Wiki is down
Post by neptronix » Apr 27 2018 10:22am
Crap. Actually it looks like wiki has been down for possibly months since I don't see it in backups until i go back to late 2017.
When was the last time you guys accessed it?
It will need work this weekend.... :(
neptronix   100 GW
Re: Wiki is down
Post by neptronix » Apr 28 2018 4:51pm
Okay, it's fixed. The recent change to the our database unfortunately broke wiki super hard. All wikimedia's tools for repairing it did not function. I had to do a lot of SQL surgery by hand.
Please do me a favor and let me know if anything is funky with it, and sorry for the bugs.
Alan B   100 GW
Re: Wiki is down
Post by Alan B » Apr 28 2018 5:20pm
Thanks for the effort.
neptronix   100 GW
Re: Wiki is down
Post by neptronix » Apr 28 2018 5:30pm
Alan B wrote:
Apr 28 2018 5:20pm
You're welcome. I'm just happy to have all this nasty stuff done.
DrkAngel   100 GW
Re: Wiki is down
Post by DrkAngel » Apr 28 2018 8:54pm
Error when trying to upload picture or edit page ...
Edit page error:
Database error.jpg (60.89 KiB) Viewed 6646 times
https://endless-sphere.com/w/index.php/Main_Page
Endless Sphere Wiki
neptronix   100 GW
Re: Wiki is down
Post by neptronix » Apr 29 2018 6:57pm
Hmm, i believe i have that fixed.
neptronix   100 GW
Re: Wiki is down
Post by neptronix » May 02 2018 9:13am
Wiki editing is still down, but viewing still works. I will address that issue this weekend. It will require more database surgery.
ps, if you get a wiki error, send it to me via PM and do not post it in this thread.
neptronix   100 GW
Re: Wiki is down
Post by neptronix » Jun 22 2018 9:27am
Guys, the wiki is down for now because it looks like some malicious actors found a way to attack it, which caused our server to be down for a few hours this morning. I may need to update the wikimedia software, or the database might need more surgery. stay tuned.
Stanislavchik   10 mW
Re: Wiki is down
Post by Stanislavchik » Aug 30 2018 4:55am
Still isn't working. :(
amberwolf   100 GW
Re: Wiki is down
Post by amberwolf » Aug 30 2018 12:07pm
